Release notes
Disclaimer
You expressly assume all liabilities and risks relating to your use or operation of Your Software and Your Hardware designed or modified using the Arm Tools, including without limitation, Your software or Your Hardware designed or intended for safety-critical applications. Should Your Software or Your Hardware prove defective, you assume the entire cost of all necessary servicing, repair or correction.
Release notes - 2022.11.23
Known Issues or Limitations
The external-system can not be reset individually on (or using) AN550_v1 FPGA release. However, the system-wide reset still applies to the external-system.
FPGA supports Linux distro install and boot through installer. However, FVP only supports openSUSE raw image installation and boot.
Due to the performance uplimit of MPS3 FPGA and FVP, some Linux distros like Fedora Rawhide can not boot on Corstone-1000 (i.e. user may experience timeouts or boot hang).
Below SCT FAILURE is a known issues in the FVP: UEFI Compliant - Boot from network protocols must be implemented – FAILURE
Below SCT FAILURE is a known issue when a terminal emulator (in the system where the user connects to serial ports) does not support 80x25 or 80x50 mode: EFI_SIMPLE_TEXT_OUT_PROTOCOL.SetMode - SetMode() with valid mode – FAILURE
Known limitations regarding ACS tests: The behavior after running ACS tests on FVP is not consistent. Both behaviors are expected and are valid; The system might boot till the Linux prompt. Or, the system might wait after finishing the ACS tests. In both cases, the system executes the entire test suite and writes the results as stated in the user guide.
Platform Support
This software release is tested on Corstone-1000 FPGA version AN550_v1 https://developer.arm.com/downloads/-/download-fpga-images
This software release is tested on Corstone-1000 Fast Model platform (FVP) version 11.19_21 https://developer.arm.com/tools-and-software/open-source-software/arm-platforms-software/arm-ecosystem-fvps
Release notes - 2022.04.04
FPGA support Linux distro install and boot through installer. However, FVP only support openSUSE raw image installation and boot.
Due to the performance uplimit of MPS3 FPGA and FVP, some Linux distros like Fedora Rawhide cannot boot on Corstone-1000 (i.e. user may experience timeouts or boot hang).
Platform Support
This software release is tested on Corstone-1000 Fast Model platform (FVP) version 11.17_23 https://developer.arm.com/tools-and-software/open-source-software/arm-platforms-software/arm-ecosystem-fvps
Release notes - 2022.02.25
The following tests only work on Corstone-1000 FPGA: ACS tests (SCT, FWTS, BSA), manual capsule update test, Linux distro install and boot.
Platform Support
Release notes - 2022.02.21
The following tests only work on Corstone-1000 FPGA: ACS tests (SCT, FWTS, BSA), manual capsule update test, Linux distro install and boot, psa-arch-test.
Platform Support
This software release is tested on Corstone-1000 Fast Model platform (FVP) version 11.16.21 https://developer.arm.com/tools-and-software/open-source-software/arm-platforms-software/arm-ecosystem-fvps
Release notes - 2022.01.18
Before running each SystemReady-IR tests: ACS tests (SCT, FWTS, BSA), manual capsule update test, Linux distro install and boot, etc., the SecureEnclave flash must be cleaned. See user-guide “Clean Secure Flash Before Testing” section.
Release notes - 2021.12.15
Software Features
The following components are present in the release:
Yocto version Honister
Linux kernel version 5.10
U-Boot 2021.07
OP-TEE version 3.14
Trusted Firmware-A 2.5
Trusted Firmware-M 1.5
OpenAMP 347397decaa43372fc4d00f965640ebde042966d
Trusted Services a365a04f937b9b76ebb2e0eeade226f208cbc0d2
Platform Support
The following tests only work on Corstone-1000 FPGA: ACS tests (SCT, FWTS, BSA), manual capsule update test, Linux distro install and boot, and psa-arch-tests.
Only the manual capsule update from UEFI shell is supported on FPGA.
Due to flash size limitation and to support A/B banks,the wic image provided by the user should be smaller than 15MB.
The failures in PSA Arch Crypto Test are known limitations with crypto library. It requires further investigation. The user can refer to PSA Arch Crypto Test Failure Analysis In TF-M V1.5 Release for the reason for each failing test.
Release notes - 2021.10.29
Software Features
This initial release of Corstone-1000 supports booting Linux on the Cortex-A35 and TF-M/MCUBOOT in the Secure Enclave. The following components are present in the release:
U-Boot 2021.07
OP-TEE version 3.14
Trusted Firmware-M 1.4
Platform Support
This Software release is tested on Corstone-1000 Fast Model platform (FVP) version 11.16.21 https://developer.arm.com/tools-and-software/open-source-software/arm-platforms-software/arm-ecosystem-fvps
No software support for external system(Cortex M3)
No communication established between A35 and M0+
Very basic functionality of booting Secure Enclave, Trusted Firmware-A , OP-TEE , u-boot and Linux are performed
Support
For technical support email: support-subsystem-iot@arm.com
For all security issues, contact Arm by email at arm-security@arm.com.
Copyright (c) 2022, Arm Limited. All rights reserved.
