Build, Flash and Run
Notice
The Corstone-1000 software stack uses the Yocto Project to build a tiny Linux distribution suitable for the Corstone-1000 platform (kernel and initramfs filesystem less than 5 MB on the flash). The Yocto Project relies on the BitBake tool as its build tool. Please see Yocto Project documentation for more information.
Prerequisites
This guide assumes that your host machine is running Ubuntu 20.04 LTS ( with sudo rights), with at least 32GB of free disk space and 16GB of RAM as minimum requirement.
The following prerequisites must be available on the host system:
  • Git 1.8.3.1 or greater.
  • Python 3.8.0 or greater.
  • GNU Tar 1.28 or greater.
  • GNU Compiler Collection 8.0 or greater.
  • GNU Make 4.0 or greater.
  • tmux.
Please follow the steps described in the Yocto mega manual:
Targets
The Corstone-1000 software stack can be run on:
Yocto Stable Branch
Corstone-1000 software stack is built on top of Yocto Project’s Whinlatter release.
Software Components
Within the Yocto Project, each component included in the Corstone-1000 software stack is specified as a BitBake recipe. The recipes specific to the Corstone-1000 BSP are located at: ${WORKSPACE}/meta-arm/meta-arm-bsp/.
Important
${WORKSPACE} refers to the absolute path to your workspace where the meta-arm repository will be cloned.
Consider exporting it (e.g., export WORKSPACE=$(realpath .)) if you’re already in the workspace directory, so you can copy and paste the commands from this guide verbatim.
Important
${TARGET} is either mps3 or fvp.
Consider exporting it (e.g., export TARGET=mps3) so you can copy and paste the commands from this guide verbatim.
The Yocto machine config files for the Corstone-1000 FVP and MPS3 targets are:
  • ${WORKSPACE}/meta-arm/meta-arm-bsp/conf/machine/include/corstone1000.inc
  • ${WORKSPACE}/meta-arm/meta-arm-bsp/conf/machine/corstone1000-${TARGET}.conf
Note
All the paths stated in this document are absolute paths.
Host Processor Components
Trusted Firmware-A
bbappend
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-bsp/trusted-firmware-a/trusted-firmware-a_%.bbappend
Recipe
${WORKSPACE}/meta-arm/meta-arm/recipes-bsp/trusted-firmware-a/trusted-firmware-a_2.13.0.bb
Trusted Services
bbappend
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/trusted-services/libts_%.bbappend
bbappend
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/trusted-services/ts-psa-crypto-api-test_%.bbappend
bbappend
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/trusted-services/ts-psa-iat-api-test_%.bbappend
bbappend
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/trusted-services/ts-psa-its-api-test_%.bbappend
bbappend
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/trusted-services/ts-psa-ps-api-test_%.bbappend
bbappend
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/trusted-services/ts-sp-se-proxy_%.bbappend
bbappend
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/trusted-services/ts-sp-smm-gateway_%.bbappend
Recipe
${WORKSPACE}/meta-arm/meta-arm/recipes-security/trusted-services/libts_git.bb
Recipe
${WORKSPACE}/meta-arm/meta-arm/recipes-security/trusted-services/ts-psa-crypto-api-test_git.bb
Recipe
${WORKSPACE}/meta-arm/meta-arm/recipes-security/trusted-services/ts-psa-iat-api-test_git.bb
Recipe
${WORKSPACE}/meta-arm/meta-arm/recipes-security/trusted-services/ts-psa-its-api-test_git.bb
Recipe
${WORKSPACE}/meta-arm/meta-arm/recipes-security/trusted-services/ts-psa-ps-api-test_git.bb
Recipe
${WORKSPACE}/meta-arm/meta-arm/recipes-security/trusted-services/ts-sp-smm-gateway_git.bb
Recipe
${WORKSPACE}/meta-arm/meta-arm/recipes-security/trusted-services/ts-sp-se-proxy_git.bb
OP-TEE
bbappend
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/optee/optee-os_4.%.bbappend
Recipe
${WORKSPACE}/meta-arm/meta-arm/recipes-security/optee/optee-os_4.7.0.bb
U-Boot
bbappend
${WORKSPACE}/meta-arm/meta-arm/recipes-bsp/u-boot/u-boot_%.bbappend
bbappend
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-bsp/u-boot/u-boot_%.bbappend
Recipe
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-bsp/u-boot/u-boot_2025.04.bb
Linux
The distribution is based on the Poky distribution which is a Linux distribution stripped down to a minimal configuration.
The provided distribution is based on BusyBox and built using musl libc.
bbappend
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-kernel/linux/linux-yocto_%.bbappend
Recipe
${WORKSPACE}/core/meta/recipes-kernel/linux/linux-yocto_6.12.bb
defconfig
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-kernel/linux/files/corstone1000/defconfig
Secure Enclave Components
Trusted Firmware-M
bbappend
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-bsp/trusted-firmware-m/trusted-firmware-m_%.bbappend
Recipe
${WORKSPACE}/meta-arm/meta-arm/recipes-bsp/trusted-firmware-m/trusted-firmware-m_2.2.1.bb
External System Processor Components
RTX Real-Time operating system
An example application that uses the RTX Real-Time Operating System.
The application project can be found here.
Recipe
${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-bsp/external-system/external-system_0.1.0.bb
Build
Warning
Building binaries natively on Windows and AArch64 Linux is not supported.
Use an Intel or AMD 64-bit architecture Linux based development machine to build the software stack and transfer the binaries to run the software stack on an FVP in Windows or AArch64 Linux if required.
  1. Create a new folder that will be your workspace.
    mkdir ${WORKSPACE}
    cd ${WORKSPACE}
  2. Install kas version 4.4 with sudo rights.
    sudo pip3 install kas==4.4
    Ensure the kas installation directory is visible on the $PATH environment variable.
  3. Clone the meta-arm Yocto layer in the workspace ${WORKSPACE}.
    cd ${WORKSPACE}
    git clone https://git.yoctoproject.org/git/meta-arm -b CORSTONE1000-2025.12
  4. Build a Corstone-1000 image:
    kas build meta-arm/kas/corstone1000-${TARGET}.yml:meta-arm/ci/debug.yml
    Important
    Accept the EULA at https://developer.arm.com/downloads/-/arm-ecosystem-fvps/eula to build a Corstone-1000 image for FVP as follows:
    export ARM_FVP_EULA_ACCEPT="True"
    Warning
    The External System Processor is not available on the Corstone-1000 with Cortex-A320 FVP.
    Access to the External System Processor is disabled by default on Corstone-1000 with Cortex-A35.
    To build the Corstone-1000 image with External System Processor enabled, run:
    kas build meta-arm/kas/corstone1000-${TARGET}.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-extsys.yml
    Warning
    The Ethos-U85 Neural Processing Unit (NPU) is only available on the Corstone-1000 with Cortex-A320 FVP.
    To build the Corstone-1000 image with the Ethos-U85 NPU enabled, run:
    kas build meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-a320.yml
A clean build takes a significant amount of time given that all of the development machine utilities are also built along with the target images. Those development machine utilities include executables (Python, CMake, etc.) and the required toolchains.
Once the build succeeds, all output binaries will be placed in ${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/
Everything apart from the Secure Enclave ROM firmware and External System firmware, is bundled into a single binary, the corstone1000-flash-firmware-image-corstone1000-${TARGET}.wic file.
The output binaries run in the Corstone-1000 platform are the following:
  • The Secure Enclave ROM firmware: ${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/bl1.bin
  • The External System Processor firmware: ${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/es_flashfw.bin
  • The internal firmware flash image: ${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000-flash-firmware-image-corstone1000-${TARGET}.wic
Flash
Note
The steps below only apply to the MPS3. The FVP being a software application running on your development machine does not require any firmware flashing. Refer to this section for running the software stack on FVP.
Important
When preparing the SD card for flashing, ensure that it is at least 4GB in size and formatted with a FAT32 partition. Using smaller cards or unsupported file systems (e.g., exFAT, NTFS) may cause the flashing process to fail or the device to become unresponsive.
  1. Download the FPGA bit file image AN550: Arm® Corstone™-1000 for MPS3 Version 2.0 on the Arm Developer website. Click on the Download AN550 bundle button and login to download the file.
    The directory structure of the FPGA bundle is as shown below:
    Boardfiles
    ├── config.txt
    ├── MB
    │   ├── BRD_LOG.TXT
    │   ├── HBI0309B
    │   │   ├── AN550
    │   │   │   ├── AN550_v2.bit
    │   │   │   ├── an550_v2.txt
    │   │   │   └── images.txt
    │   │   ├── board.txt
    │   │   └── mbb_v210.ebf
    │   └── HBI0309C
    │       ├── AN550
    │       │   └── images.txt
    │       ├── board.txt
    │       └── mbb_v210.ebf
    └── SOFTWARE
            ├── an550_st.axf
            ├── bl1.bin
            ├── cs1000.bin
            └── ES0.bin
  2. Depending upon the MPS3 board version, you should update the images.txt file (found in the corresponding HBI0309x folder e.g. Boardfiles/MB/HBI0309${BOARD_VERSION}/AN550/images.txt) so it points to the images under the SOFTWARE directory. Where ${BOARD_VERSION} is a variable containing the board printed on the MPS3 board.
    The images.txt file compatible with the latest version of the software stack can be seen below;
    ;       Preload port mapping                    *
    ;  PORT 0 & ADDRESS: 0x00_0000_0000 QSPI Flash (XNVM) (32MB)
    ;  PORT 0 & ADDRESS: 0x00_8000_0000 OCVM (DDR4 2GB)
    ;  PORT 1        Secure Enclave (M0+) ROM (64KB)
    ;  PORT 2        External System 0 (M3) Code RAM (256KB)
    ;  PORT 3        Secure Enclave OTP memory (8KB)
    ;  PORT 4        CVM (4MB)
    [IMAGES]
    TOTALIMAGES: 3      ;Number of Images (Max: 32)
    IMAGE0PORT: 1
    IMAGE0ADDRESS: 0x00_0000_0000
    IMAGE0UPDATE: RAM
    IMAGE0FILE: \SOFTWARE\bl1.bin
    IMAGE1PORT: 0
    IMAGE1ADDRESS: 0x00_0000_0000
    IMAGE1UPDATE: AUTOQSPI
    IMAGE1FILE: \SOFTWARE\cs1000.bin
    IMAGE2PORT: 2
    IMAGE2ADDRESS: 0x00_0000_0000
    IMAGE2UPDATE: RAM
    IMAGE2FILE: \SOFTWARE\es0.bin
  3. Copy bl1.bin from ${WORKSPACE}/build/tmp/deploy/images/corstone1000-mps3 to the SOFTWARE directory of the FPGA bundle.
  4. Copy es_flashfw.bin from ${WORKSPACE}/build/tmp/deploy/images/corstone1000-mps3 to the SOFTWARE directory of the FPGA bundle and rename the binary to es0.bin.
  5. Copy corstone1000-flash-firmware-image-corstone1000-mps3.wic from ${WORKSPACE}/build/tmp/deploy/images/corstone1000-mps3 to the SOFTWARE directory of the FPGA bundle and rename the wic image to cs1000.bin.
Note
Renaming of the images is required because the MCC firmware has a limit of 8 characters for file name and 3 characters for file extension.
After making all modifications above, copy the FPGA bit file bundle to the board’s SDCard and reboot the MPS3.
Run
Once the target is turned ON, the Secure Enclave will start to boot, wherein the relevant memory contents of the *.wic file are copied to their respective memory locations. Firewall policies are enforced on memories and peripherals before bringing the Host Processor out of reset.
The Host Processor will boot TrustedFirmware-A, OP-TEE, U-Boot and then Linux before presenting a login prompt.
MPS3
  1. Open 4 serial port comms terminals on the host machine. Those might be ttyUSB0, ttyUSB1, ttyUSB2, and ttyUSB3 on Linux machines.
  • ttyUSB0 for MCC, OP-TEE and Secure Partition
  • ttyUSB1 for Secure Enclave (Cortex-M0+)
  • ttyUSB2 for Host Processor (Cortex-A35)
  • ttyUSB3 for External System Processor (Cortex-M3)
    The serial ports might be different on Windows machines.
    Run the following commands in separate terminal instances on Linux:
    sudo picocom -b 115200 /dev/ttyUSB0
    sudo picocom -b 115200 /dev/ttyUSB1
    sudo picocom -b 115200 /dev/ttyUSB2
    sudo picocom -b 115200 /dev/ttyUSB3
    Important
    Plug a connected Ethernet cable to the MPS3 or it will wait for a network connection for a considerable amount of time, printing the following on the Host Processor terminal (ttyUSB2):
    Generic PHY 40100000.ethernet-ffffffff:01: attached PHY driver (mii_bus:phy_addr=40100000.ethernet-ffffffff:01, irq=POLL)
    smsc911x 40100000.ethernet eth0: SMSC911x/921x identified at 0xffffffc008e50000, IRQ: 17
    Waiting up to 100 more seconds for network.
  1. Once the system boot is completed, you should see console logs on the serial port terminals. Once the Host Processor is booted completely, user can login to the shell using root login.
    Important
    The secure flash might be completely filled if the system does not boot and only the Secure Enclave logs (ttyUSB1) are visible.
    Clean the secure flash if that is the case following the steps here.
FVP
A Fixed Virtual Platform (FVP) model of the Corstone-1000 platform must be available to run the Corstone-1000 FVP software image.
A Yocto recipe is provided to download the latest supported FVP version.
The recipe is located at ${WORKSPACE}/meta-arm/meta-arm/recipes-devtools/fvp/fvp-corstone1000.bb. This recipe supports selecting different Corstone‑1000 FVP models via MACHINE_FEATURES:
  • cortexa320 use the Cortex-A320 Host Processor with Ethos U85 enabled FVP build
  • (default) use the Cortex-A35 Host Processor with Cortex-M3 External System FVP build
The latest FVP version is 11.23.25 for Corstone-1000 with Cortex-A35 and 11.30.27 for Corstone-1000 with Cortex-A320, and each model is automatically downloaded and installed when using the runfvp command as detailed below.
Note
kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml \
-c "../meta-arm/scripts/runfvp -- --version"
The FVP can also be manually downloaded from Arm Developer to download the Corstone-1000 platform FVP installer. Follow the instructions of the installer to setup the FVP.
  1. Run tmux:
    cd ${WORKSPACE} && tmux
  2. Run the FVP within tmux:
    -c "../meta-arm/scripts/runfvp --terminals=tmux"
    When the script is executed, three terminal instances will be launched:
    • one for the Secure Enclave processing element
    • two for the Host processor processing element.
    corstone1000-fvp login:
  3. Login using the root username.
Security Issue Reporting
To report any security issues identified with Corstone-1000, please send an email to psirt@arm.com.
Tests
Important
All the tests below assume you have already built the software stack at least once following the instructions here.
Reports
Reports for the tests conducted on the Corstone-1000 software (CORSTONE1000-2025.12) release are available for reference here.
Clean Secure Flash
Important
The MPS3 secure flash needs to be cleared before running tests. This is to erase the flash cleanly and prepare a clean board environment for testing.
  1. Clone the systemready-patch repository to your ${WORKSPACE}.
    cd ${WORKSPACE}
    git clone https://git.gitlab.arm.com/arm-reference-solutions/systemready-patch.git -b CORSTONE1000-2025.12
  2. Copy the secure flash cleaning Git patch file to your copy of meta-arm.
    cp -f systemready-patch/embedded-a/corstone1000/erase_flash/0001-embedded-a-corstone1000-clean-secure-flash.patch meta-arm
  3. Apply the Git patch to meta-arm.
    cd meta-arm
    git apply 0001-embedded-a-corstone1000-clean-secure-flash.patch
  4. Rebuild the software stack.
    cd ${WORKSPACE}
    kas shell meta-arm/kas/corstone1000-mps3.yml:meta-arm/ci/debug.yml
    bitbake -c cleansstate trusted-firmware-m corstone1000-flash-firmware-image
    bitbake -c build corstone1000-flash-firmware-image
  5. Replace the bl1.bin file on the SD card with ${WORKSPACE}/build/tmp/deploy/images/corstone1000-mps3/bl1.bin.
  6. Reboot the board to completely erase the secure flash.
    The following message log from TrustedFirmware-M should be displayed on the Secure Enclave terminal (ttyUSB1):
    !!!SECURE FLASH HAS BEEN CLEANED!!!
    NOW YOU CAN FLASH THE ACTUAL CORSTONE1000 IMAGE
    PLEASE REMOVE THE LATEST ERASE SECURE FLASH PATCH AND BUILD THE IMAGE AGAIN
  7. Whilst still in the kas shell, revert the changes the patch introduced by running the following commands:
    cd ${WORKSPACE}/meta-arm
    git reset --hard
    cd ..
    exit
  8. Follow the instructions to build a clean software stack and flash the MPS3 with it.
You can proceed with the test instructions in the following section after having done all the above.
SystemReady IR
Important
SystemReady IR has now been renamed SystemReady Devicetree Band.
Running the tests described below requires USB drives. In our testing, not all USB drive models worked well with the MPS3.
Here are the USB drive models that were stable in our test environment:
  • HP v165w 8 GB USB Flash Drive
  • SanDisk Ultra 32GB Dual USB Flash Drive USB M3.0
  • SanDisk Ultra 16GB Dual USB Flash Drive USB M3.0
Follow the instructions below before running the Architecture Compliance Suite (ACS) tests.
Build an EFI System Partition
A storage with EFI System Partition (ESP) must exist in the system for the UEFI-SCT related tests to pass.
  1. Build an ESP partition for your target
    kas build meta-arm/kas/corstone1000-${TARGET}.yml:meta-arm/ci/debug.yml --target corstone1000-esp-image
  2. Locate the corstone1000-esp-image-corstone1000-${TARGET}.wic build artefact in ${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/
Use the EFI System Partition
MPS3
  1. Connect a USB drive to your development machine.
  2. Run the following command on your development machine to discover which device is your USB drive:
    lsblk
    The remaining steps assume the USB drive is /dev/sdb.
    Warning
    Do not mistake your development machine hard drive with the USB drive.
  3. Copy the ESP to the USB drive by running the following command:
    sudo dd \
    if=${WORKSPACE}/build/tmp/deploy/images/corstone1000-mps3/corstone1000-esp-image-corstone1000-mps3.wic \
    of=/dev/sdb \
    iflag=direct oflag=direct status=progress bs=512; sync;
  4. Plug the USB drive to the MPS3.
FVP
The ESP disk image will automatically be used by the Corstone-1000 FVP as the 2nd MMC card image. It will be used when the SystemReady-IR tests is performed on the FVP in the later section.
Run SystemReady IR ACS Tests
ACS is used to ensure architectural compliance across different implementations of the architecture. Arm Enterprise ACS includes a set of examples of the invariant behaviors that are provided by a set of specifications for enterprise systems (i.e. SBSA, SBBR, etc.). Implementers can verify if these behaviors have been interpreted correctly.
The following test suites and bootable applications are under the BOOT partition of the ACS image:
  • SCT
  • FWTS
  • BSA UEFI
  • BSA linux
  • GRUB
  • UEFI manual capsule application
See the directory structure of the ACS image BOOT partition below:
├── acs_results
├── EFI
│   └── BOOT
│       ├── app
│       ├── bbr
│       ├── bootaa64.efi
│       ├── bsa
│       ├── debug
│       ├── grub.cfg
│       ├── Shell.efi
│       ├── sie_startup.nsh
│       └── startup.nsh
├── Image
├── security-interface-extension-keys
│   ├── NullPK.auth
│   ├── TestDB1.auth
│   ├── TestDB1.der
│   ├── TestDBX1.auth
│   ├── TestDBX1.der
│   ├── TestKEK1.auth
│   ├── TestKEK1.der
│   ├── TestPK1.auth
│   └── TestPK1.der
├── startup.nsh
└── yocto_image.flag
The BOOT partition is also used to store test results in the acs_results folder.
Important
Ensure that the acs_results folder is empty before starting the test.
This sections below describe how to build and run ACS tests on Corstone-1000.
  1. On your host development machine, clone the Arm SystemReady ACS repository.
    cd ${WORKSPACE}
    git clone https://github.com/ARM-software/arm-systemready.git -b v23.09_SR_REL2.0.0_ES_REL1.3.0_IR_REL2.1.0 --depth 1
    This repository contains the infrastructure to build the ACS and the bootable prebuilt images to be used for the certifications of SystemReady IR.
  2. Find the pre-built ACS live image in ${WORKSPACE}/arm-systemready/IR/prebuilt_images/v23.09_2.1.0/ir-acs-live-image-generic-arm64.wic.xz.
    Note
    This prebuilt ACS image includes v5.13 kernel, which does not provide USB driver support for Corstone-1000.
  3. Decompress the pre-built ACS live image.
    cd ${WORKSPACE}/arm-systemready/IR/prebuilt_images/v23.09_2.1.0
    unxz ir-acs-live-image-generic-arm64.wic.xz
MPS3
  1. Connect a USB drive (other than the one used for the ESP) to the host development machine.
  2. Run the following command to discover which device is your USB drive:
    lsblk
    The remaining steps assume the USB drive is /dev/sdc.
    Warning
  3. Copy the ACS image to the USB drive by running the following commands:
    sudo dd if=ir-acs-live-image-generic-arm64.wic of=/dev/sdc iflag=direct oflag=direct bs=1M status=progress; sync
  4. Plug the USB drive to the MPS3. At this point you should have both the USB drive with the ESP and the USB drive with the ACS image plugged to the MPS3.
  5. Reboot the MPS3.
The MPS3 will reset multiple times during the test, and it might take approximately 24 to 36 hours to finish the test.
Important
Unplug the ESP USB drive from the MPS3 if it is preventing GRUB from finding the bootable partition. Leave only the ACS image USB drive plugged in to run the ACS tests.
The ESP USB drive can be plugged in again after selecting the Linux Boot option in the GRUB menu at the end of the ACS tests.
Warning
A timeout issue has been observed while booting Linux during the ACS tests, causing the system to boot into emergency mode. Booting Linux is necessary to run certain tests, such as dt-validation. The following workaround is required to enable Linux to boot properly and perform all Linux-based tests:
  1. Press Enter at the Linux prompt.
  2. Open the file /etc/systemd/system.conf and set DefaultDeviceTimeoutSec=infinity.
  3. Reboot the platform using the reboot command.
  4. Select the Linux Boot option from the GRUB menu.
  5. Allow Linux to boot and run the remaining ACS tests until completion.
FVP
  1. Run tmux:
  2. Run the commands below within tmux to run the ACS test on FVP using the built firmware image and the pre-built ACS image identified above:
    ./meta-arm/scripts/runfvp \
    --terminals=tmux \
    ./build/tmp/deploy/images/corstone1000-fvp/corstone1000-flash-firmware-image-corstone1000-fvp.fvpconf \
    -- -C board.msd_mmc.p_mmc_file=${WORKSPACE}/arm-systemready/IR/prebuilt_images/v23.09_2.1.0/ir-acs-live-image-generic-arm64.wic
Note
The FVP will reset multiple times during the test. The ACS tests might take up to 1 day to complete when run on FVP.
The message ACS run is completed will be displayed on the FVP host terminal when the test runs to completion. You will be prompted to press the Enter key to access the Linux prompt.
Test Sequence and Results
U-Boot should be able to boot the GRUB bootloader from the first partition.
If GRUB is not interrupted, the tests are executed automatically in the following order:
  • SCT
  • UEFI BSA
  • FWTS
The results can be fetched from the acs_results folder in the BOOT partition of the USB drive (for MPS3) or SD Card (for FVP).
Note
Access the acs_results folder in FVP by running the following commands:
sudo mkdir /mnt/test
sudo mount -o rw,offset=1048576 \
${WORKSPACE}/arm-systemready/IR/prebuilt_images/v23.09_2.1.0/ir-acs-live-image-generic-arm64.wic \
/mnt/test
Capsule Update
Warning
The Corstone-1000 with Cortex-A320 FVP becomes unresponsive when the Linux kernel driver for the Ethos-U85 NPU loads automatically after a software reboot. This behavior results from a power reset control issue in the Corstone-1000 with Cortex-A320 FVP model. To prevent the failure and complete the test successfully, rebuild the Corstone-1000 with Cortex-A320 firmware image using the following steps:
    cd ${WORKSPACE}
    git clone https://git.gitlab.arm.com/arm-reference-solutions/systemready-patch.git \
  2. Re-Build the Corstone-1000 with Cortex-A320 FVP software stack as follows:
    kas build meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-a320.yml:\
    systemready-patch/embedded-a/corstone1000/disable_module_autoloading/disable_module_autoloading.yml
Important
Payload GUIDs (${BL2_GUID}, ${TFM_S_GUID}, ${FIP_GUID}, and ${INITRAMFS_GUID}) are different depending on whether the capsule is built for the fvp or mps3 ${TARGET}.
Payloads
FVP
MPS3
BL2
f1d883f9-dfeb-5363-98d8-686ee3b69f4f
fbfbefaa-0a56-50d5-b651-74091d3d62cf
TFM_S
7fad470e-5ec5-5c03-a2c1-4756b495de61
af4cc7ad-ee2e-5a39-aad5-fac8a1e6173c
FIP
f1933675-5a8c-5b6d-9ef4-846739e89bc8
55302f96-c4f0-5cf9-8624-e7cc388f2b68
INITRAMFS
f771aff9-c7e9-5f99-9eda-2369dd694f61
3e8ac972-c33c-5cc9-90a0-cdd3159683ea
The following section describes the steps to update the firmware using Capsule Update as the Corstone-1000 supports UEFI.
The firmware update process is tested with an invalid capsule and with valid capsules to validate the robustness and error-handling capabilities of the firmware update mechanism.
Positive full capsule update test: The Corstone-1000 is provided with a valid full capsule, which it applies successfully. The system then boots normally and reaches the Linux command prompt.
Positive partial capsule update test: The Corstone-1000 is provided with a valid partial capsule that specifies an update for a single component only. The capsule is applied successfully, after which the system boots normally and reaches the Linux command prompt.
Rollback protection capsule update test: The Corstone-1000 is provided with an outdated capsule containing lower version numbers for all payloads. The capsule is correctly rejected due to rollback protection, and the previously installed firmware is retained.
Three different capsules are therefore needed to perform the tests.
The following payloads can be individually updated:
  • Boot Loader stage 2 (BL2)
  • Trusted Firmware-M Secure partition (TFM_S)
  • Firmware Image Package (FIP)
  • Initial RAM Filesystem (INITRAMFS)
Generate Capsules
EDK II’s GenerateCapsule tool is used to generate capsules and is built automatically for the host machine during the firmware image building process. The tool can be found at ${WORKSPACE}/build/tmp/sysroots-components/aarch64/edk2-basetools-native/usr/bin/edk2-BaseTools/BinWrappers/PosixLike/GenerateCapsule.
A JSON file containing metadata about the capsule payloads needs to be created using the script found at ${WORKSPACE}/meta-arm/meta-arm/scripts/generate_capsule_json_multiple.py. This JSON file is required by EDK II’s GenerateCapsule tool to generate the capsule.
The capsule’s default metadata passed can be found in the ${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-bsp/images/corstone1000-flash-firmware-image.bb and ${WORKSPACE}/meta-arm/kas/corstone1000-image-configuration.yml files.
Valid Full Capsule
An automatically generated capsule can be found at ${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000-${TARGET}-v6.uefi.capsule after running a firmware build.
The default metadata values are assumed to be correct to generate a valid capsule.
This capsule will be used for the positive capsule update test.
Valid Partial Capsule
To generate a capsule that updates only a single component, explicitly set the firmware version for that component and mark it as the only payload to be updated.
The partial capsule is also valid, but sets the firmware version to 7 only for the BL2 component, indicating that no other components should be updated.
Use the following commands to generate the capsule_config.json file, which is required by the EDK2 tool for capsule creation:
cd ${WORKSPACE}
python3 meta-arm/meta-arm/scripts/generate_capsule_json_multiple.py \
--selected_components DUMMY_START  BL2  DUMMY_END \
--components DUMMY_START  BL2  TFM_S  FIP  INITRAMFS  DUMMY_END \
--fw_versions 0 7 0 0 0 0 \
--guids \
6f784cbf-7938-5c23-8d6e-24d2f1410fa9  \
${BL2_GUID} ${TFM_S_GUID}  ${FIP_GUID}  ${INITRAMFS_GUID} \
b57e432b-a250-5c73-93e3-90205e64baba \
--hardware_instances 1  1  1  1  1  1 \
--lowest_supported_versions 5 5 5 5 5 5 \
--monotonic_counts 1  1  1  1  1  1 \
--payloads \
build/tmp/work/corstone1000_${TARGET}-poky-linux-musl/corstone1000-flash-firmware-image/1.0/sources/corstone1000-flash-firmware-image-1.0/dummy.bin \
build/tmp/deploy/images/corstone1000-${TARGET}/bl2_signed.bin \
build/tmp/deploy/images/corstone1000-${TARGET}/tfm_s_signed.bin \
build/tmp/deploy/images/corstone1000-${TARGET}/signed_fip-corstone1000.bin \
build/tmp/deploy/images/corstone1000-${TARGET}/Image.gz-initramfs-corstone1000-${TARGET}.bin \
--update_image_indexes 5  1  2  3  4  6 \
--private_keys \
build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_key.key \
--certificates \
build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_cert.crt \
--output capsule_config.json
Run the command below to generate the partial capsule:
./build/tmp/sysroots-components/aarch64/edk2-basetools-native/usr/bin/edk2-BaseTools/BinWrappers/PosixLike/GenerateCapsule \
-e \
-j capsule_config.json \
--capflag PersistAcrossReset \
-o corstone1000-${TARGET}-partial-v7.uefi.capsule
The partial capsule will be located in the ${WORKSPACE} directory.
Invalid Capsule
Generate a capsule with firmware version metadata for all payloads set lower than that of a valid capsule. The valid capsule has a default firmware version of 6 for all payloads, while the simulated invalid capsule has the firmware version set to 5 for all payloads.
cd ${WORKSPACE}
--selected_components DUMMY_START  BL2  TFM_S  FIP  INITRAMFS  DUMMY_END \
--fw_versions 5 5 5 5 5 5 \
--guids \
--payloads \
--private_keys \
--certificates \
Run the command below to generate the invalid capsule:
-e \
-o corstone1000-${TARGET}-v5.uefi.capsule
The invalid capsule will be located in the ${WORKSPACE} directory.
Transfer Capsules to Target
The capsule delivery process described below is the direct method (usage of capsules from the ACS image) as opposed to the on-disk method (delivery of capsules using a file on a mass storage device).
MPS3
  1. Prepare a USB drive as explained in this section.
  2. Copy the capsule file to the root directory of the BOOT partition in the USB drive.
cp ${WORKSPACE}/build/tmp/deploy/images/corstone1000-mps3/corstone1000-mps3-v6.uefi.capsule /dev/sdc/BOOT/
cp ${WORKSPACE}/corstone1000-mps3-v5.uefi.capsule /dev/sdc/EFI/BOOT/
cp ${WORKSPACE}/corstone1000-mps3-partial-v7.uefi.capsule /dev/sdc/EFI/BOOT/
sync
Note
/dev/sdc is the assumed path for the ACS Image USB drive. Replace it with the actual device path as enumerated on your development machine.
Important
The direct Capsule Update method requires that the capsule files not be placed in the EFI/UpdateCapsule directory, as doing so might inadvertently trigger the on-disk update method.
FVP
  1. Download and extract the ACS image as described for the MPS3. The ACS image extraction location will be referred below as ${ACS_IMAGE_PATH}.
    Note
    Creating a USB drive with the ACS image is not required as the image will be mounted with the steps below.
  2. Find the first partition’s offset of the ir-acs-live-image-generic-arm64.wic image using the fdisk tool. The partition table can be listed using:
    fdisk -lu ${ACS_IMAGE_PATH}/ir-acs-live-image-generic-arm64.wic
    Device                                                 Start     End Sectors  Size Type
    ${ACS_IMAGE_PATH}/ir-acs-live-image-generic-arm64.wic1    2048  309247  307200  150M Microsoft basic data
    ${ACS_IMAGE_PATH}/ir-acs-live-image-generic-arm64.wic2  309248 1343339 1034092  505M Linux filesystem
    Given that the first partition starts at sector 2048 and each sector is 512 bytes in size, the first partition is at offset 1048576 (2048 x 512).
  3. Mount the ir-acs-live-image-generic-arm64.wic image using the previously calculated offset:
    sudo mkdir /mnt/ir-acs-live-image-generic-arm64
    sudo mount -o rw,offset=<first_partition_offset> ${ACS_IMAGE_PATH}/ir-acs-live-image-generic-arm64.wic  /mnt/ir-acs-live-image-generic-arm64
  4. Copy the capsules:
    sudo cp ${WORKSPACE}/build/tmp/deploy/images/corstone1000-fvp/corstone1000-fvp-v6.uefi.capsule /mnt/ir-acs-live-image-generic-arm64/
    sudo cp ${WORKSPACE}/corstone1000-fvp-v5.uefi.capsule /mnt/ir-acs-live-image-generic-arm64/
    sudo cp ${WORKSPACE}/corstone1000-fvp-partial-v7.uefi.capsule /mnt/ir-acs-live-image-generic-arm64/
    sync
  5. Unmount the IR image:
    sudo umount /mnt/ir-acs-live-image-generic-arm64
Run Capsule Update Tests
The valid capsules will be used first to run the positive capsule update tests. This will be followed by using the invalid capsule to run the rollback protection capsule update test.
Important
This sequence order must be respected as the invalid capsule has a firmware version lower than the firmware version in the valid capsule. The rollback protection capsule update test effectively tests that firmware rollback is not permitted.
Positive Full Capsule Update Test
  1. Run Corstone-1000 with the ACS image containing the two capsule files:
    • MPS3:
      1. Plug the prepared USB drive which has the IR prebuilt image and two capsules to the MPS3.
      2. Power cycle the MPS3.
    • FVP:
      1. Run tmux:
      1. Run the FVP within tmux with the IR prebuilt image which now also contains the two capsules:
      -c "../meta-arm/scripts/runfvp --terminals=tmux \
      -- -C board.msd_mmc.p_mmc_file=${ACS_IMAGE_PATH}/ir-acs-live-image-generic-arm64.wic"
      Warning
      ${ACS_IMAGE_PATH} must be an absolute path. Ensure there are no spaces before or after of = of the -C board.msd_mmc.p_mmc_file option.
  2. Wait until U-Boot loads EFI from the ACS image and interrupt the EFI shell by pressing the Escape key when the following prompt is displayed on the Host Processor terminal (ttyUSB2 for MPS3).
    Press ESC in 4 seconds to skip startup.nsh or any other key to continue.
  3. The content of the first file system (File System 0), where the capsule files were copied, can be accessed by running the following command:
    FS0:
  4. Run the CapsuleApp application with the valid capsule file:
    • MPS3:
      EFI/BOOT/app/CapsuleApp.efi EFI/BOOT/corstone1000-mps3-v6.uefi.capsule
    • FVP:
      EFI/BOOT/app/CapsuleApp.efi corstone1000-fvp-v6.uefi.capsule
    The capsule update will be started.
    Note
    The capsule update takes about 8 minutes to complete on MPS3 and between 15-30 minutes on FVP.
    The Corstone-1000 will reset after successfully applying the capsule.
    The software stack copies the capsule content to the external flash, which is shared between the Secure Enclave and the Host Processor before rebooting the system.
    After the first reboot, TrustedFirmware-M should apply the valid capsule and display the following log on the Secure Enclave terminal (ttyUSB1 for MPS3) before rebooting the system a second time:
    SysTick_Handler: counted = 10, expiring on = 360
    SysTick_Handler: counted = 20, expiring on = 360
    SysTick_Handler: counted = 30, expiring on = 360
    metadata_write: success: active = 1, previous = 0
    flash_full_capsule: exit
    corstone1000_fwu_flash_image: exit: ret = 0
    The above log snippet indicates that the new capsule image is successfully applied, and the board is booting with the external flash’s Bank-1.
    After a second reboot, the following log should be displayed on on the Secure Enclave terminal (ttyUSB1):
    fmp_set_image_info:133 Enter
    FMP image update: image id = 0
    FMP image update: status = 0version=6 last_attempt_version=6.
    fmp_set_image_info:157 Exit.
    corstone1000_fwu_host_ack: exit: ret = 0
  5. Interrupt the U-Boot shell.
    Hit any key to stop autoboot:
  6. Run the following commands in order to run the Corstone-1000 Linux kernel.
    Note
    Otherwise, the execution ends up in the ACS live image.
    $ unzip $kernel_addr 0x90000000
    $ loadm 0x90000000 $kernel_addr_r $filesize
    $ bootefi $kernel_addr_r $fdtcontroladdr
  7. The first boot after a capsule update is considered the trial stage, during which the FWU image is accepted. However, to view the updated contents of the EFI System Resource Table (ESRT), an additional reboot is required.
    # reboot
  8. Interrupt the U-Boot shell when prompted.
  9. Run the following commands to boot the Corstone-1000 Linux kernel.
    Note
    If these commands are not executed, the system will default to booting into the ACS live image.
  10. Once the system has fully booted again, read the ESRT to confirm that the firmware version reflects the updated capsule.
Warning
Do not terminate FVP between the positive full capsule update and partial capsule update tests.
Positive Partial Capsule Update Test
Follow the steps for the positive full capsule update test ensuring you use corstone1000-${TARGET}-partial-v7.uefi.capsule instead of corstone1000-${TARGET}-v6.uefi.capsule.
Warning
Do not terminate FVP between the positive partial capsule update rollback protection capsule update tests.
Rollback Protection Capsule Update Test
Important
The positive partial capsule update test must be run before running the rollback protection capsule update test.
  1. After running the positive capsule update test, reboot the system by typing the following command on the Host Processor terminal (ttyUSB2 for MPS3):
    reboot
    FS0:
  4. Run the CapsuleApp application with the invalid capsule file:
    • MPS3:
      EFI/BOOT/app/CapsuleApp.efi EFI/BOOT/corstone1000-mps3-v5.uefi.capsule
    • FVP:
      EFI/BOOT/app/CapsuleApp.efi corstone1000-fvp-v5.uefi.capsule
  5. TrustedFirmware-M should reject the capsule due to having a lower firmware version and display the following log on the Secure Enclave terminal (ttyUSB1 for MPS3):
      uefi_capsule_retrieve_images: image 0 at 0xa0000070, size=15654928
      uefi_capsule_retrieve_images: exit
      flash_full_capsule: enter: image = 0x0xa0000070, size = 7764541, version = 5
      ERROR: flash_full_capsule: version error
      private_metadata_write: enter: boot_index = 1
      private_metadata_write: success
      FMP image update: status = 1version=6 last_attempt_version=5.
      corstone1000_fwu_flash_image: exit: ret = -1
      fmp_get_image_info:232 Enter
      pack_image_info:207 ImageInfo size = 105, ImageName size = 34, ImageVersionName
      size = 36
      fmp_get_image_info:236 Exit
    The Secure Enclave tries to load the new image a predetermined number of times if the capsule passes initial verification but fails verifications performed during boot time.
    metadata_write: success: active = 0, previous = 1
    fwu_select_previous: in regular state by choosing previous active bank
    The Secure Enclave eventually reverts back to the previously running image.
  6. Reboot manually:
    Shell> reset
  7. Interrupt the U-Boot shell.
  8. Run the following commands in order to run the Corstone-1000 Linux kernel.
    Note
  9. The first boot after a capsule update is considered the trial stage, during which the FWU image is rejected. However, to view the updated contents of the ESRT, an additional reboot is required.
    # reboot
  10. Interrupt the U-Boot shell when prompted.
  11. Run the following commands to boot the Corstone-1000 Linux kernel.
    Note
  12. Once the system has fully booted again, read the ESRT to confirm that the firmware version reflects the updated capsule.
Verifying Firmware Versions via ESRT
After the system has fully booted, verify that the firmware versions of all applied capsule payloads match those currently installed on the system. This can be done by inspecting the ESRT, which is exposed by the Linux kernel.
Reading ESRT Entries
To read each ESRT entry, use the following commands:
cat /sys/firmware/efi/esrt/entries/entry0/*
cat /sys/firmware/efi/esrt/entries/entry1/*
cat /sys/firmware/efi/esrt/entries/entry2/*
cat /sys/firmware/efi/esrt/entries/entry3/*
These entries typically correspond to:
  • entry0: BL2
  • entry1: TFM_S
  • entry2: FIP
  • entry3: INITRAMFS
Note
Entry indices may vary depending on how your firmware capsules are structured. Adjust as needed.
Structure of Each ESRT Entry
Each directory under /sys/firmware/efi/esrt/entries/entryX/ contains files representing the following fields:
Field Name
Description
capsule_flags
Attributes of the update capsule (e.g., persist, reset)
fw_class
GUID identifying the firmware component
fw_type
Firmware type (e.g., system, device, peripheral)
fw_version
Currently installed firmware version
last_attempt_status
Status of the last update attempt (e.g., success, failure)
Version that was last attempted to install
lowest_supported_fw_version
Minimum firmware version that is still supported
Verifying an ESRT Entry
To check the version and status of BL2 (entry0), run:
cat /sys/firmware/efi/esrt/entries/entry0/fw_version
cat /sys/firmware/efi/esrt/entries/entry0/last_attempt_version
cat /sys/firmware/efi/esrt/entries/entry0/last_attempt_status
Positive Full Capsule Update Test ESRT
The following table shows the details of the first four ESRT entries for the positive capsule update test:
capsule_flags
fw_class
fw_type
fw_version
last_attempt_status
0
${BL2_GUID}
0
6
0
6
0
0
${TFM_S_GUID}
0
6
0
6
0
0
${FIP_GUID}
0
6
0
6
0
0
${INITRAMFS_GUID}
0
6
0
6
0
Positive Partial Capsule Update Test ESRT
capsule_flags
fw_class
fw_type
fw_version
last_attempt_status
0
${BL2_GUID}
0
7
0
7
0
0
${TFM_S_GUID}
0
6
0
6
0
0
${FIP_GUID}
0
6
0
6
0
0
${INITRAMFS_GUID}
0
6
0
6
0
Rollback Protection Capsule Update Test ESRT
The following table shows the details of the first four ESRT entries for the rollback protection capsule update test:
capsule_flags
fw_class
fw_type
fw_version
last_attempt_status
0
${BL2_GUID}
0
7
1
5
0
0
${TFM_S_GUID}
0
6
0
6
0
0
${FIP_GUID}
0
6
0
6
0
0
${INITRAMFS_GUID}
0
6
0
6
0
See the UEFI documentation for more information on the significance of the table fields.
Linux Distributions
This sections describes the steps to install major Linux distributions to the Corstone-1000 Host Processor.
The Linux distributions to be installed are:
Follow the instructions below to install the Linux distributions to the Corstone-1000 software stack.
Prepare Installation Media
The media containing the bootable files required to start the installation process needs to be prepared.
Follow the instructions below to create the installation media.
  1. Using your development machine, download one of following Linux distribution images:
    Note
    The location of the ISO file on the development machine will be referred to as ${DISTRO_INSTALLER_ISO_PATH}.
  2. Create the installation media which will contain the necessary files to install the operation system.
  • MPS3:
    1. Plug a blank USB drive formatted with FAT32, ensuring it has a minimum capacity of 4GB, to the development machine.
      lsblk
      Warning
    3. Write one of the distribution installer ISO file to the USB drive.
      sudo dd if=${DISTRO_INSTALLER_ISO_PATH} of=/dev/sdb iflag=direct oflag=direct status=progress bs=1M; sync;
  • FVP:
    The distribution installer ISO file does not need to be burnt to a USB drive. It will be used as is when starting the FVP install the distribution.
Prepare System Drive
A system (or boot) drive, to store all the operating system files and used to boot the distribution, is required as Corstone-1000 on-board non-volatile storage size is insufficient for installing the distributions.
  • MPS3:
    1. Find another blank USB drive formatted with FAT32 with a minimum capacity of 4GB.
    2. Do not yet connect this blank USB drive to the MPS3. It will be used as the primary drive to boot the distribution.
  • FVP:
    1. Create an 10 GB GUID Partition Table (GPT) formatted MultiMediaCard (MMC) image.
      dd if=/dev/zero of=${WORKSPACE}/fvp_distro_system_drive.img \
      bs=1 count=0 seek=10G; sync; \
      parted -s fvp_distro_system_drive.img mklabel gpt
    2. This MMC image will be used as the primary drive to boot the distribution.
Installation
MPS3
  1. Connect the installation media, which contains the installer for the desired distribution, to the MPS3.
  2. Open a serial port terminal interface to /dev/ttyUSB0 in one terminal window on your development machine.
  3. Open a serial port terminal interface to /dev/ttyUSB2 in another terminal window on your development machine.
  4. When the installation screen is displayed on ttyUSB2, plug in the (still empty) system drive to the MPS3.
  5. Start the distribution installation process.
    Note
    Reboot the MPS3 with both USB drives (installation media and empty system drive) connected to it if the distribution installer does not start.
Note
Due to the performance limitation, the distribution installation process can take up to 24 hours to complete.
FVP
  1. Run the tmux:
  2. Start the FVP within tmux with the system drive as the primary drive and the distro ISO file as the secondary drive:
    -c "../meta-arm/scripts/runfvp --terminals=tmux -- \
    -C board.msd_mmc.p_mmc_file=${WORKSPACE}/fvp_distro_system_drive.img \
    -C board.msd_mmc_2.p_mmc_file=${DISTRO_INSTALLER_ISO_PATH}"
    The Linux distribution will be installed on fvp_distro_system_drive.img.
Debian Installation Extra Steps
Debian installation may need some extra steps, that are indicated below:
  1. Answer Yes to the question Force grub installation to the EFI removable media path?.
    If the GRUB installation fails, these are the steps to follow on the subsequent popups:
    1. Select Continue, then Continue again on the next popup.
    2. Scroll down and select Execute a shell.
    3. Select Continue.
    4. Enter the following command:
      in-target grub-install --no-nvram --force-extra-removable
    5. Enter the following command:
      in-target update-grub
    6. Enter the following command:
      exit
    7. Select Continue without boot loader, then select Continue on the next popup.
    8. At this stage, the installation should proceed as normal.
  2. Answer No to the question Update NVRAM variables to automatically boot into Debian?.
Boot Distribution
  • MPS3
    1. Once the installation is complete, unplug the installation media.
    2. Perform a cold boot of the MPS3.
  • FVP
    The target should automatically boot into the installed operating system image.
    Stop the FVP with CTRL+C and run tmux:
    Run the command below to simulate a cold boot:
    -C board.msd_mmc.p_mmc_file=${WORKSPACE}/fvp_distro_system_drive.img"
    Warning
    To manually enter recovery mode, once the FVP begins booting, you can quickly change the boot option in GRUB, to boot into recovery mode. This option will disappear quickly, so it is best to preempt it.
    Select Advanced Options for <OS> and then <OS> (recovery mode).
The target will then enter recovery mode, from which the user can access a shell after entering the password for the root user.
Timeout Optimizations
Important
Operating system timeouts are inconsistent across systems. Skip this section if the system boots to Debian or openSUSE without any issue.
Make the system modification below whilst in recovery mode to increase timeouts and boot to the installed distribution.
  1. Remove the timeout limit for device operations.
    • Debian
      vi /etc/systemd/system.conf
    • openSUSE
      vi /usr/lib/systemd/system.conf
      Warning
      As modifying system.conf in /usr/lib/systemd/ is not working as it is getting overwritten, copy system.conf from /usr/lib/systemd/ to /etc/systemd/system.conf.d/ after the above edit.
  2. Set the maximum time that the system will wait for a user to successfully log in before timing out to 180 seconds.
    • Debian
      vi /etc/login.defs
      LOGIN_TIMEOUT   180
    • openSUSE
      vi /usr/etc/login.defs
      LOGIN_TIMEOUT   180
  3. Ensure the changes are applied by run the command below.
    systemctl daemon-reload
  4. Perform a cold boot of the target.
Log into the Distribution
Login with the root username and its corresponding password (set during installation) at the distribution login prompt after booting. See an illustration for Debian below:
debian login:
UEFI Secure Boot
The UEFI Secure Boot test is designed to verify the integrity and authenticity of the system’s boot process. This test ensures that only trusted, signed images are executed, thereby preventing unauthorized or malicious code from running. A successful test confirms that the signed image executes correctly, while any unsigned image is blocked from running.
Generate Keys, Signed Image and Unsigned Image
  1. Build an EFI System Partition as described here.
  2. Clone the systemready-patch repository to your workspace.
    cd ${WORKSPACE}
    git clone https://gitlab.arm.com/arm-reference-solutions/systemready-patch \
  3. Set the current working directory to build directory’s subdirectory containing the software stack build images.
    cd ${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/
  4. Run the image signing script (without changing the current working directory).
    ./${WORKSPACE}/systemready-patch/embedded-a/corstone1000/secureboot/create_keys_and_sign.sh \
    -d ${TARGET} \
    -v ${CERTIFICATE_VALIDITY_DURATION_IN_DAYS}
    Important
    The efitools package is required to execute the script.
    ${CERTIFICATE_VALIDITY_DURATION_IN_DAYS} is an integer that specifies the certificate’s validity period in days.
    Note
    Consult the image signing script help message (-h) for more information about other optional arguments.
    The script is interactive and contains commands that require sudo level permissions.
The keys, signed kernel image, and unsigned kernel image will be copied to the exisiting ESP image. The modified ESP image can be found at ${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000-esp-image-corstone1000-${TARGET}.wic.
Run Unsigned Image Boot Test
MPS3
  1. Follow the instructions here to use the ESP.
  3. On the Host Processor terminal host side, stop the execution of U-Boot when prompted to do so with the message Press any key to stop.
    Warning
    There is a timeout of 3 seconds to stop the execution at the U-Boot prompt.
    The U-Boot console prompt looks as follows:
    corstone1000#
    Important
    The rest of the instructions below will be executed on the U-Boot terminal.
  4. On the U-Boot console, reset USB.
    corstone1000# usb reset
    resetting USB...
    Bus usb@40200000: isp1763 bus width: 16, oc: not available
    USB ISP 1763 HW rev. 32 started
    scanning bus usb@40200000 for devices... port 1 high speed
    3 USB Device(s) found
            scanning usb for storage devices... 1 Storage Device(s) found
    Note
    Occasionally, the USB reset may fail to detect the USB device. It is advisable to rerun the USB reset command.
  5. Select the first USB device, which should be the USB drive containing the ESP.
    corstone1000# usb dev 0
  6. Enroll the four UEFI secure boot authenticated variables.
    corstone1000# \
    load usb 0 $loadaddr corstone1000_secureboot_keys/PK.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize PK; \
    load usb 0 $loadaddr corstone1000_secureboot_keys/KEK.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize KEK; \
    load usb 0 $loadaddr corstone1000_secureboot_keys/db.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize db; \
    load usb 0 $loadaddr corstone1000_secureboot_keys/dbx.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize dbx
  7. Attempt to Load the unsigned kernel image.
    corstone1000# \
    load usb 0 $loadaddr corstone1000_secureboot_mps3_images/Image_mps3
    loadm $loadaddr $kernel_addr_r $filesize
    Booting /MemoryMapped(0x0,0x88200000,0x236aa00)
    Image not authenticated
    Loading image failed
The unsigned Linux kernel image should not be loaded.
FVP
  2. Run the software stack as described here.
    Warning
    corstone1000#
    Important
  4. On the U-Boot console, set the current MMC device.
    corstone1000# mmc dev 1
  5. Enroll the four UEFI secure boot authenticated variables.
    corstone1000# \
    load mmc 1:1 $loadaddr corstone1000_secureboot_keys/PK.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize PK; \
    load mmc 1:1 $loadaddr corstone1000_secureboot_keys/KEK.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize KEK; \
    load mmc 1:1 $loadaddr corstone1000_secureboot_keys/db.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize db; \
    load mmc 1:1 $loadaddr corstone1000_secureboot_keys/dbx.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize dbx
  6. Attempt to Load the unsigned kernel image.
    corstone1000# \
    load mmc 1:1 $loadaddr corstone1000_secureboot_fvp_images/Image_fvp; \
    loadm $loadaddr $kernel_addr_r $filesize; \
Run Signed Image Boot Test
MPS3
Important
You must first perform the Unsigned Image Boot Test.
Load the signed kernel image.
corstone1000# \
load usb 0 $loadaddr corstone1000_secureboot_mps3_images/Image_mps3.signed; \
The signed Linux kernel image should be booted successfully.
FVP
Important
corstone1000# \
load mmc 1:1 $loadaddr corstone1000_secureboot_fvp_images/Image_fvp.signed; \
Disable Secure Boot
Running the UEFI Secure Boot Test steps stores UEFI authenticated variables in the secure flash. As a result, U-Boot reads these variables and verifies the Linux kernel image before executing it at each reboot.
In a typical boot scenario, the Linux kernel image is not signed, which will prevent the system from booting due to failed image authentication. To resolve this, the Platform Key (one of the UEFI authenticated variables for secure boot) needs to be deleted.
  1. Perform a cold boot of the MPS3.
  2. On the Host Processor terminal host side, stop the execution of U-Boot when prompted to do so with the message Press any key to stop.
  3. On the U-Boot console, delete the Platform Key (PK).
    • MPS3
      corstone1000# \
      usb reset; \
      usb dev 0; \
      load usb 0 $loadaddr corstone1000_secureboot_keys/PK_delete.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize PK; \
      boot
    • FVP
      corstone1000# \
      mmc dev 1; \
      load mmc 1:1 $loadaddr corstone1000_secureboot_keys/PK_delete.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize PK; \
      boot
PSA API
The following tests the implementation of the Application Programming Interface (API) of the Platform Security Architecture (PSA) certification scheme. It uses Arm Firmware Framework for Arm A-profile (FF-A) to communicate between the normal world and the secure world to run the Arm Platform Security Architecture Test Suite.
The tests use the arm_tstee driver to access Trusted Services Secure Partitions from user space. The driver is included in the Linux Kernel, starting from v6.10.
Important
Ensure there are no USB drives connected to the board when running the test on the MPS3.
The steps below are applicable to both MPS3 and FVP.
  1. Start the Corstone-1000 and wait until it boots to Linux on the Host Processor terminal (ttyUSB2).
  2. Run the PSA API tests by running the commands below in the order shown:
    psa-iat-api-test
    psa-crypto-api-test
    psa-its-api-test
    psa-ps-api-test
Important
Access to the External System Processor is disabled by default. Ensure you are running a software stack image with access to the External System Processor enabled following the steps here.
The Linux operating system running on the Host Processor starts the remoteproc framework to manage the External System Processor.
  1. Stop the External System Processor with the following command:
    echo stop > /sys/class/remoteproc/remoteproc0/state
  2. Start the External System Processor with the following command:
    echo start > /sys/class/remoteproc/remoteproc0/state
Symmetric Multiprocessing
Warning
Symmetric multiprocessing (SMP) mode is only supported on Corstone-1000 with Cortex-A35 FVP but is disabled by default.
  1. Build the software stack with SMP mode enabled:
    kas build meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-fvp-multicore.yml
  2. Run the Corstone-1000 FVP:
    kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-fvp-multicore.yml \
    -c "../meta-arm/scripts/runfvp"
  3. Verify that the FVP is running the Host Processor with more than one CPU core:
    nproc
    4                  # number of processing units
Ethos-U85 NPU
Warning
The Ethos-U85 NPU is only supported on Corstone-1000 with Cortex-A320 FVP.
    cd ${WORKSPACE}
  2. Copy the additional kas configuration file to:
    cp ${WORKSPACE}/systemready-patch/embedded-a/corstone1000/ethos-u85_test/ethos-u85_test.yml \
  3. Re-Build the Corstone-1000 with Cortex-A320 FVP software stack as follows:
    meta-arm/kas/ethos-u85_test.yml
  4. Run the Corstone-1000 with Cortex-320 FVP:
    kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-a320.yml:\
  5. To verify you are running the Corstone-1000 with Cortex-A320, build and run the FVP and inspect the CPU model reported in /proc/cpuinfo as shown below. Inside the FVP shell, confirm the core type:
    grep -E 'CPU part|model name' /proc/cpuinfo
    # Expect: CPU part : 0xd8f  (which corresponds to Cortex-A320)
  6. Run the delegate_runner test application inside the FVP shell as follows:
    delegate_runner -l /usr/lib/libethosu_op_delegate.so \
    -n /usr/share/ethosu/mobilenet_v2_1.0_224_INT8_vela.tflite \
    -i /usr/share/ethosu/input_data0.bin \
    -o /usr/share/ethosu/actual_output_data0.bin
    The test completes in approximately one minute.
  7. Run the following command to compare the generated output binary with the expected output binary:
    cmp -s /usr/share/ethosu/expected_output_data0.bin /usr/share/ethosu/actual_output_data0.bin
    The two binary files should be identical.
Secure Debug
Warning
Secure Debug is only supported on MPS3.
The MPS3 supports Authenticated Debug Access Control (ADAC), using the CoreSight SDC-600 IP.
For more information about this, see the following resources:
The Secure Debug Manager API is implemented in the Secure Debug Manager (PSA-ADAC / SDC-600) repository. This repository also contains the necessary files for the Arm Development Studio support. The build and integration instructions can be found in its README.
The Secure Debug Manager (PSA-ADAC / SDC-600) repository also contains the private key and chain certificate to be used during the tests. The private key’s public pair is provisioned into the One-Time Programmable memory in TrustedFirmware-M. These are dummy keys that should not be used in production.
To test the Secure Debug feature, you’ll need a debug probe from the Arm ULINKpro family and Arm Development Studio versions 2022.2, 2022.c, or 2023.a.
  1. Clone the Secure Debug Manager (PSA-ADAC / SDC-600) repository to your workspace.
    cd ${WORKSPACE}
    git clone https://github.com/ARM-software/secure-debug-manager.git
  2. Navigate into the repository directory and checkout the specific commit in the listing below.
    cd ${WORKSPACE}/secure-debug-manager
    git checkout b30d6496ca749123e86b39b161b9f70ef76106d6
  3. Follow the instructions in the Secure Debug Manager (PSA-ADAC / SDC-600)’s README for the development machine setup.
  4. Rebuild the software stack with Secure Debug.
    kas build meta-arm/kas/corstone1000-mps3.yml:meta-arm/ci/debug.yml:meta-arm/ci/secure-debug.yml
  5. Flash the firmware image as shown here.
  6. Run the software as shown here.
  7. Wait until the Secure Enclave terminal (ttyUSB1) prints the following prompts:
    IComPortInit                  :  382 : warn  : init       : IComPortInit: Blocked reading of LPH2RA is active.
    IComPortInit                  :  383 : warn  : init       : IComPortInit: Blocked reading LPH2RA
  8. Connect the debug probe to the MPS3 using the 20-pin 1.27mm connector with the CS_20W_1.27MM silkscreen label.
  9. Create a debug configuration in Arm Development Studio as described in the Secure Debug Manager (PSA-ADAC / SDC-600)’s README.
  10. Connect the debuger to the target using the debug configuration.
  11. Provide the paths to the private key and trust chain certificate when asked by Arm Development Studio Console.
    Please provide private key file path:
    Enter file path > ${WORKSPACE}\secure-debug-manager\example\data\keys\EcdsaP256Key-3.pem
    Please provide trust chain file path:
    Enter file path > ${WORKSPACE}\secure-debug-manager\example\data\chains\chain.EcdsaP256-3
  12. When successful authenticated, Arm Development Studio will connect to the running MPS3 and the debug features can be used. The following prompt should appear in the Secure Enclave terminal (ttyUSB1):
    boot_platform_init: Corstone-1000 Secure Debug is a success.
Copyright (c) 2022-2026, Arm Limited. All rights reserved.
