Change Log
This document contains a summary of the new features, changes and fixes in each release of Corstone-1000 software stack.
Version 2026.05
Changes
  • Upgraded key Corstone-1000 components to U-Boot 2025.10, TF-A 2.14.1, TF-M 2.2.2, OP-TEE 4.9.0, Trusted Services 1.3.0, and Linux 6.19.
  • Added GPT support in TF-M and updated MCUboot to use the GPT library for firmware-update partitions.
  • Extended the TF-M firmware update flow with GPT fixes, partition create/remove/duplicate operations, metadata-only handling, flash erase protection, stale partition cleanup, and better handling of older images during PSA FWU.
  • Added SSH-enabled build overlay for FVP mass-storage images.
  • Removed GRUB from the initramfs boot package set.
Corstone-1000 components versions
linux-yocto
6.19
u-boot
2025.10
external-system
0.1.0
optee-client
4.9.0
optee-os
4.9.0
trusted-firmware-a
2.14.1
trusted-firmware-m
2.2.2
libts
v1.3.0
ts-sp-{se-proxy, smm-gateway}
v1.3.0
ts-psa-{crypto, iat, its. ps}-api-test
74dc6646ff
Yocto distribution components versions
meta-arm
wrynose
bitbake
22021758e6
meta-openembedded
9af4488d46
openembedded-core
06dd66e622
meta-yocto
8251bdad5f
meta-secure-core
07a99ae241
busybox
1.37.0
musl
1.2.6
gcc-arm-none-eabi
15.2.rel1
gcc-cross-aarch64
15.2.0
openssl
3.5.6
Version 2025.12
Changes
  • Delivered end-to-end Cortex-A320 enablement across U-Boot, TF-A, TF-M, OP-TEE, Yocto machine layers, and documentation, including device-tree updates, MPIDR handling, and FVP model renaming.
  • Rolled out the PSA Firmware Update (DEN0118) pipeline: U-Boot capsule parsing, Bootloader Abstraction Layer in TF-M, ESRT exposure, and Trusted Services IPC bridges replacing legacy capsule code.
  • Hardened the new firmware update flow with EFI self-tests, metadata restructuring for partial and multi-image acceptance, and RSE-COMMS gating refinements.
  • Upgraded key firmware components (TF-A 2.13.0, TF-M 2.2.1, Trusted Services 1.2.0, OP-TEE OS 4.7.0) and introduced targeted test skips plus integer-only build modes to keep validation green.
  • Cleaned and renumbered downstream patch series across Trusted Services and TF-M while removing obsolete integrations to align with upstream baselines.
  • Refreshed release material and architecture guides to describe the A320 profile, PSA FWU behavior, and updated software stack.
  • Added KAS profiles, machine includes, and automated FVP selection logic to streamline developer workflows for the refreshed platform configuration.
linux-yocto
6.12.60
u-boot
2025.04
external-system
0.1.0
optee-client
4.7.0
optee-os
4.7.0
trusted-firmware-a
2.13.0
trusted-firmware-m
2.2.1
libts
v1.2.0
v1.2.0
74dc6646ff
meta-arm
whinlatter
bitbake
0dde1a3ff8
meta-openembedded
fc0152e434
openembedded-core
4bd920ad7d
meta-yocto
b3b6592635
meta-secure-core
63209fb150
busybox
1.37.0
musl
1.2.5
gcc-arm-none-eabi
13.3.rel1
gcc-cross-aarch64
15.2.0
openssl
3.5.4
Version 2025.05
Changes
  • OP-TEE OS: Added support for v4.4
  • Trusted Services: PSA-Crypto structures aligned with TF-M, added protobuf interface to crypto-sp
  • Documentation: fixed typos, added host-level authentication section, enabled fly-out sidebar menu
  • Das U-Boot: Reserved memory for RSS communication-pointer access protocol
  • Linux Kernel: Upgraded kernel to v6.12, updated Upstream-Status notes for remoteproc patches
  • Corstone-1000 image: Implemented IMAGE_ROOTFS_EXTRA_SPACE workaround
linux-yocto
6.12.30
u-boot
2023.07.02
external-system
0.1.0
optee-client
4.4.0
optee-os
4.4.0
trusted-firmware-a
2.11.0
trusted-firmware-m
2.1.1
libts
602be60719
ts-newlib
4.1.0
74dc6646ff
602be60719
meta-arm
walnascar
poky
ee0d8d8a61
meta-openembedded
2169c9afcc
meta-secure-core
423bc85b05
busybox
1.37.0
musl
1.2.5
gcc-arm-none-eabi
13.3.rel1
gcc-cross-aarch64
14.2.0
openssl
3.4.1
Version 2024.11
Changes
  • Implementation of a replication strategy for FWU metadata in TF-M according to the FWU specification.
  • Upgrade to metadata version 2 in TF-M.
  • Increase the ITS and PS memory size in Secure Flash for TF-M.
  • SW components upgrades.
  • Bug fixes.
linux-yocto
6.10.14
u-boot
2023.07.02
external-system
0.1.0
optee-client
4.2.0
optee-os
4.2.0
trusted-firmware-a
2.11.0
trusted-firmware-m
2.1.0
libts
602be60719
ts-newlib
4.1.0
74dc6646ff
602be60719
meta-arm
styhead
poky
5465094be9
meta-openembedded
461d85a183
meta-secure-core
59d7e90542
busybox
1.36.1
musl
1.2.5
gcc-arm-none-eabi
13.3.rel1
gcc-cross-aarch64
14.2.0
openssl
3.3.1
Version 2024.06
Changes
  • Re-enabling support for the External System using linux remoteproc (only supporting switching on and off the External System)
  • UEFI Secure Boot and Authenticated Variable support
  • RSE Comms replaces OpenAMP
  • The EFI System partition image is now created by the meta-arm build system. This image is mounted on the second MMC card by default in the FVP.
  • The capsule generation script is now part of the meta-arm build system. Corstone1000-flash-firmware-image recipe generates a capsule binary using the U-Boot capsule generation tool that includes all the firmware binaries and recovery kernel image.
  • Bug fixes
arm-tstee
2.0.0
linux-yocto
6.6.23
u-boot
2023.07.02
external-system
0.1.0
optee-client
4.1.0
optee-os
4.1.0
trusted-firmware-a
2.10.4
trusted-firmware-m
2.0.0
libts
602be60719
ts-newlib
4.1.0
602be60719
602be60719
meta-arm
scarthgap
poky
scarthgap
meta-openembedded
scarthgap
meta-secure-core
scarthgap
busybox
1.36.1
musl
1.2.4
gcc-arm-none-eabi
13.2.Rel1
gcc-cross-aarch64
13.2.0
openssl
3.2.1
Version 2023.11
Changes
  • Making Corstone-1000 SystemReady IR 2.0 certifiable
  • Allow booting Debian & OpenSUSE on FVP
  • Add support for two MMC cards for the FVP
  • Add signed capsule update support
  • Enable on-disk capsule update
  • Add the feature of purging specific DT nodes in U-Boot before Linux
  • Add Ethernet over VirtIO support in U-Boot
  • Add support for unaligned MMC card images
  • Reducing the out-of-tree patches by upstreaming them to the corresponding open-source projects
  • Bug fixes
arm-ffa-tee
1.1.2-r0
linux-yocto
6.5.7
u-boot
2023.07
external-system
0.1.0+gitAUTOINC+8c9dca74b1-r0
optee-client
3.22.0
optee-os
3.22.0
trusted-firmware-a
2.9.0
trusted-firmware-m
1.8.1
libts
08b3d39471
ts-newlib
4.1.0
38cb53a4d9
08b3d39471
meta-arm
nanbield
poky
nanbield
meta-openembedded
nanbield
meta-secure-core
nanbield
busybox
1.36.1
musl
1.2.4
gcc-arm-none-eabi
11.2-2022.02
gcc-cross-aarch64
13.2.0
openssl
3.1.3
Version 2023.06
Changes
  • GPT support (in TF-M, TF-A, U-boot)
  • Use TF-M BL1 code as the ROM code instead of MCUboot (the next stage bootloader BL2 remains to be MCUboot)
  • Secure Enclave uses CC312 OTP as the provisioning backend in FVP and FPGA
  • NVMXIP block storage support in U-Boot
  • Upgrading the SW stack recipes
  • Upgrades for the U-Boot FF-A driver and MM communication
arm-ffa-tee
1.1.2-r0
arm-ffa-user
5.0.1-r0
corstone1000-external-sys-tests
1.0+gitAUTOINC+2945cd92f7-r0
external-system
linux-yocto
6.1.25+gitAUTOINC+36901b5b29_581dc1aa2f-r0
u-boot
2023.01-r0
optee-client
3.18.0-r0
optee-os
3.20.0-r0
trusted-firmware-a
2.8.0-r0
trusted-firmware-m
1.7.0-r0
ts-newlib
4.1.0-r0
38cb53a4d9
08b3d39471
meta-arm
mickledore
poky
mickledore
meta-openembedded
mickledore
busybox
1.36.0-r0
musl
1.2.3+gitAUTOINC+7d756e1c04-r0
gcc-arm-none-eabi-native
11.2-2022.02
gcc-cross-aarch64
12.2.rel1-r0
openssl
3.1.0-r0
Version 2022.11.23
Changes
  • Booting the External System (Cortex-M3) with RTX RTOS
  • Adding MHU communication between the HOST (Cortex-A35) and the External System
  • Adding a Linux application to test the External System
  • Adding ESRT (EFI System Resource Table) support
arm-ffa-tee
1.1.1
arm-ffa-user
5.0.0
1.0
external-system
0.1.0
linux-yocto
5.19
u-boot
2022.07
optee-client
3.18.0
optee-os
3.18.0
trusted-firmware-a
2.7.0
trusted-firmware-m
1.6.0
ts-newlib
4.1.0
451aa087a4
3d4956770f
meta-arm
langdale
poky
langdale
meta-openembedded
langdale
busybox
1.35.0
musl
1.2.3+git37e18b7bf3
11.2-2022.02
gcc-cross-aarch64
12.2
openssl
3.0.5
Version 2022.04.04
Changes
  • Linux distro openSUSE, raw image installation and boot in the FVP.
  • SCT test support in FVP.
  • Manual capsule update support in FVP.
Version 2022.02.25
Changes
  • Building and running psa-arch-tests on Corstone-1000 FVP
  • Enabled smm-gateway partition in Trusted Service on Corstone-1000 FVP
  • Enabled MHU driver in Trusted Service on Corstone-1000 FVP
  • Enabled OpenAMP support in SE proxy SP on Corstone-1000 FVP
Version 2022.02.21
Changes
  • psa-arch-tests: recipe is dropped and merged into the secure-partitons recipe.
  • psa-arch-tests: The tests are align with latest tfm version for psa-crypto-api suite.
Version 2022.01.18
Changes
  • psa-arch-tests: change master to main for psa-arch-tests
  • U-Boot: fix null pointer exception for get_image_info
  • TF-M: fix capsule instability issue for Corstone-1000
Version 2022.01.07
Changes
  • Corstone-1000: fix SystemReady-IR ACS test (SCT, FWTS) failures.
  • U-Boot: send bootcomplete event to secure enclave.
  • U-Boot: support populating Corstone-1000 image_info to ESRT table.
  • U-Boot: add ethernet device and enable configs to support bootfromnetwork SCT.
Version 2021.12.15
Changes
  • Enabling Corstone-1000 FPGA support on: - Linux 5.10 - OP-TEE 3.14 - Trusted Firmware-A 2.5 - Trusted Firmware-M 1.5
  • Adding openamp support in SE proxy SP
  • OP-TEE: adding smm-gateway partition
  • U-Boot: introducing Arm FF-A and MM support
Version 2021.10.29
Changes
  • Enabling Corstone-1000 FVP support on: - Linux 5.10 - OP-TEE 3.14 - Trusted Firmware-A 2.5 - Trusted Firmware-M 1.4
  • Linux kernel: enabling EFI, adding FF-A debugfs driver, integrating ARM_FFA_TRANSPORT.
  • U-Boot: Extending EFI support
  • python3-imgtool: adding recipe for Trusted-firmware-m
  • python3-imgtool: adding the Yocto recipe used in signing host images (based on MCUBOOT format)
Copyright (c) 2022-2026, Arm Limited. All rights reserved.
