.. # Copyright (c) 2022-2026, Arm Limited. # # SPDX-License-Identifier: MIT ########## Change Log ########## This document contains a summary of the new features, changes and fixes in each release of Corstone-1000 software stack. *************** Version 2026.05 *************** Changes ======= - Upgraded key Corstone-1000 components to U-Boot 2025.10, TF-A 2.14.1, TF-M 2.2.2, OP-TEE 4.9.0, Trusted Services 1.3.0, and Linux 6.19. - Added GPT support in TF-M and updated MCUboot to use the GPT library for firmware-update partitions. - Extended the TF-M firmware update flow with GPT fixes, partition create/remove/duplicate operations, metadata-only handling, flash erase protection, stale partition cleanup, and better handling of older images during PSA FWU. - Added SSH-enabled build overlay for FVP mass-storage images. - Removed GRUB from the initramfs boot package set. Corstone-1000 components versions ================================= +-------------------------------------------+-------------------+ | linux-yocto | 6.19 | +-------------------------------------------+-------------------+ | u-boot | 2025.10 | +-------------------------------------------+-------------------+ | external-system | 0.1.0 | +-------------------------------------------+-------------------+ | optee-client | 4.9.0 | +-------------------------------------------+-------------------+ | optee-os | 4.9.0 | +-------------------------------------------+-------------------+ | trusted-firmware-a | 2.14.1 | +-------------------------------------------+-------------------+ | trusted-firmware-m | 2.2.2 | +-------------------------------------------+-------------------+ | libts | v1.3.0 | +-------------------------------------------+-------------------+ | ts-sp-{se-proxy, smm-gateway} | v1.3.0 | +-------------------------------------------+-------------------+ | ts-psa-{crypto, iat, its. ps}-api-test | 74dc6646ff | +-------------------------------------------+-------------------+ Yocto distribution components versions ====================================== +-------------------------------------------+----------------+ | meta-arm | wrynose | +-------------------------------------------+----------------+ | bitbake | 22021758e6 | +-------------------------------------------+----------------+ | meta-openembedded | 9af4488d46 | +-------------------------------------------+----------------+ | openembedded-core | 06dd66e622 | +-------------------------------------------+----------------+ | meta-yocto | 8251bdad5f | +-------------------------------------------+----------------+ | meta-secure-core | 07a99ae241 | +-------------------------------------------+----------------+ | busybox | 1.37.0 | +-------------------------------------------+----------------+ | musl | 1.2.6 | +-------------------------------------------+----------------+ | gcc-arm-none-eabi | 15.2.rel1 | +-------------------------------------------+----------------+ | gcc-cross-aarch64 | 15.2.0 | +-------------------------------------------+----------------+ | openssl | 3.5.6 | +-------------------------------------------+----------------+ *************** Version 2025.12 *************** Changes ======= - Delivered end-to-end Cortex-A320 enablement across U-Boot, TF-A, TF-M, OP-TEE, Yocto machine layers, and documentation, including device-tree updates, MPIDR handling, and FVP model renaming. - Rolled out the PSA Firmware Update (DEN0118) pipeline: U-Boot capsule parsing, Bootloader Abstraction Layer in TF-M, ESRT exposure, and Trusted Services IPC bridges replacing legacy capsule code. - Hardened the new firmware update flow with EFI self-tests, metadata restructuring for partial and multi-image acceptance, and RSE-COMMS gating refinements. - Upgraded key firmware components (TF-A 2.13.0, TF-M 2.2.1, Trusted Services 1.2.0, OP-TEE OS 4.7.0) and introduced targeted test skips plus integer-only build modes to keep validation green. - Cleaned and renumbered downstream patch series across Trusted Services and TF-M while removing obsolete integrations to align with upstream baselines. - Refreshed release material and architecture guides to describe the A320 profile, PSA FWU behavior, and updated software stack. - Added KAS profiles, machine includes, and automated FVP selection logic to streamline developer workflows for the refreshed platform configuration. Corstone-1000 components versions ================================= +-------------------------------------------+-------------------+ | linux-yocto | 6.12.60 | +-------------------------------------------+-------------------+ | u-boot | 2025.04 | +-------------------------------------------+-------------------+ | external-system | 0.1.0 | +-------------------------------------------+-------------------+ | optee-client | 4.7.0 | +-------------------------------------------+-------------------+ | optee-os | 4.7.0 | +-------------------------------------------+-------------------+ | trusted-firmware-a | 2.13.0 | +-------------------------------------------+-------------------+ | trusted-firmware-m | 2.2.1 | +-------------------------------------------+-------------------+ | libts | v1.2.0 | +-------------------------------------------+-------------------+ | ts-sp-{se-proxy, smm-gateway} | v1.2.0 | +-------------------------------------------+-------------------+ | ts-psa-{crypto, iat, its. ps}-api-test | 74dc6646ff | +-------------------------------------------+-------------------+ Yocto distribution components versions ====================================== +-------------------------------------------+----------------+ | meta-arm | whinlatter | +-------------------------------------------+----------------+ | bitbake | 0dde1a3ff8 | +-------------------------------------------+----------------+ | meta-openembedded | fc0152e434 | +-------------------------------------------+----------------+ | openembedded-core | 4bd920ad7d | +-------------------------------------------+----------------+ | meta-yocto | b3b6592635 | +-------------------------------------------+----------------+ | meta-secure-core | 63209fb150 | +-------------------------------------------+----------------+ | busybox | 1.37.0 | +-------------------------------------------+----------------+ | musl | 1.2.5 | +-------------------------------------------+----------------+ | gcc-arm-none-eabi | 13.3.rel1 | +-------------------------------------------+----------------+ | gcc-cross-aarch64 | 15.2.0 | +-------------------------------------------+----------------+ | openssl | 3.5.4 | +-------------------------------------------+----------------+ *************** Version 2025.05 *************** Changes ======= - OP-TEE OS: Added support for v4.4 - Trusted Services: PSA-Crypto structures aligned with TF-M, added protobuf interface to crypto-sp - Documentation: fixed typos, added host-level authentication section, enabled fly-out sidebar menu - Das U-Boot: Reserved memory for RSS communication-pointer access protocol - Linux Kernel: Upgraded kernel to v6.12, updated Upstream-Status notes for remoteproc patches - Corstone-1000 image: Implemented IMAGE_ROOTFS_EXTRA_SPACE workaround Corstone-1000 components versions ================================= +-------------------------------------------+-------------------+ | linux-yocto | 6.12.30 | +-------------------------------------------+-------------------+ | u-boot | 2023.07.02 | +-------------------------------------------+-------------------+ | external-system | 0.1.0 | +-------------------------------------------+-------------------+ | optee-client | 4.4.0 | +-------------------------------------------+-------------------+ | optee-os | 4.4.0 | +-------------------------------------------+-------------------+ | trusted-firmware-a | 2.11.0 | +-------------------------------------------+-------------------+ | trusted-firmware-m | 2.1.1 | +-------------------------------------------+-------------------+ | libts | 602be60719 | +-------------------------------------------+-------------------+ | ts-newlib | 4.1.0 | +-------------------------------------------+-------------------+ | ts-psa-{crypto, iat, its. ps}-api-test | 74dc6646ff | +-------------------------------------------+-------------------+ | ts-sp-{se-proxy, smm-gateway} | 602be60719 | +-------------------------------------------+-------------------+ Yocto distribution components versions ====================================== +-------------------------------------------+----------------+ | meta-arm | walnascar | +-------------------------------------------+----------------+ | poky | ee0d8d8a61 | +-------------------------------------------+----------------+ | meta-openembedded | 2169c9afcc | +-------------------------------------------+----------------+ | meta-secure-core | 423bc85b05 | +-------------------------------------------+----------------+ | busybox | 1.37.0 | +-------------------------------------------+----------------+ | musl | 1.2.5 | +-------------------------------------------+----------------+ | gcc-arm-none-eabi | 13.3.rel1 | +-------------------------------------------+----------------+ | gcc-cross-aarch64 | 14.2.0 | +-------------------------------------------+----------------+ | openssl | 3.4.1 | +-------------------------------------------+----------------+ *************** Version 2024.11 *************** Changes ======= - Implementation of a replication strategy for FWU metadata in TF-M according to the FWU specification. - Upgrade to metadata version 2 in TF-M. - Increase the ITS and PS memory size in Secure Flash for TF-M. - SW components upgrades. - Bug fixes. Corstone-1000 components versions ================================= +-------------------------------------------+-----------------------------------------------------+ | linux-yocto | 6.10.14 | +-------------------------------------------+-----------------------------------------------------+ | u-boot | 2023.07.02 | +-------------------------------------------+-----------------------------------------------------+ | external-system | 0.1.0 | +-------------------------------------------+-----------------------------------------------------+ | optee-client | 4.2.0 | +-------------------------------------------+-----------------------------------------------------+ | optee-os | 4.2.0 | +-------------------------------------------+-----------------------------------------------------+ | trusted-firmware-a | 2.11.0 | +-------------------------------------------+-----------------------------------------------------+ | trusted-firmware-m | 2.1.0 | +-------------------------------------------+-----------------------------------------------------+ | libts | 602be60719 | +-------------------------------------------+-----------------------------------------------------+ | ts-newlib | 4.1.0 | +-------------------------------------------+-----------------------------------------------------+ | ts-psa-{crypto, iat, its. ps}-api-test | 74dc6646ff | +-------------------------------------------+-----------------------------------------------------+ | ts-sp-{se-proxy, smm-gateway} | 602be60719 | +-------------------------------------------+-----------------------------------------------------+ Yocto distribution components versions ====================================== +-------------------------------------------+------------------------------+ | meta-arm | styhead | +-------------------------------------------+------------------------------+ | poky | 5465094be9 | +-------------------------------------------+------------------------------+ | meta-openembedded | 461d85a183 | +-------------------------------------------+------------------------------+ | meta-secure-core | 59d7e90542 | +-------------------------------------------+------------------------------+ | busybox | 1.36.1 | +-------------------------------------------+------------------------------+ | musl | 1.2.5 | +-------------------------------------------+------------------------------+ | gcc-arm-none-eabi | 13.3.rel1 | +-------------------------------------------+------------------------------+ | gcc-cross-aarch64 | 14.2.0 | +-------------------------------------------+------------------------------+ | openssl | 3.3.1 | +-------------------------------------------+------------------------------+ *************** Version 2024.06 *************** Changes ======= - Re-enabling support for the External System using linux remoteproc (only supporting switching on and off the External System) - UEFI Secure Boot and Authenticated Variable support - RSE Comms replaces OpenAMP - The EFI System partition image is now created by the meta-arm build system. This image is mounted on the second MMC card by default in the FVP. - The capsule generation script is now part of the meta-arm build system. Corstone1000-flash-firmware-image recipe generates a capsule binary using the U-Boot capsule generation tool that includes all the firmware binaries and recovery kernel image. - SW components upgrades - Bug fixes Corstone-1000 components versions ================================= +-------------------------------------------+-----------------------------------------------------+ | arm-tstee | 2.0.0 | +-------------------------------------------+-----------------------------------------------------+ | linux-yocto | 6.6.23 | +-------------------------------------------+-----------------------------------------------------+ | u-boot | 2023.07.02 | +-------------------------------------------+-----------------------------------------------------+ | external-system | 0.1.0 | +-------------------------------------------+-----------------------------------------------------+ | optee-client | 4.1.0 | +-------------------------------------------+-----------------------------------------------------+ | optee-os | 4.1.0 | +-------------------------------------------+-----------------------------------------------------+ | trusted-firmware-a | 2.10.4 | +-------------------------------------------+-----------------------------------------------------+ | trusted-firmware-m | 2.0.0 | +-------------------------------------------+-----------------------------------------------------+ | libts | 602be60719 | +-------------------------------------------+-----------------------------------------------------+ | ts-newlib | 4.1.0 | +-------------------------------------------+-----------------------------------------------------+ | ts-psa-{crypto, iat, its. ps}-api-test | 602be60719 | +-------------------------------------------+-----------------------------------------------------+ | ts-sp-{se-proxy, smm-gateway} | 602be60719 | +-------------------------------------------+-----------------------------------------------------+ Yocto distribution components versions ====================================== +-------------------------------------------+------------------------------+ | meta-arm | scarthgap | +-------------------------------------------+------------------------------+ | poky | scarthgap | +-------------------------------------------+------------------------------+ | meta-openembedded | scarthgap | +-------------------------------------------+------------------------------+ | meta-secure-core | scarthgap | +-------------------------------------------+------------------------------+ | busybox | 1.36.1 | +-------------------------------------------+------------------------------+ | musl | 1.2.4 | +-------------------------------------------+------------------------------+ | gcc-arm-none-eabi | 13.2.Rel1 | +-------------------------------------------+------------------------------+ | gcc-cross-aarch64 | 13.2.0 | +-------------------------------------------+------------------------------+ | openssl | 3.2.1 | +-------------------------------------------+------------------------------+ *************** Version 2023.11 *************** Changes ======= - Making Corstone-1000 SystemReady IR 2.0 certifiable - Allow booting Debian & OpenSUSE on FVP - Add support for two MMC cards for the FVP - Add signed capsule update support - Enable on-disk capsule update - Add the feature of purging specific DT nodes in U-Boot before Linux - Add Ethernet over VirtIO support in U-Boot - Add support for unaligned MMC card images - Reducing the out-of-tree patches by upstreaming them to the corresponding open-source projects - SW components upgrades - Bug fixes Corstone-1000 components versions ================================= +-------------------------------------------+-----------------------------------------------------+ | arm-ffa-tee | 1.1.2-r0 | +-------------------------------------------+-----------------------------------------------------+ | linux-yocto | 6.5.7 | +-------------------------------------------+-----------------------------------------------------+ | u-boot | 2023.07 | +-------------------------------------------+-----------------------------------------------------+ | external-system | 0.1.0+gitAUTOINC+8c9dca74b1-r0 | +-------------------------------------------+-----------------------------------------------------+ | optee-client | 3.22.0 | +-------------------------------------------+-----------------------------------------------------+ | optee-os | 3.22.0 | +-------------------------------------------+-----------------------------------------------------+ | trusted-firmware-a | 2.9.0 | +-------------------------------------------+-----------------------------------------------------+ | trusted-firmware-m | 1.8.1 | +-------------------------------------------+-----------------------------------------------------+ | libts | 08b3d39471 | +-------------------------------------------+-----------------------------------------------------+ | ts-newlib | 4.1.0 | +-------------------------------------------+-----------------------------------------------------+ | ts-psa-{crypto, iat, its. ps}-api-test | 38cb53a4d9 | +-------------------------------------------+-----------------------------------------------------+ | ts-sp-{se-proxy, smm-gateway} | 08b3d39471 | +-------------------------------------------+-----------------------------------------------------+ Yocto distribution components versions ====================================== +-------------------------------------------+------------------------------+ | meta-arm | nanbield | +-------------------------------------------+------------------------------+ | poky | nanbield | +-------------------------------------------+------------------------------+ | meta-openembedded | nanbield | +-------------------------------------------+------------------------------+ | meta-secure-core | nanbield | +-------------------------------------------+------------------------------+ | busybox | 1.36.1 | +-------------------------------------------+------------------------------+ | musl | 1.2.4 | +-------------------------------------------+------------------------------+ | gcc-arm-none-eabi | 11.2-2022.02 | +-------------------------------------------+------------------------------+ | gcc-cross-aarch64 | 13.2.0 | +-------------------------------------------+------------------------------+ | openssl | 3.1.3 | +-------------------------------------------+------------------------------+ *************** Version 2023.06 *************** Changes ======= - GPT support (in TF-M, TF-A, U-boot) - Use TF-M BL1 code as the ROM code instead of MCUboot (the next stage bootloader BL2 remains to be MCUboot) - Secure Enclave uses CC312 OTP as the provisioning backend in FVP and FPGA - NVMXIP block storage support in U-Boot - Upgrading the SW stack recipes - Upgrades for the U-Boot FF-A driver and MM communication Corstone-1000 components versions ================================= +-------------------------------------------+--------------------------------------------+ | arm-ffa-tee | 1.1.2-r0 | +-------------------------------------------+--------------------------------------------+ | arm-ffa-user | 5.0.1-r0 | +-------------------------------------------+--------------------------------------------+ | corstone1000-external-sys-tests | 1.0+gitAUTOINC+2945cd92f7-r0 | +-------------------------------------------+--------------------------------------------+ | external-system | 0.1.0+gitAUTOINC+8c9dca74b1-r0 | +-------------------------------------------+--------------------------------------------+ | linux-yocto | 6.1.25+gitAUTOINC+36901b5b29_581dc1aa2f-r0 | +-------------------------------------------+--------------------------------------------+ | u-boot | 2023.01-r0 | +-------------------------------------------+--------------------------------------------+ | optee-client | 3.18.0-r0 | +-------------------------------------------+--------------------------------------------+ | optee-os | 3.20.0-r0 | +-------------------------------------------+--------------------------------------------+ | trusted-firmware-a | 2.8.0-r0 | +-------------------------------------------+--------------------------------------------+ | trusted-firmware-m | 1.7.0-r0 | +-------------------------------------------+--------------------------------------------+ | ts-newlib | 4.1.0-r0 | +-------------------------------------------+--------------------------------------------+ | ts-psa-{crypto, iat, its. ps}-api-test | 38cb53a4d9 | +-------------------------------------------+--------------------------------------------+ | ts-sp-{se-proxy, smm-gateway} | 08b3d39471 | +-------------------------------------------+--------------------------------------------+ Yocto distribution components versions ====================================== +-------------------------------------------+--------------------------------+ | meta-arm | mickledore | +-------------------------------------------+--------------------------------+ | poky | mickledore | +-------------------------------------------+--------------------------------+ | meta-openembedded | mickledore | +-------------------------------------------+--------------------------------+ | busybox | 1.36.0-r0 | +-------------------------------------------+--------------------------------+ | musl | 1.2.3+gitAUTOINC+7d756e1c04-r0 | +-------------------------------------------+--------------------------------+ | gcc-arm-none-eabi-native | 11.2-2022.02 | +-------------------------------------------+--------------------------------+ | gcc-cross-aarch64 | 12.2.rel1-r0 | +-------------------------------------------+--------------------------------+ | openssl | 3.1.0-r0 | +-------------------------------------------+--------------------------------+ ****************** Version 2022.11.23 ****************** Changes ======= - Booting the External System (Cortex-M3) with RTX RTOS - Adding MHU communication between the HOST (Cortex-A35) and the External System - Adding a Linux application to test the External System - Adding ESRT (EFI System Resource Table) support - Upgrading the SW stack recipes - Upgrades for the U-Boot FF-A driver and MM communication Corstone-1000 components versions ================================= +-------------------------------------------+------------+ | arm-ffa-tee | 1.1.1 | +-------------------------------------------+------------+ | arm-ffa-user | 5.0.0 | +-------------------------------------------+------------+ | corstone1000-external-sys-tests | 1.0 | +-------------------------------------------+------------+ | external-system | 0.1.0 | +-------------------------------------------+------------+ | linux-yocto | 5.19 | +-------------------------------------------+------------+ | u-boot | 2022.07 | +-------------------------------------------+------------+ | optee-client | 3.18.0 | +-------------------------------------------+------------+ | optee-os | 3.18.0 | +-------------------------------------------+------------+ | trusted-firmware-a | 2.7.0 | +-------------------------------------------+------------+ | trusted-firmware-m | 1.6.0 | +-------------------------------------------+------------+ | ts-newlib | 4.1.0 | +-------------------------------------------+------------+ | ts-psa-{crypto, iat, its. ps}-api-test | 451aa087a4 | +-------------------------------------------+------------+ | ts-sp-{se-proxy, smm-gateway} | 3d4956770f | +-------------------------------------------+------------+ Yocto distribution components versions ====================================== +-------------------------------------------+---------------------+ | meta-arm | langdale | +-------------------------------------------+---------------------+ | poky | langdale | +-------------------------------------------+---------------------+ | meta-openembedded | langdale | +-------------------------------------------+---------------------+ | busybox | 1.35.0 | +-------------------------------------------+---------------------+ | musl | 1.2.3+git37e18b7bf3 | +-------------------------------------------+---------------------+ | gcc-arm-none-eabi-native | 11.2-2022.02 | +-------------------------------------------+---------------------+ | gcc-cross-aarch64 | 12.2 | +-------------------------------------------+---------------------+ | openssl | 3.0.5 | +-------------------------------------------+---------------------+ ****************** Version 2022.04.04 ****************** Changes ======= - Linux distro openSUSE, raw image installation and boot in the FVP. - SCT test support in FVP. - Manual capsule update support in FVP. ****************** Version 2022.02.25 ****************** Changes ======= - Building and running psa-arch-tests on Corstone-1000 FVP - Enabled smm-gateway partition in Trusted Service on Corstone-1000 FVP - Enabled MHU driver in Trusted Service on Corstone-1000 FVP - Enabled OpenAMP support in SE proxy SP on Corstone-1000 FVP ****************** Version 2022.02.21 ****************** Changes ======= - psa-arch-tests: recipe is dropped and merged into the secure-partitons recipe. - psa-arch-tests: The tests are align with latest tfm version for psa-crypto-api suite. ****************** Version 2022.01.18 ****************** Changes ======= - psa-arch-tests: change master to main for psa-arch-tests - U-Boot: fix null pointer exception for get_image_info - TF-M: fix capsule instability issue for Corstone-1000 ****************** Version 2022.01.07 ****************** Changes ======= - Corstone-1000: fix SystemReady-IR ACS test (SCT, FWTS) failures. - U-Boot: send bootcomplete event to secure enclave. - U-Boot: support populating Corstone-1000 image_info to ESRT table. - U-Boot: add ethernet device and enable configs to support bootfromnetwork SCT. ****************** Version 2021.12.15 ****************** Changes ======= - Enabling Corstone-1000 FPGA support on: - Linux 5.10 - OP-TEE 3.14 - Trusted Firmware-A 2.5 - Trusted Firmware-M 1.5 - Building and running psa-arch-tests - Adding openamp support in SE proxy SP - OP-TEE: adding smm-gateway partition - U-Boot: introducing Arm FF-A and MM support ****************** Version 2021.10.29 ****************** Changes ======= - Enabling Corstone-1000 FVP support on: - Linux 5.10 - OP-TEE 3.14 - Trusted Firmware-A 2.5 - Trusted Firmware-M 1.4 - Linux kernel: enabling EFI, adding FF-A debugfs driver, integrating ARM_FFA_TRANSPORT. - U-Boot: Extending EFI support - python3-imgtool: adding recipe for Trusted-firmware-m - python3-imgtool: adding the Yocto recipe used in signing host images (based on MCUBOOT format) -------------- *Copyright (c) 2022-2026, Arm Limited. All rights reserved.*
