Change Log
This document contains a summary of the new features, changes and fixes in each release of Corstone-1000 software stack.
Version 2022.11.23
Changes
  • Booting the External System (Cortex-M3) with RTX RTOS
  • Adding MHU communication between the HOST (Cortex-A35) and the External System
  • Adding a Linux application to test the External System
  • Adding ESRT (EFI System Resource Table) support
  • Upgrading the SW stack recipes
  • Upgrades for the U-Boot FF-A driver and MM communication
Corstone-1000 components versions
arm-ffa-tee
1.1.1
arm-ffa-user
5.0.0
corstone1000-external-sys-tests
1.0
external-system
0.1.0
linux-yocto
5.19
u-boot
2022.07
optee-client
3.18.0
optee-os
3.18.0
trusted-firmware-a
2.7.0
trusted-firmware-m
1.6.0
ts-newlib
4.1.0
ts-psa-{crypto, iat, its. ps}-api-test
451aa087a4
ts-sp-{se-proxy, smm-gateway}
3d4956770f
Yocto distribution components versions
meta-arm
langdale
poky
langdale
meta-openembedded
langdale
busybox
1.35.0
musl
1.2.3+git37e18b7bf3
gcc-arm-none-eabi-native
11.2-2022.02
gcc-cross-aarch64
12.2
openssl
3.0.5
Version 2022.04.04
Changes
  • Linux distro openSUSE, raw image installation and boot in the FVP.
  • SCT test support in FVP.
  • Manual capsule update support in FVP.
Version 2022.02.25
Changes
  • Building and running psa-arch-tests on Corstone-1000 FVP
  • Enabled smm-gateway partition in Trusted Service on Corstone-1000 FVP
  • Enabled MHU driver in Trusted Service on Corstone-1000 FVP
  • Enabled OpenAMP support in SE proxy SP on Corstone-1000 FVP
Version 2022.02.21
Changes
  • psa-arch-tests: recipe is dropped and merged into the secure-partitons recipe.
  • psa-arch-tests: The tests are align with latest tfm version for psa-crypto-api suite.
Version 2022.01.18
Changes
  • psa-arch-tests: change master to main for psa-arch-tests
  • U-Boot: fix null pointer exception for get_image_info
  • TF-M: fix capsule instability issue for Corstone-1000
Version 2022.01.07
Changes
  • Corstone-1000: fix SystemReady-IR ACS test (SCT, FWTS) failures.
  • U-Boot: send bootcomplete event to secure enclave.
  • U-Boot: support populating Corstone-1000 image_info to ESRT table.
  • U-Boot: add ethernet device and enable configs to support bootfromnetwork SCT.
Version 2021.12.15
Changes
  • Enabling Corstone-1000 FPGA support on: - Linux 5.10 - OP-TEE 3.14 - Trusted Firmware-A 2.5 - Trusted Firmware-M 1.5
  • Adding openamp support in SE proxy SP
  • OP-TEE: adding smm-gateway partition
  • U-Boot: introducing Arm FF-A and MM support
Version 2021.10.29
Changes
  • Enabling Corstone-1000 FVP support on: - Linux 5.10 - OP-TEE 3.14 - Trusted Firmware-A 2.5 - Trusted Firmware-M 1.4
  • Linux kernel: enabling EFI, adding FF-A debugfs driver, integrating ARM_FFA_TRANSPORT.
  • U-Boot: Extending EFI support
  • python3-imgtool: adding recipe for Trusted-firmware-m
  • python3-imgtool: adding the Yocto recipe used in signing host images (based on MCUBOOT format)
Copyright (c) 2022, Arm Limited. All rights reserved.
