User Guide
Notice
The Corstone-1000 software stack uses the Yocto Project to build a tiny Linux distribution suitable for the Corstone-1000 platform (kernel and initramfs filesystem less than 5 MB on the flash). The Yocto Project relies on the Bitbake tool as its build tool. Please see Yocto Project documentation for more information.
Prerequisites
These instructions assume your host PC is running Ubuntu Linux 18.04 or 20.04 LTS, with at least 32GB of free disk space and 16GB of RAM as minimum requirement. The following instructions expect that you are using a bash shell. All the paths stated in this document are absolute paths.
The following prerequisites must be available on the host system. To resolve these dependencies, run:
sudo apt-get update
sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib \
build-essential chrpath socat cpio python3 python3-pip python3-pexpect \
xz-utils debianutils iputils-ping python3-git libegl1-mesa libsdl1.2-dev \
xterm zstd liblz4-tool picocom
sudo apt-get upgrade libstdc++6
Provided components
Within the Yocto Project, each component included in the Corstone-1000 software stack is specified as
a bitbake recipe.
The recipes specific to the Corstone-1000 BSP are located at:
<_workspace>/meta-arm/meta-arm-bsp/.
The Yocto machine config files for the Corstone-1000 FVP and FPGA targets are:
<_workspace>/meta-arm/meta-arm-bsp/conf/machine/include/corstone1000.inc
<_workspace>/meta-arm/meta-arm-bsp/conf/machine/corstone1000-fvp.conf
<_workspace>/meta-arm/meta-arm-bsp/conf/machine/corstone1000-mps3.conf
Software for Host
Trusted Firmware-A
Based on Trusted Firmware-A
bbappend |
<_workspace>/meta-arm/meta-arm-bsp/recipes-bsp/trusted-firmware-a/trusted-firmware-a_2.7.bbappend |
Recipe |
<_workspace>/meta-arm/meta-arm/recipes-bsp/trusted-firmware-a/trusted-firmware-a_2.7.bb |
OP-TEE
Based on OP-TEE
bbappend |
<_workspace>/meta-arm/meta-arm-bsp/recipes-security/optee/optee-os_3.18.0.bbappend |
Recipe |
<_workspace>/meta-arm/meta-arm/recipes-security/optee/optee-os_3.18.0.bb |
U-Boot
Based on U-Boot
bbappend |
<_workspace>/meta-arm/meta-arm/recipes-bsp/u-boot/u-boot_%.bbappend |
Recipe |
<_workspace>/poky/meta/recipes-bsp/u-boot/u-boot_2022.07.bb |
Linux
The distro is based on the poky-tiny distribution which is a Linux distribution stripped down to a minimal configuration.
The provided distribution is based on busybox and built using muslibc. The recipe responsible for building a tiny version of Linux is listed below.
bbappend |
<_workspace>/meta-arm/meta-arm-bsp/recipes-kernel/linux/linux-yocto_%.bbappend |
Recipe |
<_workspace>/poky/meta/recipes-kernel/linux/linux-yocto_5.19.bb |
defconfig |
<_workspace>/meta-arm/meta-arm-bsp/recipes-kernel/linux/files/corstone1000/defconfig |
External System Tests
Based on Corstone-1000/applications
Recipe |
<_workspace>/meta-arm/meta-arm-bsp/recipes-test/corstone1000-external-sys-tests/corstone1000-external-sys-tests_1.0.bb |
The recipe provides the systems-comms-tests command run in Linux and used for testing the External System.
Software for Boot Processor (a.k.a Secure Enclave)
Based on Trusted Firmware-M
bbappend |
<_workspace>/meta-arm/meta-arm-bsp/recipes-bsp/trusted-firmware-m/trusted-firmware-m_%.bbappend |
Recipe |
<_workspace>/meta-arm/meta-arm/recipes-bsp/trusted-firmware-m/trusted-firmware-m_1.6.0.bb |
Software for the External System
RTX
Based on RTX RTOS
Recipe |
<_workspace>/meta-arm/meta-arm-bsp/recipes-bsp/external-system/external-system_0.1.0.bb |
Building the software stack
Create a new folder that will be your workspace and will henceforth be referred
to as <_workspace> in these instructions. To create the folder, run:
mkdir <_workspace>
cd <_workspace>
Corstone-1000 software is based on the Yocto Project which uses kas and bitbake commands to build the stack. To install kas tool, run:
pip3 install kas
If ‘kas’ command is not found in command-line, please make sure the user installation directories are visible on $PATH. If you have sudo rights, try ‘sudo pip3 install kas’.
In the top directory of the workspace <_workspace>, run:
git clone https://git.yoctoproject.org/git/meta-arm -b CORSTONE1000-2022.11.23
To build a Corstone-1000 image for MPS3 FPGA, run:
kas build meta-arm/kas/corstone1000-mps3.yml
Alternatively, to build a Corstone-1000 image for FVP, run:
kas build meta-arm/kas/corstone1000-fvp.yml
The initial clean build will be lengthy, given that all host utilities are to be built as well as the target images. This includes host executables (python, cmake, etc.) and the required toolchain(s).
- Once the build is successful, all output binaries will be placed in the following folders:
<_workspace>/build/tmp/deploy/images/corstone1000-fvp/folder for FVP build;<_workspace>/build/tmp/deploy/images/corstone1000-mps3/folder for FPGA build.
Everything apart from the Secure Enclave ROM firmware and External System firmware, is bundled into a single binary, the
corstone1000-image-corstone1000-{mps3,fvp}.wic.nopt file.
- The output binaries run in the Corstone-1000 platform are the following:
The Secure Enclave ROM firmware:
<_workspace>/build/tmp/deploy/images/corstone1000-{mps3,fvp}/bl1.binThe External System firmware:
<_workspace>/build/tmp/deploy/images/corstone1000-{mps3,fvp}/es_flashfw.binThe flash image:
<_workspace>/build/tmp/deploy/images/corstone1000-{mps3,fvp}/corstone1000-image-corstone1000-{mps3,fvp}.wic.nopt
Flash the firmware image on FPGA
The user should download the FPGA bit file image AN550: Arm® Corstone™-1000 for MPS3 Version 1
from this link
and under the section Arm® Corstone™-1000 for MPS3.
The directory structure of the FPGA bundle is shown below.
Boardfiles
├── MB
│ ├── BRD_LOG.TXT
│ ├── HBI0309B
│ │ ├── AN550
│ │ │ ├── AN550_v1.bit
│ │ │ ├── an550_v1.txt
│ │ │ └── images.txt
│ │ ├── board.txt
│ │ └── mbb_v210.ebf
│ └── HBI0309C
│ ├── AN550
│ │ └── images.txt
│ ├── board.txt
│ └── mbb_v210.ebf
├── SOFTWARE
│ ├── ES0.bin
│ ├── SE.bin
│ └── an550_st.axf
└── config.txt
Depending upon the MPS3 board version (printed on the MPS3 board) you should update the images.txt file (in corresponding HBI0309x folder. Boardfiles/MB/HBI0309<board_revision>/AN550/images.txt) so that the file points to the images under SOFTWARE directory.
The images.txt file that is compatible with the latest version of the software stack can be seen below;
; Preload port mapping *
; PORT 0 & ADDRESS: 0x00_0000_0000 QSPI Flash (XNVM) (32MB)
; PORT 0 & ADDRESS: 0x00_8000_0000 OCVM (DDR4 2GB)
; PORT 1 Secure Enclave (M0+) ROM (64KB)
; PORT 2 External System 0 (M3) Code RAM (256KB)
; PORT 3 Secure Enclave OTP memory (8KB)
; PORT 4 CVM (4MB)
[IMAGES]
TOTALIMAGES: 3 ;Number of Images (Max: 32)
IMAGE0PORT: 1
IMAGE0ADDRESS: 0x00_0000_0000
IMAGE0UPDATE: RAM
IMAGE0FILE: \SOFTWARE\bl1.bin
IMAGE1PORT: 0
IMAGE1ADDRESS: 0x00_0010_0000
IMAGE1UPDATE: AUTOQSPI
IMAGE1FILE: \SOFTWARE\cs1000.bin
IMAGE2PORT: 2
IMAGE2ADDRESS: 0x00_0000_0000
IMAGE2UPDATE: RAM
IMAGE2FILE: \SOFTWARE\es0.bin
OUTPUT_DIR = <_workspace>/build/tmp/deploy/images/corstone1000-mps3
Copy
bl1.binfrom OUTPUT_DIR directory to SOFTWARE directory of the FPGA bundle.Copy
es_flashfw.binfrom OUTPUT_DIR directory to SOFTWARE directory of the FPGA bundle and rename the binary toes0.bin.Copy
corstone1000-image-corstone1000-mps3.wic.noptfrom OUTPUT_DIR directory to SOFTWARE directory of the FPGA bundle and rename the wic.nopt image tocs1000.bin.
NOTE: Renaming of the images are required because MCC firmware has limitation of 8 characters before .(dot) and 3 characters after .(dot).
Now, copy the entire folder to board’s SDCard and reboot the board.
Running the software on FPGA
On the host machine, open 4 serial port terminals. In case of Linux machine it will be ttyUSB0, ttyUSB1, ttyUSB2, ttyUSB3 and it might be different on Windows machines.
ttyUSB0 for MCC, OP-TEE and Secure Partition
ttyUSB1 for Boot Processor (Cortex-M0+)
ttyUSB2 for Host Processor (Cortex-A35)
ttyUSB3 for External System Processor (Cortex-M3)
Run following commands to open serial port terminals on Linux:
sudo picocom -b 115200 /dev/ttyUSB0 # in one terminal
sudo picocom -b 115200 /dev/ttyUSB1 # in another terminal
sudo picocom -b 115200 /dev/ttyUSB2 # in another terminal.
sudo picocom -b 115200 /dev/ttyUSB3 # in another terminal.
Once the system boot is completed, you should see console logs on the serial port terminals. Once the HOST(Cortex-A35) is booted completely, user can login to the shell using “root” login.
If system does not boot and only the ttyUSB1 logs are visible, please follow the steps in Clean Secure Flash Before Testing (applicable to FPGA only) under SystemReady-IR tests section. The previous image used in FPGA (MPS3) might have filled the Secure Flash completely. The best practice is to clean the secure flash in this case.
Running the software on FVP
An FVP (Fixed Virtual Platform) model of the Corstone-1000 platform must be available to run the Corstone-1000 FVP software image.
A Yocto recipe is provided and allows to download the latest supported FVP version.
The recipe is located at <_workspace>/meta-arm/meta-arm/recipes-devtools/fvp/fvp-corstone1000.bb
The latest supported Fixed Virtual Platform (FVP) version is 11.19_21 and is automatically downloaded and installed when using the runfvp command as detailed below. The FVP version can be checked by running the following command:
<_workspace>/meta-arm/scripts/runfvp <_workspace>/build/tmp/deploy/images/corstone1000-fvp/corstone1000-image-corstone1000-fvp.fvpconf -- --version
The FVP can also be manually downloaded from the Arm Ecosystem FVPs page. On this page, navigate to “Corstone IoT FVPs” section to download the Corstone-1000 platform FVP installer. Follow the instructions of the installer and setup the FVP.
To run the FVP using the runfvp command, please run the following command:
<_workspace>/meta-arm/scripts/runfvp --terminals=xterm <_workspace>/build/tmp/deploy/images/corstone1000-fvp/corstone1000-image-corstone1000-fvp.fvpconf
When the script is executed, three terminal instances will be launched, one for the boot processor (aka Secure Enclave) processing element and two for the Host processing element. Once the FVP is executing, the Boot Processor will start to boot, wherein the relevant memory contents of the .wic.nopt file are copied to their respective memory locations within the model, enforce firewall policies on memories and peripherals and then, bring the host out of reset.
The host will boot trusted-firmware-a, OP-TEE, U-Boot and then Linux, and present a login prompt (FVP host_terminal_0):
corstone1000-fvp login:
Login using the username root.
The External System can be released out of reset on demand using the systems-comms-tests command.
Testing steps
NOTE: Running the SystemReady-IR tests described below requires the user to work with USB sticks. In our testing, not all USB stick models work well with MPS3 FPGA. Here are the USB sticks models that are stable in our test environment.
HP V165W 8 GB USB Flash Drive
SanDisk Ultra 32GB Dual USB Flash Drive USB M3.0
SanDisk Ultra 16GB Dual USB Flash Drive USB M3.0
NOTE: Before running each of the tests in this chapter, the user should follow the steps described in following section “Clean Secure Flash Before Testing” to erase the SecureEnclave flash cleanly and prepare a clean board environment for the testing.
To prepare a clean board environment with clean secure flash for the testing, the user should prepare an image that erases the secure flash cleanly during boot. Run following commands to build such image.
cd <_workspace>
git clone https://git.gitlab.arm.com/arm-reference-solutions/systemready-patch.git -b CORSTONE1000-2022.11.23
cp -f systemready-patch/embedded-a/corstone1000/erase_flash/0001-arm-bsp-trusted-firmware-m-corstone1000-Clean-Secure.patch meta-arm
cd meta-arm
git apply 0001-arm-bsp-trusted-firmware-m-corstone1000-Clean-Secure.patch
cd ..
- Replace the bl1.bin and cs1000.bin files on the SD card with following files:
The ROM firmware: <_workspace>/build/tmp/deploy/images/corstone1000-mps3/bl1.bin
The flash image: <_workspace>/build/tmp/deploy/images/corstone1000-mps3/corstone1000-image-corstone1000-mps3.wic.nopt
Now reboot the board. This step erases the Corstone-1000 SecureEnclave flash completely, the user should expect following message from TF-M log (can be seen in ttyUSB1):
!!!SECURE FLASH HAS BEEN CLEANED!!!
NOW YOU CAN FLASH THE ACTUAL CORSTONE1000 IMAGE
PLEASE REMOVE THE LATEST ERASE SECURE FLASH PATCH AND BUILD THE IMAGE AGAIN
Then the user should follow “Building the software stack” to build a clean software stack and flash the FPGA as normal. And continue the testing.
Run SystemReady-IR ACS tests
ACS image contains two partitions. BOOT partition and RESULT partition. Following packages are under BOOT partition
SCT
FWTS
BSA uefi
BSA linux
grub
uefi manual capsule application
RESULT partition is used to store the test results. PLEASE MAKE SURE THAT THE RESULT PARTITION IS EMPTY BEFORE YOU START THE TESTING. OTHERWISE THE TEST RESULTS WILL NOT BE CONSISTENT
FPGA instructions for ACS image
This section describes how the user can build and run Architecture Compliance Suite (ACS) tests on Corstone-1000.
First, the user should download the Arm SystemReady ACS repository. This repository contains the infrastructure to build the Architecture Compliance Suite (ACS) and the bootable prebuilt images to be used for the certifications of SystemReady-IR. To download the repository, run command:
cd <_workspace>
git clone https://github.com/ARM-software/arm-systemready.git -b v21.09_REL1.0
- Once the repository is successfully downloaded, the prebuilt ACS live image can be found in:
<_workspace>/arm-systemready/IR/prebuilt_images/v21.07_0.9_BETA/ir_acs_live_image.img.xz
NOTE: This prebuilt ACS image includes v5.13 kernel, which doesn’t provide USB driver support for Corstone-1000. The ACS image with newer kernel version and with full USB support for Corstone-1000 will be available in the next SystemReady release in this repository.
Then, the user should prepare a USB stick with ACS image. In the given example here,
we assume the USB device is /dev/sdb (the user should use lsblk command to
confirm). Be cautious here and don’t confuse your host PC’s own hard drive with the
USB drive. Run the following commands to prepare the ACS image in USB stick:
cd <_workspace>/arm-systemready/IR/prebuilt_images/v21.07_0.9_BETA
unxz ir_acs_live_image.img.xz
sudo dd if=ir_acs_live_image.img of=/dev/sdb iflag=direct oflag=direct bs=1M status=progress; sync
Once the USB stick with ACS image is prepared, the user should make sure that ensure that only the USB stick with the ACS image is connected to the board, and then boot the board.
The FPGA will reset multiple times during the test, and it might take approx. 24-36 hours to finish the test. At the end of test, the FPGA host terminal will halt showing a shell prompt. Once test is finished the result can be copied following above instructions.
FVP instructions for ACS image and run
- Download ACS image from:
https://gitlab.arm.com/systemready/acs/arm-systemready/-/tree/linux-5.17-rc7/IR/prebuilt_images/v22.04_1.0-Linux-v5.17-rc7
Use the below command to run the FVP with ACS image support in the SD card.
unxz ${<path-to-img>/ir_acs_live_image.img.xz}
tmux
<_workspace>/meta-arm/scripts/runfvp <_workspace>/build/tmp/deploy/images/corstone1000-fvp/corstone1000-image-corstone1000-fvp.fvpconf -- -C board.msd_mmc.p_mmc_file="${<path-to-img>/ir_acs_live_image.img}"
The test results can be fetched using following commands:
sudo mkdir /mnt/test
sudo mount -o rw,offset=<offset_2nd_partition> <path-to-img>/ir_acs_live_image.img /mnt/test/
fdisk -lu <path-to-img>/ir_acs_live_image.img
-> Device Start End Sectors Size Type
<path-to-img>/ir_acs_live_image_modified.img1 2048 1050622 1048575 512M Microsoft basic data
<path-to-img>/ir_acs_live_image_modified.img2 1050624 1153022 102399 50M Microsoft basic data
-> <offset_2nd_partition> = 1050624 * 512 (sector size) = 537919488
The FVP will reset multiple times during the test, and it might take up to 1 day to finish the test. At the end of test, the FVP host terminal will halt showing a shell prompt. Once test is finished, the FVP can be stoped, and result can be copied following above instructions.
Common to FVP and FPGA
U-Boot should be able to boot the grub bootloader from the 1st partition and if grub is not interrupted, tests are executed automatically in the following sequence:
SCT
UEFI BSA
FWTS
BSA Linux
The results can be fetched from the acs_results folder in the RESULT partition of the USB stick (FPGA) / SD Card (FVP).
Manual capsule update and ESRT checks
The following section describes running manual capsule update with the direct method.
The steps described in this section perform manual capsule update and show how to use the ESRT feature to retrieve the installed capsule details.
For the following tests two capsules are needed to perform 2 capsule updates. A positive update and a negative update.
A positive test case capsule which boots the platform correctly until the Linux prompt, and a negative test case with an incorrect capsule (corrupted or outdated) which fails to boot to the host software.
- Check the “Run SystemReady-IR ACS tests” section above to download and unpack the ACS image file
Download edk2 under <_workspace> :
git clone https://github.com/tianocore/edk2.git
Generating Capsules
The capsule binary size (wic.nopt file) should be less than 15 MB.
Based on the user’s requirement, the user can change the firmware version
number given to --fw-version option (the version number needs to be >= 1).
Generating FPGA Capsules
<_workspace>/edk2/BaseTools/BinWrappers/PosixLike/GenerateCapsule -e -o \
cs1k_cap_mps3_v5 --fw-version 5 --lsv 0 --guid \
e2bb9c06-70e9-4b14-97a3-5a7913176e3f --verbose --update-image-index \
0 --verbose <_workspace>/build/tmp/deploy/images/corstone1000-mps3/corstone1000-image-corstone1000-mps3.wic.nopt
cs1k_cap_mps3_v6 --fw-version 6 --lsv 0 --guid \
Generating FVP Capsules
cs1k_cap_fvp_v6 --fw-version 6 --lsv 0 --guid \
0 --verbose <_workspace>/build/tmp/deploy/images/corstone1000-fvp/corstone1000-image-corstone1000-fvp.wic.nopt
cs1k_cap_fvp_v5 --fw-version 5 --lsv 0 --guid \
Copying Capsules
Copying the FPGA capsules
The user should prepare a USB stick as explained in ACS image section (see above).
Place the generated cs1k_cap files in the root directory of the boot partition
in the USB stick. Note: As we are running the direct method, the cs1k_cap file
should not be under the EFI/UpdateCapsule directory as this may or may not trigger
the on disk method.
sudo cp cs1k_cap_mps3_v6 <mounting path>/BOOT/
sudo cp cs1k_cap_mps3_v5 <mounting path>/BOOT/
sync
Copying the FVP capsules
First, mount the IR image:
sudo mount -o rw,offset=1048576 <path-to-img>/ir_acs_live_image.img /mnt/test
Then, copy the capsules:
sudo cp cs1k_cap_fvp_v6 /mnt/test/
sudo cp cs1k_cap_fvp_v5 /mnt/test/
sync
Then, unmount the IR image:
sudo umount /mnt/test
NOTE:
Size of first partition in the image file is calculated in the following way. The data is just an example and might vary with different ir_acs_live_image.img files.
-> <offset_1st_partition> = 2048 * 512 (sector size) = 1048576
Performing the capsule update
During this section we will be using the capsule with the higher version (cs1k_cap_<fvp/mps3>_v6) for the positive scenario and the capsule with the lower version (cs1k_cap_<fvp/mps3>_v5) for the negative scenario.
Running the FVP with the IR prebuilt image
Run the FVP with the IR prebuilt image:
<_workspace>/meta-arm/scripts/runfvp --terminals=xterm <_workspace>/build/tmp/deploy/images/corstone1000-fvp/corstone1000-image-corstone1000-fvp.fvpconf -- -C "board.msd_mmc.p_mmc_file ${<path-to-img>/ir_acs_live_image.img}"
Running the FPGA with the IR prebuilt image
Insert the prepared USB stick then Power cycle the MPS3 board.
Executing capsule update for FVP and FPGA
Reach u-boot then interrupt the boot to reach the EFI shell.
Press ESC in 4 seconds to skip startup.nsh or any other key to continue.
Then, type FS0: as shown below:
FS0:
In case of the positive scenario run the update with the higher version capsule as shown below:
EFI/BOOT/app/CapsuleApp.efi cs1k_cap_<fvp/mps3>_v6
After successfully updating the capsule the system will reset.
In case of the negative scenario run the update with the lower version capsule as shown below:
EFI/BOOT/app/CapsuleApp.efi cs1k_cap_<fvp/mps3>_v5
The command above should fail and in the TF-M logs the following message should appear:
ERROR: flash_full_capsule: version error
Then, reboot manually:
Shell> reset
FPGA: Select Corstone-1000 Linux kernel boot
Remove the USB stick before u-boot is reached so the Corstone-1000 kernel will be detected and used for booting.
NOTE: Otherwise, the execution ends up in the ACS live image.
FVP: Select Corstone-1000 Linux kernel boot
Interrupt the u-boot shell.
Hit any key to stop autoboot:
Run the following commands in order to run the Corstone-1000 Linux kernel and being able to check the ESRT table.
$ run retrieve_kernel_load_addr
$ unzip $kernel_addr 0x90000000
$ loadm 0x90000000 $kernel_addr_r 0xf00000
$ bootefi $kernel_addr_r $fdtcontroladdr
Capsule update status
Positive scenario
In the positive case scenario, the user should see following log in TF-M log, indicating the new capsule image is successfully applied, and the board boots correctly.
SysTick_Handler: counted = 10, expiring on = 360
SysTick_Handler: counted = 20, expiring on = 360
SysTick_Handler: counted = 30, expiring on = 360
metadata_write: success: active = 1, previous = 0
accept_full_capsule: exit: fwu state is changed to regular
It’s possible to check the content of the ESRT table after the system fully boots.
In the Linux command-line run the following:
# cd /sys/firmware/efi/esrt/entries/entry0
# cat *
0x0
0
6
0
6
0
Negative scenario
In the negative case scenario (rollback the capsule version), the user should see appropriate logs in the secure enclave terminal.
uefi_capsule_retrieve_images: image 0 at 0xa0000070, size=15654928
uefi_capsule_retrieve_images: exit
flash_full_capsule: enter: image = 0x0xa0000070, size = 15654928, version = 10
private_metadata_write: enter: boot_index = 1
private_metadata_write: success
fmp_set_image_info:133 Enter
FMP image update: image id = 0
FMP image update: status = 1version=11 last_attempt_version=10.
fmp_set_image_info:157 Exit.
corstone1000_fwu_flash_image: exit: ret = -1
If capsule pass initial verification, but fails verifications performed during boot time, secure enclave will try new images predetermined number of times (defined in the code), before reverting back to the previous good bank.
metadata_write: success: active = 0, previous = 1
fwu_select_previous: in regular state by choosing previous active bank
# cat *
0x0
0
6
1
5
0
Linux distros tests
Debian/OpenSUSE install and boot (applicable to FPGA only)
To test Linux distro install and boot, the user should prepare two empty USB sticks (minimum size should be 4GB and formatted with FAT32).
- Download one of following Linux distro images:
Debian installer image: https://cdimage.debian.org/cdimage/weekly-builds/arm64/iso-dvd/
OpenSUSE Tumbleweed installer image: http://download.opensuse.org/ports/aarch64/tumbleweed/iso/ - The user should look for a DVD Snapshot like openSUSE-Tumbleweed-DVD-aarch64-Snapshot<date>-Media.iso
Once the .iso file is downloaded, the .iso file needs to be flashed to your USB drive.
In the given example here, we assume the USB device is /dev/sdb (the user
should use lsblk command to confirm). Be cautious here and don’t confuse your
host PC’s own hard drive with the USB drive. Then copy the contents of an iso
file into the first USB stick, run:
sudo dd if=<path-to-iso_file> of=/dev/sdb iflag=direct oflag=direct status=progress bs=1M; sync;
Boot the MSP3 board with the first USB stick connected. Open following minicom sessions:
Now plug in the second USB stick (once installation screen is visible), the distro installation process will start. The installation prompt can be seen in ttyUSB2. If installer does not start, please try to reboot the board with both USB sticks connected and repeat the process.
NOTE: Due to the performance limitation of Corstone-1000 MPS3 FPGA, the distro installation process can take up to 24 hours to complete.
Once installation is complete, unplug the first USB stick and reboot the board. After successfully installing and booting the Linux distro, the user should see a login prompt:
debian login:
Login with the username root.
NOTE: The Debian installer has a known issue “Install the GRUB bootloader - unable to install ” and these are the steps to follow on the subsequent popups to solve the issue during the installation:
Select “Continue”, then “Continue” again on the next popup
Scroll down and select “Execute a shell”
Select “Continue”
Enter the following command:
in-target grub-install --no-nvram --force-extra-removable
in-target update-grub
exit
Select “Continue without boot loader”, then select “Continue” on the next popup
At this stage, the installation should proceed as normal.
OpenSUSE Raw image install and boot (applicable to FVP only)
- Steps to download openSUSE Tumbleweed raw image:
Go to: http://download.opensuse.org/ports/aarch64/tumbleweed/appliances/
The user should look for a Tumbleweed-ARM-JeOS-efi.aarch64-* Snapshot, for example,
openSUSE-Tumbleweed-ARM-JeOS-efi.aarch64-<date>-Snapshot<date>.raw.xz
Once the .raw.xz file is downloaded, the raw image file needs to be extracted:
unxz <file-name.raw.xz>
The above command will generate a file ending with extension .raw image. Now, use the following command to run FVP with raw image installation process.
<_workspace>/meta-arm/scripts/runfvp --terminals=xterm <_workspace>/build/tmp/deploy/images/corstone1000-fvp/corstone1000-image-corstone1000-fvp.fvpconf -- -C board.msd_mmc.p_mmc_file="${openSUSE raw image file path}"
After successfully installing and booting the Linux distro, the user should see a openSUSE login prompt.
localhost login:
Login with the username ‘root’ and password ‘linux’.
PSA API tests
Run PSA API test commands (applicable to both FPGA and FVP)
When running PSA API test commands (aka PSA Arch Tests) on MPS3 FPGA, the user should make sure there is no USB stick connected to the board. Power on the board and boot the board to Linux. Then, the user should follow the steps below to run the tests.
When running the tests on the Corstone-1000 FVP, the user should follow the
instructions in Running the software on FVP section to boot Linux in FVP
host_terminal_0, and login using the username root.
First, load FF-A TEE kernel module:
insmod /lib/modules/5.19.14-yocto-standard/extra/arm-ffa-tee.ko
Then, check whether the FF-A TEE driver is loaded correctly by using the following command:
cat /proc/modules | grep arm_ffa_tee
The output should be:
arm_ffa_tee 16384 - - Live 0xffffffc0004f0000 (O)
Now, run the PSA API tests in the following order:
psa-iat-api-test
psa-crypto-api-test
psa-its-api-test
psa-ps-api-test
External System tests
Running the External System test command (systems-comms-tests)
Test 1: Releasing the External System out of reset
Run this command in the Linux command-line:
systems-comms-tests 1
The output on the External System terminal should be:
___ ___
| / __|
|=== \___
|___ |___/
External System Cortex-M3 Processor
Running RTX RTOS
v0.1.0_2022-10-19_16-41-32-8c9dca7
MHUv2 module 'MHU0_H' started
MHUv2 module 'MHU1_H' started
MHUv2 module 'MHU0_SE' started
MHUv2 module 'MHU1_SE' started
Test 2: Communication
Test 2 releases the External System out of reset if not already done. Then, it performs communication between host and External System.
After running Test 1, run this command in the Linux command-line:
systems-comms-tests 2
Additional output on the External System terminal will be printed:
MHUv2: Message from 'MHU0_H': 0xabcdef1
Received 'abcdef1' From Host MHU0
CMD: Increment and return to sender...
MHUv2: Message from 'MHU1_H': 0xabcdef1
Received 'abcdef1' From Host MHU1
When running Test 2 the first, Test 1 will be run in the background.
___ ___
| / __|
|=== \___
|___ |___/
Running RTX RTOS
The output on the Host terminal should be:
Received abcdf00 from es0mhu0
Received abcdf00 from es0mhu1
Tests results
As a reference for the end user, reports for various tests for Corstone-1000 software (CORSTONE1000-2022.11.23) can be found in here.
Running the software on FVP on Windows
If the user needs to run the Corstone-1000 software on FVP on Windows. The user should follow the build instructions in this document to build on Linux host PC, and copy the output binaries to the Windows PC where the FVP is located, and launch the FVP binary.
Copyright (c) 2022, Arm Limited. All rights reserved.
