.. # Copyright (c) 2022-2026, Arm Limited. # # SPDX-License-Identifier: MIT #################### Build, Flash and Run #################### Notice ------ The Corstone-1000 software stack uses the `Yocto Project `__ to build a tiny Linux distribution suitable for the Corstone-1000 platform (kernel and initramfs filesystem less than 5 MB on the flash). The Yocto Project relies on the `BitBake `__ tool as its build tool. Please see `Yocto Project documentation `__ for more information. Prerequisites ------------- This guide assumes that your host machine is running Ubuntu 20.04 LTS ( with ``sudo`` rights), with at least 32GB of free disk space and 16GB of RAM as minimum requirement. The following prerequisites must be available on the host system: - Git 1.8.3.1 or greater. - Python 3.8.0 or greater. - GNU Tar 1.28 or greater. - GNU Compiler Collection 8.0 or greater. - GNU Make 4.0 or greater. - tmux. Please follow the steps described in the Yocto mega manual: - `Compatible Linux Distribution `__ - `Build Host Packages `__ Targets ------- The Corstone-1000 software stack can be run on: - `Arm Corstone-1000 Ecosystem FVP (Fixed Virtual Platform) `__ - `Arm Corstone-1000 for MPS3 `__ .. important:: Arm Corstone-1000 for MPS3 requires an additional 32 MB QSPI flash PMOD module. For more information see the `Application Note AN550 document `__. Yocto Stable Branch ------------------- Corstone-1000 software stack is built on top of Yocto Project's `Walnascar release `__. Software Components ------------------- Within the Yocto Project, each component included in the Corstone-1000 software stack is specified as a `BitBake recipe `__. The recipes specific to the Corstone-1000 BSP are located at: ``${WORKSPACE}/meta-arm/meta-arm-bsp/``. .. important:: ``${WORKSPACE}`` refers to the absolute path to your workspace where the `meta-arm` repository will be cloned. Consider exporting it (e.g., ``export WORKSPACE=$(realpath .)``) if you're already in the workspace directory, so you can copy and paste the commands from this guide verbatim. .. important:: ``${TARGET}`` is either ``mps3`` or ``fvp``. Consider exporting it (e.g., ``export TARGET=mps3``) so you can copy and paste the commands from this guide verbatim. The Yocto machine config files for the Corstone-1000 FVP and MPS3 targets are: - ``${WORKSPACE}/meta-arm/meta-arm-bsp/conf/machine/include/corstone1000.inc`` - ``${WORKSPACE}/meta-arm/meta-arm-bsp/conf/machine/corstone1000-${TARGET}.conf`` .. note:: All the paths stated in this document are absolute paths. ************************* Host Processor Components ************************* `Trusted Firmware-A `__ ==================================================================================== +----------+-------------------------------------------------------------------------------------------------------+ | bbappend | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-bsp/trusted-firmware-a/trusted-firmware-a_%.bbappend`` | +----------+-------------------------------------------------------------------------------------------------------+ | Recipe | ``${WORKSPACE}/meta-arm/meta-arm/recipes-bsp/trusted-firmware-a/trusted-firmware-a_2.13.0.bb`` | +----------+-------------------------------------------------------------------------------------------------------+ `Trusted Services `__ ==================================================================================== +----------+-------------------------------------------------------------------------------------------------------------+ | bbappend | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/trusted-services/libts_%.bbappend`` | +----------+-------------------------------------------------------------------------------------------------------------+ | bbappend | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/trusted-services/ts-psa-crypto-api-test_%.bbappend`` | +----------+-------------------------------------------------------------------------------------------------------------+ | bbappend | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/trusted-services/ts-psa-iat-api-test_%.bbappend`` | +----------+-------------------------------------------------------------------------------------------------------------+ | bbappend | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/trusted-services/ts-psa-its-api-test_%.bbappend`` | +----------+-------------------------------------------------------------------------------------------------------------+ | bbappend | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/trusted-services/ts-psa-ps-api-test_%.bbappend`` | +----------+-------------------------------------------------------------------------------------------------------------+ | bbappend | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/trusted-services/ts-sp-se-proxy_%.bbappend`` | +----------+-------------------------------------------------------------------------------------------------------------+ | bbappend | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/trusted-services/ts-sp-smm-gateway_%.bbappend`` | +----------+-------------------------------------------------------------------------------------------------------------+ | Recipe | ``${WORKSPACE}/meta-arm/meta-arm/recipes-security/trusted-services/libts_git.bb`` | +----------+-------------------------------------------------------------------------------------------------------------+ | Recipe | ``${WORKSPACE}/meta-arm/meta-arm/recipes-security/trusted-services/ts-psa-crypto-api-test_git.bb`` | +----------+-------------------------------------------------------------------------------------------------------------+ | Recipe | ``${WORKSPACE}/meta-arm/meta-arm/recipes-security/trusted-services/ts-psa-iat-api-test_git.bb`` | +----------+-------------------------------------------------------------------------------------------------------------+ | Recipe | ``${WORKSPACE}/meta-arm/meta-arm/recipes-security/trusted-services/ts-psa-its-api-test_git.bb`` | +----------+-------------------------------------------------------------------------------------------------------------+ | Recipe | ``${WORKSPACE}/meta-arm/meta-arm/recipes-security/trusted-services/ts-psa-ps-api-test_git.bb`` | +----------+-------------------------------------------------------------------------------------------------------------+ | Recipe | ``${WORKSPACE}/meta-arm/meta-arm/recipes-security/trusted-services/ts-sp-smm-gateway_git.bb`` | +----------+-------------------------------------------------------------------------------------------------------------+ | Recipe | ``${WORKSPACE}/meta-arm/meta-arm/recipes-security/trusted-services/ts-sp-se-proxy_git.bb`` | +----------+-------------------------------------------------------------------------------------------------------------+ `OP-TEE `__ ================================================================ +----------+------------------------------------------------------------------------------------------+ | bbappend | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-security/optee/optee-os_4.%.bbappend`` | +----------+------------------------------------------------------------------------------------------+ | Recipe | ``${WORKSPACE}/meta-arm/meta-arm/recipes-security/optee/optee-os_4.7.0.bb`` | +----------+------------------------------------------------------------------------------------------+ `U-Boot `__ ================================================= +----------+----------------------------------------------------------------------------------+ | bbappend | ``${WORKSPACE}/meta-arm/meta-arm/recipes-bsp/u-boot/u-boot_%.bbappend`` | +----------+----------------------------------------------------------------------------------+ | bbappend | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-bsp/u-boot/u-boot_%.bbappend`` | +----------+----------------------------------------------------------------------------------+ | Recipe | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-bsp/u-boot/u-boot_2025.04.bb`` | +----------+----------------------------------------------------------------------------------+ Linux ===== The distribution is based on the `Poky `__ distribution which is a Linux distribution stripped down to a minimal configuration. The provided distribution is based on `BusyBox `__ and built using `musl libc `__. +-----------+------------------------------------------------------------------------------------------------+ | bbappend | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-kernel/linux/linux-yocto_%.bbappend`` | +-----------+------------------------------------------------------------------------------------------------+ | Recipe | ``${WORKSPACE}/core/meta/recipes-kernel/linux/linux-yocto_6.12.bb`` | +-----------+------------------------------------------------------------------------------------------------+ | defconfig | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-kernel/linux/files/corstone1000/defconfig`` | +-----------+------------------------------------------------------------------------------------------------+ ************************* Secure Enclave Components ************************* `Trusted Firmware-M `__ ==================================================================================== +----------+-------------------------------------------------------------------------------------------------------+ | bbappend | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-bsp/trusted-firmware-m/trusted-firmware-m_%.bbappend`` | +----------+-------------------------------------------------------------------------------------------------------+ | Recipe | ``${WORKSPACE}/meta-arm/meta-arm/recipes-bsp/trusted-firmware-m/trusted-firmware-m_2.2.1.bb`` | +----------+-------------------------------------------------------------------------------------------------------+ ************************************ External System Processor Components ************************************ RTX Real-Time operating system ============================== An example application that uses the `RTX Real-Time Operating System `__. The application project can be found `here `__. +----------+----------------------------------------------------------------------------------------------+ | Recipe | ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-bsp/external-system/external-system_0.1.0.bb`` | +----------+----------------------------------------------------------------------------------------------+ .. _building-the-software-stack: Build ----- .. warning:: Building binaries natively on Windows and AArch64 Linux is not supported. Use an Intel or AMD 64-bit architecture Linux based development machine to build the software stack and transfer the binaries to run the software stack on an FVP in Windows or AArch64 Linux if required. #. Create a new folder that will be your workspace. .. code-block:: console mkdir ${WORKSPACE} cd ${WORKSPACE} #. Install kas version 4.4 with ``sudo`` rights. .. code-block:: console sudo pip3 install kas==4.4 Ensure the kas installation directory is visible on the ``$PATH`` environment variable. #. Clone the `meta-arm` Yocto layer in the workspace ``${WORKSPACE}``. .. code-block:: console cd ${WORKSPACE} git clone https://git.yoctoproject.org/git/meta-arm -b CORSTONE1000-2025.12 #. Build a Corstone-1000 image: .. code-block:: console kas build meta-arm/kas/corstone1000-${TARGET}.yml:meta-arm/ci/debug.yml .. important:: Accept the EULA at https://developer.arm.com/downloads/-/arm-ecosystem-fvps/eula to build a Corstone-1000 image for FVP as follows: .. code-block:: console export ARM_FVP_EULA_ACCEPT="True" .. warning:: **The External System Processor is not available on the Corstone-1000 with Cortex-A320 FVP.** Access to the External System Processor is disabled by default on **Corstone-1000 with Cortex-A35**. To build the Corstone-1000 image with External System Processor enabled, run: .. code-block:: console kas build meta-arm/kas/corstone1000-${TARGET}.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-extsys.yml .. warning:: **The Ethos-U85 Neural Processing Unit (NPU) is only available on the Corstone-1000 with Cortex-A320 FVP.** To build the Corstone-1000 image with the Ethos-U85 NPU enabled, run: .. code-block:: console kas build meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-a320.yml A clean build takes a significant amount of time given that all of the development machine utilities are also built along with the target images. Those development machine utilities include executables (Python, CMake, etc.) and the required toolchains. Once the build succeeds, all output binaries will be placed in ``${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/`` Everything apart from the Secure Enclave ROM firmware and External System firmware, is bundled into a single binary, the ``corstone1000-flash-firmware-image-corstone1000-${TARGET}.wic`` file. The output binaries run in the Corstone-1000 platform are the following: - The Secure Enclave ROM firmware: ``${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/bl1.bin`` - The External System Processor firmware: ``${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/es_flashfw.bin`` - The internal firmware flash image: ``${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000-flash-firmware-image-corstone1000-${TARGET}.wic`` .. _flashing-firmware-images: Flash ----- .. note:: The steps below only apply to the MPS3. The FVP being a software application running on your development machine does not require any firmware flashing. Refer to `this `__ section for running the software stack on FVP. .. important:: When preparing the SD card for flashing, ensure that it is at least 4GB in size and formatted with a FAT32 partition. Using smaller cards or unsupported file systems (e.g., exFAT, NTFS) may cause the flashing process to fail or the device to become unresponsive. #. Download the FPGA bit file image ``AN550: Arm® Corstone™-1000 for MPS3 Version 2.0`` on the `Arm Developer website `__. Click on the ``Download AN550 bundle`` button and login to download the file. The directory structure of the FPGA bundle is as shown below: .. code-block:: console Boardfiles ├── config.txt ├── MB │   ├── BRD_LOG.TXT │   ├── HBI0309B │   │   ├── AN550 │   │   │   ├── AN550_v2.bit │   │   │   ├── an550_v2.txt │   │   │   └── images.txt │   │   ├── board.txt │   │   └── mbb_v210.ebf │   └── HBI0309C │   ├── AN550 │   │   ├── AN550_v2.bit │   │   ├── an550_v2.txt │   │   └── images.txt │   ├── board.txt │   └── mbb_v210.ebf └── SOFTWARE ├── an550_st.axf ├── bl1.bin ├── cs1000.bin └── ES0.bin #. Depending upon the MPS3 board version, you should update the ``images.txt`` file (found in the corresponding ``HBI0309x`` folder e.g. ``Boardfiles/MB/HBI0309${BOARD_VERSION}/AN550/images.txt``) so it points to the images under the ``SOFTWARE`` directory. Where ``${BOARD_VERSION}`` is a variable containing the board printed on the MPS3 board. The ``images.txt`` file compatible with the latest version of the software stack can be seen below; .. code-block:: console ;************************************************ ; Preload port mapping * ;************************************************ ; PORT 0 & ADDRESS: 0x00_0000_0000 QSPI Flash (XNVM) (32MB) ; PORT 0 & ADDRESS: 0x00_8000_0000 OCVM (DDR4 2GB) ; PORT 1 Secure Enclave (M0+) ROM (64KB) ; PORT 2 External System 0 (M3) Code RAM (256KB) ; PORT 3 Secure Enclave OTP memory (8KB) ; PORT 4 CVM (4MB) ;************************************************ [IMAGES] TOTALIMAGES: 3 ;Number of Images (Max: 32) IMAGE0PORT: 1 IMAGE0ADDRESS: 0x00_0000_0000 IMAGE0UPDATE: RAM IMAGE0FILE: \SOFTWARE\bl1.bin IMAGE1PORT: 0 IMAGE1ADDRESS: 0x00_0000_0000 IMAGE1UPDATE: AUTOQSPI IMAGE1FILE: \SOFTWARE\cs1000.bin IMAGE2PORT: 2 IMAGE2ADDRESS: 0x00_0000_0000 IMAGE2UPDATE: RAM IMAGE2FILE: \SOFTWARE\es0.bin #. Copy ``bl1.bin`` from ``${WORKSPACE}/build/tmp/deploy/images/corstone1000-mps3`` to the ``SOFTWARE`` directory of the FPGA bundle. #. Copy ``es_flashfw.bin`` from ``${WORKSPACE}/build/tmp/deploy/images/corstone1000-mps3`` to the ``SOFTWARE`` directory of the FPGA bundle and rename the binary to ``es0.bin``. #. Copy ``corstone1000-flash-firmware-image-corstone1000-mps3.wic`` from ``${WORKSPACE}/build/tmp/deploy/images/corstone1000-mps3`` to the ``SOFTWARE`` directory of the FPGA bundle and rename the wic image to ``cs1000.bin``. .. note:: Renaming of the images is required because the MCC firmware has a limit of 8 characters for file name and 3 characters for file extension. After making all modifications above, copy the FPGA bit file bundle to the board's SDCard and reboot the MPS3. Run --- .. _running-software-stack-mps3: Once the target is turned ON, the Secure Enclave will start to boot, wherein the relevant memory contents of the ``*.wic`` file are copied to their respective memory locations. Firewall policies are enforced on memories and peripherals before bringing the Host Processor out of reset. The Host Processor will boot TrustedFirmware-A, OP-TEE, U-Boot and then Linux before presenting a login prompt. **** MPS3 **** 1. Open 4 serial port comms terminals on the host machine. Those might be ``ttyUSB0``, ``ttyUSB1``, ``ttyUSB2``, and ``ttyUSB3`` on Linux machines. - ``ttyUSB0`` for MCC, OP-TEE and Secure Partition - ``ttyUSB1`` for Secure Enclave (Cortex-M0+) - ``ttyUSB2`` for Host Processor (Cortex-A35) - ``ttyUSB3`` for External System Processor (Cortex-M3) The serial ports might be different on Windows machines. Run the following commands in separate terminal instances on Linux: .. code-block:: console sudo picocom -b 115200 /dev/ttyUSB0 .. code-block:: console sudo picocom -b 115200 /dev/ttyUSB1 .. code-block:: console sudo picocom -b 115200 /dev/ttyUSB2 .. code-block:: console sudo picocom -b 115200 /dev/ttyUSB3 .. important:: Plug a connected Ethernet cable to the MPS3 or it will wait for a network connection for a considerable amount of time, printing the following on the Host Processor terminal (``ttyUSB2``): .. code-block:: console Generic PHY 40100000.ethernet-ffffffff:01: attached PHY driver (mii_bus:phy_addr=40100000.ethernet-ffffffff:01, irq=POLL) smsc911x 40100000.ethernet eth0: SMSC911x/921x identified at 0xffffffc008e50000, IRQ: 17 Waiting up to 100 more seconds for network. 2. Once the system boot is completed, you should see console logs on the serial port terminals. Once the Host Processor is booted completely, user can login to the shell using ``root`` login. .. important:: The secure flash might be completely filled if the system does not boot and only the Secure Enclave logs (``ttyUSB1``) are visible. Clean the secure flash if that is the case following the steps `here `__. .. _running-software-stack-fvp: *** FVP *** A Fixed Virtual Platform (FVP) model of the Corstone-1000 platform must be available to run the Corstone-1000 FVP software image. A Yocto recipe is provided to download the latest supported FVP version. The recipe is located at ``${WORKSPACE}/meta-arm/meta-arm/recipes-devtools/fvp/fvp-corstone1000.bb``. This recipe supports selecting different Corstone‑1000 FVP models via MACHINE_FEATURES: - ``cortexa320`` use the Cortex-A320 Host Processor with Ethos U85 enabled FVP build - (default) use the Cortex-A35 Host Processor with Cortex-M3 External System FVP build The latest FVP version is ``11.23.25`` for Corstone-1000 with Cortex-A35 and ``11.30.27`` for Corstone-1000 with Cortex-A320, and each model is automatically downloaded and installed when using the ``runfvp`` command as detailed below. .. note:: .. code-block:: console kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml \ -c "../meta-arm/scripts/runfvp -- --version" The FVP can also be manually downloaded from `Arm Developer `__ to download the Corstone-1000 platform FVP installer. Follow the instructions of the installer to setup the FVP. #. Run ``tmux``: .. code-block:: console cd ${WORKSPACE} && tmux #. Run the FVP within ``tmux``: .. code-block:: console kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml \ -c "../meta-arm/scripts/runfvp --terminals=tmux" When the script is executed, three terminal instances will be launched: - one for the Secure Enclave processing element - two for the Host processor processing element. .. code-block:: console corstone1000-fvp login: #. Login using the ``root`` username. Security Issue Reporting ------------------------ To report any security issues identified with Corstone-1000, please send an email to psirt@arm.com. ##### Tests ##### .. important:: All the tests below assume you have already built the software stack at least once following the instructions `here `__. Reports ------- Reports for the tests conducted on the `Corstone-1000 software (CORSTONE1000-2025.12) `__ release are available for reference `here `__. .. _clean-secure-flash: Clean Secure Flash ------------------ .. important:: The MPS3 secure flash needs to be cleared before running tests. This is to erase the flash cleanly and prepare a clean board environment for testing. #. Clone the `systemready-patch` repository to your ${WORKSPACE}. .. code-block:: console cd ${WORKSPACE} git clone https://git.gitlab.arm.com/arm-reference-solutions/systemready-patch.git -b CORSTONE1000-2025.12 #. Copy the secure flash cleaning Git patch file to your copy of `meta-arm`. .. code-block:: console cp -f systemready-patch/embedded-a/corstone1000/erase_flash/0001-embedded-a-corstone1000-clean-secure-flash.patch meta-arm #. Apply the Git patch to `meta-arm`. .. code-block:: console cd meta-arm git apply 0001-embedded-a-corstone1000-clean-secure-flash.patch #. Rebuild the software stack. .. code-block:: console cd ${WORKSPACE} kas shell meta-arm/kas/corstone1000-mps3.yml:meta-arm/ci/debug.yml bitbake -c cleansstate trusted-firmware-m corstone1000-flash-firmware-image bitbake -c build corstone1000-flash-firmware-image #. Replace the ``bl1.bin`` file on the SD card with ``${WORKSPACE}/build/tmp/deploy/images/corstone1000-mps3/bl1.bin``. #. Reboot the board to completely erase the secure flash. The following message log from TrustedFirmware-M should be displayed on the Secure Enclave terminal (``ttyUSB1``): .. code-block:: console !!!SECURE FLASH HAS BEEN CLEANED!!! NOW YOU CAN FLASH THE ACTUAL CORSTONE1000 IMAGE PLEASE REMOVE THE LATEST ERASE SECURE FLASH PATCH AND BUILD THE IMAGE AGAIN #. Whilst still in the ``kas`` shell, revert the changes the patch introduced by running the following commands: .. code-block:: console cd ${WORKSPACE}/meta-arm git reset --hard cd .. bitbake -c cleansstate trusted-firmware-m corstone1000-flash-firmware-image exit #. Follow the `instructions `__ to build a clean software stack and flash the MPS3 with it. You can proceed with the test instructions in the following section after having done all the above. SystemReady IR -------------- .. important:: **SystemReady IR** has now been renamed **SystemReady Devicetree Band**. Running the tests described below requires USB drives. In our testing, not all USB drive models worked well with the MPS3. Here are the USB drive models that were stable in our test environment: - HP v165w 8 GB USB Flash Drive - SanDisk Ultra 32GB Dual USB Flash Drive USB M3.0 - SanDisk Ultra 16GB Dual USB Flash Drive USB M3.0 Follow the instructions below before running the Architecture Compliance Suite (ACS) tests. .. _build-efi-system-partition: ***************************** Build an EFI System Partition ***************************** A storage with EFI System Partition (ESP) must exist in the system for the UEFI-SCT related tests to pass. #. Build an ESP partition for your target .. code-block:: console kas build meta-arm/kas/corstone1000-${TARGET}.yml:meta-arm/ci/debug.yml --target corstone1000-esp-image #. Locate the ``corstone1000-esp-image-corstone1000-${TARGET}.wic`` build artefact in ``${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/`` **************************** Use the EFI System Partition **************************** .. _use-efi-system-partition-mps3: MPS3 ==== #. Connect a USB drive to your development machine. #. Run the following command on your development machine to discover which device is your USB drive: .. code-block:: console lsblk The remaining steps assume the USB drive is ``/dev/sdb``. .. warning:: Do not mistake your development machine hard drive with the USB drive. #. Copy the ESP to the USB drive by running the following command: .. code-block:: console sudo dd \ if=${WORKSPACE}/build/tmp/deploy/images/corstone1000-mps3/corstone1000-esp-image-corstone1000-mps3.wic \ of=/dev/sdb \ iflag=direct oflag=direct status=progress bs=512; sync; #. Plug the USB drive to the MPS3. .. _use-efi-system-partition-fvp: FVP === The ESP disk image will automatically be used by the Corstone-1000 FVP as the 2nd MMC card image. It will be used when the SystemReady-IR tests is performed on the FVP in the later section. **************************** Run SystemReady IR ACS Tests **************************** ACS is used to ensure architectural compliance across different implementations of the architecture. Arm Enterprise ACS includes a set of examples of the invariant behaviors that are provided by a set of specifications for enterprise systems (i.e. SBSA, SBBR, etc.). Implementers can verify if these behaviors have been interpreted correctly. The following test suites and bootable applications are under the ``BOOT`` partition of the ACS image: * SCT * FWTS * BSA UEFI * BSA linux * GRUB * UEFI manual capsule application See the directory structure of the ACS image ``BOOT`` partition below: .. code-block:: console ├── acs_results ├── EFI │ └── BOOT │ ├── app │ ├── bbr │ ├── bootaa64.efi │ ├── bsa │ ├── debug │ ├── grub.cfg │ ├── Shell.efi │ ├── sie_startup.nsh │ └── startup.nsh ├── Image ├── security-interface-extension-keys │ ├── NullPK.auth │ ├── TestDB1.auth │ ├── TestDB1.der │ ├── TestDBX1.auth │ ├── TestDBX1.der │ ├── TestKEK1.auth │ ├── TestKEK1.der │ ├── TestPK1.auth │ └── TestPK1.der ├── startup.nsh └── yocto_image.flag The ``BOOT`` partition is also used to store test results in the ``acs_results`` folder. .. important:: Ensure that the ``acs_results`` folder is empty before starting the test. This sections below describe how to build and run ACS tests on Corstone-1000. .. _mps3-instructions-for-acs-image: #. On your host development machine, clone the `Arm SystemReady ACS repository `_. .. code-block:: console cd ${WORKSPACE} git clone https://github.com/ARM-software/arm-systemready.git -b v23.09_SR_REL2.0.0_ES_REL1.3.0_IR_REL2.1.0 --depth 1 This repository contains the infrastructure to build the ACS and the bootable prebuilt images to be used for the certifications of SystemReady IR. #. Find the pre-built ACS live image in ``${WORKSPACE}/arm-systemready/IR/prebuilt_images/v23.09_2.1.0/ir-acs-live-image-generic-arm64.wic.xz``. .. note:: This prebuilt ACS image includes v5.13 kernel, which does not provide USB driver support for Corstone-1000. #. Decompress the pre-built ACS live image. .. code-block:: console cd ${WORKSPACE}/arm-systemready/IR/prebuilt_images/v23.09_2.1.0 unxz ir-acs-live-image-generic-arm64.wic.xz MPS3 ==== #. Connect a USB drive (other than the one used for the ESP) to the host development machine. #. Run the following command to discover which device is your USB drive: .. code-block:: console lsblk The remaining steps assume the USB drive is ``/dev/sdc``. .. warning:: Do not mistake your development machine hard drive with the USB drive. #. Copy the ACS image to the USB drive by running the following commands: .. code-block:: console cd ${WORKSPACE}/arm-systemready/IR/prebuilt_images/v23.09_2.1.0 sudo dd if=ir-acs-live-image-generic-arm64.wic of=/dev/sdc iflag=direct oflag=direct bs=1M status=progress; sync #. Plug the USB drive to the MPS3. At this point you should have both the USB drive with the ESP and the USB drive with the ACS image plugged to the MPS3. #. Reboot the MPS3. The MPS3 will reset multiple times during the test, and it might take approximately 24 to 36 hours to finish the test. .. important:: Unplug the ESP USB drive from the MPS3 if it is preventing GRUB from finding the bootable partition. Leave only the ACS image USB drive plugged in to run the ACS tests. The ESP USB drive can be plugged in again after selecting the `Linux Boot` option in the GRUB menu at the end of the ACS tests. .. warning:: A timeout issue has been observed while booting Linux during the ACS tests, causing the system to boot into emergency mode. Booting Linux is necessary to run certain tests, such as `dt-validation`. The following workaround is required to enable Linux to boot properly and perform all Linux-based tests: #. Press Enter at the Linux prompt. #. Open the file `/etc/systemd/system.conf` and set `DefaultDeviceTimeoutSec=infinity`. #. Reboot the platform using the `reboot` command. #. Select the `Linux Boot` option from the GRUB menu. #. Allow Linux to boot and run the remaining ACS tests until completion. .. _fvp-instructions-for-acs-image: FVP === #. Run ``tmux``: .. code-block:: console cd ${WORKSPACE} && tmux #. Run the commands below within ``tmux`` to run the ACS test on FVP using the built firmware image and the pre-built ACS image identified above: .. code-block:: console ./meta-arm/scripts/runfvp \ --terminals=tmux \ ./build/tmp/deploy/images/corstone1000-fvp/corstone1000-flash-firmware-image-corstone1000-fvp.fvpconf \ -- -C board.msd_mmc.p_mmc_file=${WORKSPACE}/arm-systemready/IR/prebuilt_images/v23.09_2.1.0/ir-acs-live-image-generic-arm64.wic .. note:: The FVP will reset multiple times during the test. The ACS tests might take up to 1 day to complete when run on FVP. The message `ACS run is completed` will be displayed on the FVP host terminal when the test runs to completion. You will be prompted to press the Enter key to access the Linux prompt. Test Sequence and Results ========================= U-Boot should be able to boot the GRUB bootloader from the first partition. If GRUB is not interrupted, the tests are executed automatically in the following order: - SCT - UEFI BSA - FWTS The results can be fetched from the `acs_results` folder in the ``BOOT`` partition of the USB drive (for MPS3) or SD Card (for FVP). .. note:: Access the `acs_results` folder in FVP by running the following commands: .. code-block:: console sudo mkdir /mnt/test sudo mount -o rw,offset=1048576 \ ${WORKSPACE}/arm-systemready/IR/prebuilt_images/v23.09_2.1.0/ir-acs-live-image-generic-arm64.wic \ /mnt/test ##################################################### Capsule Update -------------- .. warning:: The **Corstone-1000 with Cortex-A320 FVP** becomes unresponsive when the Linux kernel driver for the Ethos-U85 NPU loads automatically after a software reboot. This behavior results from a power reset control issue in the **Corstone-1000 with Cortex-A320 FVP** model. To prevent the failure and complete the test successfully, rebuild the **Corstone-1000 with Cortex-A320** firmware image using the following steps: #. Clone the `systemready-patch` repository to your ``${WORKSPACE}``. .. code-block:: console cd ${WORKSPACE} git clone https://git.gitlab.arm.com/arm-reference-solutions/systemready-patch.git \ -b CORSTONE1000-2025.12 #. Re-Build the **Corstone-1000 with Cortex-A320 FVP** software stack as follows: .. code-block:: console kas build meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-a320.yml:\ systemready-patch/embedded-a/corstone1000/disable_module_autoloading/disable_module_autoloading.yml .. important:: Payload GUIDs (``${BL2_GUID}``, ``${TFM_S_GUID}``, ``${FIP_GUID}``, and ``${INITRAMFS_GUID}``) are different depending on whether the capsule is built for the ``fvp`` or ``mps3`` ``${TARGET}``. +------------+----------------------------------------+----------------------------------------+ | Payloads | FVP | MPS3 | +============+========================================+========================================+ | BL2 | f1d883f9-dfeb-5363-98d8-686ee3b69f4f | fbfbefaa-0a56-50d5-b651-74091d3d62cf | +------------+----------------------------------------+----------------------------------------+ | TFM_S | 7fad470e-5ec5-5c03-a2c1-4756b495de61 | af4cc7ad-ee2e-5a39-aad5-fac8a1e6173c | +------------+----------------------------------------+----------------------------------------+ | FIP | f1933675-5a8c-5b6d-9ef4-846739e89bc8 | 55302f96-c4f0-5cf9-8624-e7cc388f2b68 | +------------+----------------------------------------+----------------------------------------+ | INITRAMFS | f771aff9-c7e9-5f99-9eda-2369dd694f61 | 3e8ac972-c33c-5cc9-90a0-cdd3159683ea | +------------+----------------------------------------+----------------------------------------+ The following section describes the steps to update the firmware using Capsule Update as the Corstone-1000 supports UEFI. The firmware update process is tested with an invalid capsule and with valid capsules to validate the robustness and error-handling capabilities of the firmware update mechanism. **Positive full capsule update test:** The Corstone-1000 is provided with a valid full capsule, which it applies successfully. The system then boots normally and reaches the Linux command prompt. **Positive partial capsule update test:** The Corstone-1000 is provided with a valid partial capsule that specifies an update for a single component only. The capsule is applied successfully, after which the system boots normally and reaches the Linux command prompt. **Rollback protection capsule update test:** The Corstone-1000 is provided with an outdated capsule containing lower version numbers for all payloads. The capsule is correctly rejected due to rollback protection, and the previously installed firmware is retained. Three different capsules are therefore needed to perform the tests. The following payloads can be individually updated: - Boot Loader stage 2 (BL2) - Trusted Firmware-M Secure partition (TFM_S) - Firmware Image Package (FIP) - Initial RAM Filesystem (INITRAMFS) ***************** Generate Capsules ***************** `EDK II's `__ ``GenerateCapsule`` tool is used to generate capsules and is built automatically for the host machine during the firmware image building process. The tool can be found at ``${WORKSPACE}/build/tmp/sysroots-components/aarch64/edk2-basetools-native/usr/bin/edk2-BaseTools/BinWrappers/PosixLike/GenerateCapsule``. A JSON file containing metadata about the capsule payloads needs to be created using the script found at ``${WORKSPACE}/meta-arm/meta-arm/scripts/generate_capsule_json_multiple.py``. This JSON file is required by EDK II's ``GenerateCapsule`` tool to generate the capsule. The capsule's default metadata passed can be found in the ``${WORKSPACE}/meta-arm/meta-arm-bsp/recipes-bsp/images/corstone1000-flash-firmware-image.bb`` and ``${WORKSPACE}/meta-arm/kas/corstone1000-image-configuration.yml`` files. Valid Full Capsule ================== An automatically generated capsule can be found at ``${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000-${TARGET}-v6.uefi.capsule`` after running a firmware build. The default metadata values are assumed to be correct to generate a valid capsule. This capsule will be used for the positive capsule update test. Valid Partial Capsule ===================== To generate a capsule that updates only a single component, explicitly set the firmware version for that component and mark it as the only payload to be updated. The **partial capsule** is also valid, but sets the firmware version to **7** **only** for the **BL2** component, indicating that no other components should be updated. Use the following commands to generate the `capsule_config.json` file, which is required by the EDK2 tool for capsule creation: .. code-block:: console cd ${WORKSPACE} python3 meta-arm/meta-arm/scripts/generate_capsule_json_multiple.py \ --selected_components DUMMY_START BL2 DUMMY_END \ --components DUMMY_START BL2 TFM_S FIP INITRAMFS DUMMY_END \ --fw_versions 0 7 0 0 0 0 \ --guids \ 6f784cbf-7938-5c23-8d6e-24d2f1410fa9 \ ${BL2_GUID} ${TFM_S_GUID} ${FIP_GUID} ${INITRAMFS_GUID} \ b57e432b-a250-5c73-93e3-90205e64baba \ --hardware_instances 1 1 1 1 1 1 \ --lowest_supported_versions 5 5 5 5 5 5 \ --monotonic_counts 1 1 1 1 1 1 \ --payloads \ build/tmp/work/corstone1000_${TARGET}-poky-linux-musl/corstone1000-flash-firmware-image/1.0/sources/corstone1000-flash-firmware-image-1.0/dummy.bin \ build/tmp/deploy/images/corstone1000-${TARGET}/bl2_signed.bin \ build/tmp/deploy/images/corstone1000-${TARGET}/tfm_s_signed.bin \ build/tmp/deploy/images/corstone1000-${TARGET}/signed_fip-corstone1000.bin \ build/tmp/deploy/images/corstone1000-${TARGET}/Image.gz-initramfs-corstone1000-${TARGET}.bin \ build/tmp/work/corstone1000_${TARGET}-poky-linux-musl/corstone1000-flash-firmware-image/1.0/sources/corstone1000-flash-firmware-image-1.0/dummy.bin \ --update_image_indexes 5 1 2 3 4 6 \ --private_keys \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_key.key \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_key.key \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_key.key \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_key.key \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_key.key \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_key.key \ --certificates \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_cert.crt \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_cert.crt \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_cert.crt \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_cert.crt \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_cert.crt \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_cert.crt \ --output capsule_config.json Run the command below to generate the partial capsule: .. code-block:: console ./build/tmp/sysroots-components/aarch64/edk2-basetools-native/usr/bin/edk2-BaseTools/BinWrappers/PosixLike/GenerateCapsule \ -e \ -j capsule_config.json \ --capflag PersistAcrossReset \ -o corstone1000-${TARGET}-partial-v7.uefi.capsule The partial capsule will be located in the ``${WORKSPACE}`` directory. Invalid Capsule =============== Generate a capsule with firmware version metadata for all payloads set lower than that of a valid capsule. The valid capsule has a default firmware version of 6 for all payloads, while the simulated invalid capsule has the firmware version set to 5 for all payloads. Use the following commands to generate the `capsule_config.json` file, which is required by the EDK2 tool for capsule creation: .. code-block:: console cd ${WORKSPACE} python3 meta-arm/meta-arm/scripts/generate_capsule_json_multiple.py \ --selected_components DUMMY_START BL2 TFM_S FIP INITRAMFS DUMMY_END \ --components DUMMY_START BL2 TFM_S FIP INITRAMFS DUMMY_END \ --fw_versions 5 5 5 5 5 5 \ --guids \ 6f784cbf-7938-5c23-8d6e-24d2f1410fa9 \ ${BL2_GUID} ${TFM_S_GUID} ${FIP_GUID} ${INITRAMFS_GUID} \ b57e432b-a250-5c73-93e3-90205e64baba \ --hardware_instances 1 1 1 1 1 1 \ --lowest_supported_versions 5 5 5 5 5 5 \ --monotonic_counts 1 1 1 1 1 1 \ --payloads \ build/tmp/work/corstone1000_${TARGET}-poky-linux-musl/corstone1000-flash-firmware-image/1.0/sources/corstone1000-flash-firmware-image-1.0/dummy.bin \ build/tmp/deploy/images/corstone1000-${TARGET}/bl2_signed.bin \ build/tmp/deploy/images/corstone1000-${TARGET}/tfm_s_signed.bin \ build/tmp/deploy/images/corstone1000-${TARGET}/signed_fip-corstone1000.bin \ build/tmp/deploy/images/corstone1000-${TARGET}/Image.gz-initramfs-corstone1000-${TARGET}.bin \ build/tmp/work/corstone1000_${TARGET}-poky-linux-musl/corstone1000-flash-firmware-image/1.0/sources/corstone1000-flash-firmware-image-1.0/dummy.bin \ --update_image_indexes 5 1 2 3 4 6 \ --private_keys \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_key.key \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_key.key \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_key.key \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_key.key \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_key.key \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_key.key \ --certificates \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_cert.crt \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_cert.crt \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_cert.crt \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_cert.crt \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_cert.crt \ build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000_capsule_cert.crt \ --output capsule_config.json Run the command below to generate the invalid capsule: .. code-block:: console ./build/tmp/sysroots-components/aarch64/edk2-basetools-native/usr/bin/edk2-BaseTools/BinWrappers/PosixLike/GenerateCapsule \ -e \ -j capsule_config.json \ --capflag PersistAcrossReset \ -o corstone1000-${TARGET}-v5.uefi.capsule The invalid capsule will be located in the ``${WORKSPACE}`` directory. *************************** Transfer Capsules to Target *************************** The capsule delivery process described below is the direct method (usage of capsules from the ACS image) as opposed to the on-disk method (delivery of capsules using a file on a mass storage device). MPS3 ==== #. Prepare a USB drive as explained in `this `_ section. #. Copy the capsule file to the root directory of the ``BOOT`` partition in the USB drive. .. code-block:: console cp ${WORKSPACE}/build/tmp/deploy/images/corstone1000-mps3/corstone1000-mps3-v6.uefi.capsule /dev/sdc/BOOT/ cp ${WORKSPACE}/corstone1000-mps3-v5.uefi.capsule /dev/sdc/EFI/BOOT/ cp ${WORKSPACE}/corstone1000-mps3-partial-v7.uefi.capsule /dev/sdc/EFI/BOOT/ sync .. note:: ``/dev/sdc`` is the assumed path for the ACS Image USB drive. Replace it with the actual device path as enumerated on your development machine. .. important:: The direct Capsule Update method requires that the capsule files not be placed in the ``EFI/UpdateCapsule`` directory, as doing so might inadvertently trigger the on-disk update method. FVP === #. Download and extract the ACS image `as described for the MPS3 `_. The ACS image extraction location will be referred below as ``${ACS_IMAGE_PATH}``. .. note:: Creating a USB drive with the ACS image is not required as the image will be mounted with the steps below. #. Find the first partition's offset of the ``ir-acs-live-image-generic-arm64.wic`` image using the ``fdisk`` tool. The partition table can be listed using: .. code-block:: console fdisk -lu ${ACS_IMAGE_PATH}/ir-acs-live-image-generic-arm64.wic Device Start End Sectors Size Type ${ACS_IMAGE_PATH}/ir-acs-live-image-generic-arm64.wic1 2048 309247 307200 150M Microsoft basic data ${ACS_IMAGE_PATH}/ir-acs-live-image-generic-arm64.wic2 309248 1343339 1034092 505M Linux filesystem Given that the first partition starts at sector 2048 and each sector is 512 bytes in size, the first partition is at offset 1048576 (2048 x 512). #. Mount the ``ir-acs-live-image-generic-arm64.wic`` image using the previously calculated offset: .. code-block:: console sudo mkdir /mnt/ir-acs-live-image-generic-arm64 sudo mount -o rw,offset= ${ACS_IMAGE_PATH}/ir-acs-live-image-generic-arm64.wic /mnt/ir-acs-live-image-generic-arm64 #. Copy the capsules: .. code-block:: console sudo cp ${WORKSPACE}/build/tmp/deploy/images/corstone1000-fvp/corstone1000-fvp-v6.uefi.capsule /mnt/ir-acs-live-image-generic-arm64/ sudo cp ${WORKSPACE}/corstone1000-fvp-v5.uefi.capsule /mnt/ir-acs-live-image-generic-arm64/ sudo cp ${WORKSPACE}/corstone1000-fvp-partial-v7.uefi.capsule /mnt/ir-acs-live-image-generic-arm64/ sync #. Unmount the IR image: .. code-block:: console sudo umount /mnt/ir-acs-live-image-generic-arm64 ************************ Run Capsule Update Tests ************************ The valid capsules will be used first to run the positive capsule update tests. This will be followed by using the invalid capsule to run the rollback protection capsule update test. .. important:: This sequence order must be respected as the invalid capsule has a firmware version lower than the firmware version in the valid capsule. The rollback protection capsule update test effectively tests that firmware rollback is not permitted. .. _positive-full-capsule-update-test: Positive Full Capsule Update Test ================================= #. Run Corstone-1000 with the ACS image containing the two capsule files: - MPS3: #. Plug the prepared USB drive which has the IR prebuilt image and two capsules to the MPS3. #. Power cycle the MPS3. - FVP: #. Run ``tmux``: .. code-block:: console cd ${WORKSPACE} && tmux #. Run the FVP within ``tmux`` with the IR prebuilt image which now also contains the two capsules: .. code-block:: console kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml \ -c "../meta-arm/scripts/runfvp --terminals=tmux \ -- -C board.msd_mmc.p_mmc_file=${ACS_IMAGE_PATH}/ir-acs-live-image-generic-arm64.wic" .. warning:: ``${ACS_IMAGE_PATH}`` must be an absolute path. Ensure there are no spaces before or after of ``=`` of the ``-C board.msd_mmc.p_mmc_file`` option. #. Wait until U-Boot loads EFI from the ACS image and interrupt the EFI shell by pressing the ``Escape`` key when the following prompt is displayed on the Host Processor terminal (``ttyUSB2`` for MPS3). .. code-block:: console Press ESC in 4 seconds to skip startup.nsh or any other key to continue. #. The content of the first file system (``File System 0``), where the capsule files were copied, can be accessed by running the following command: .. code-block:: console FS0: #. Run the ``CapsuleApp`` application with the valid capsule file: - MPS3: .. code-block:: console EFI/BOOT/app/CapsuleApp.efi EFI/BOOT/corstone1000-mps3-v6.uefi.capsule - FVP: .. code-block:: console EFI/BOOT/app/CapsuleApp.efi corstone1000-fvp-v6.uefi.capsule The capsule update will be started. .. note:: The capsule update takes about 8 minutes to complete on MPS3 and between 15-30 minutes on FVP. The Corstone-1000 will reset after successfully applying the capsule. The software stack copies the capsule content to the external flash, which is shared between the Secure Enclave and the Host Processor before rebooting the system. After the first reboot, TrustedFirmware-M should apply the valid capsule and display the following log on the Secure Enclave terminal (``ttyUSB1`` for MPS3) before rebooting the system a second time: .. code-block:: console ... SysTick_Handler: counted = 10, expiring on = 360 SysTick_Handler: counted = 20, expiring on = 360 SysTick_Handler: counted = 30, expiring on = 360 ... metadata_write: success: active = 1, previous = 0 flash_full_capsule: exit corstone1000_fwu_flash_image: exit: ret = 0 ... The above log snippet indicates that the new capsule image is successfully applied, and the board is booting with the external flash's Bank-1. After a second reboot, the following log should be displayed on on the Secure Enclave terminal (``ttyUSB1``): .. code-block:: console ... fmp_set_image_info:133 Enter FMP image update: image id = 0 FMP image update: status = 0version=6 last_attempt_version=6. fmp_set_image_info:157 Exit. corstone1000_fwu_host_ack: exit: ret = 0 ... #. Interrupt the U-Boot shell. .. code-block:: console Hit any key to stop autoboot: #. Run the following commands in order to run the Corstone-1000 Linux kernel. .. note:: Otherwise, the execution ends up in the ACS live image. .. code-block:: console $ unzip $kernel_addr 0x90000000 $ loadm 0x90000000 $kernel_addr_r $filesize $ bootefi $kernel_addr_r $fdtcontroladdr #. The first boot after a capsule update is considered the trial stage, during which the FWU image is accepted. However, to view the updated contents of the EFI System Resource Table (ESRT), an additional reboot is required. .. code-block:: console # reboot #. Interrupt the U-Boot shell when prompted. .. code-block:: console Hit any key to stop autoboot: #. Run the following commands to boot the Corstone-1000 Linux kernel. .. note:: If these commands are not executed, the system will default to booting into the ACS live image. .. code-block:: console $ unzip $kernel_addr 0x90000000 $ loadm 0x90000000 $kernel_addr_r $filesize $ bootefi $kernel_addr_r $fdtcontroladdr #. Once the system has fully booted again, `read the ESRT `__ to confirm that the firmware version reflects the updated capsule. .. warning:: Do not terminate FVP between the positive full capsule update and partial capsule update tests. .. _positive-partial-capsule-update-test: Positive Partial Capsule Update Test ==================================== Follow the steps for the `positive full capsule update test `__ ensuring you use ``corstone1000-${TARGET}-partial-v7.uefi.capsule`` instead of ``corstone1000-${TARGET}-v6.uefi.capsule``. Once the system has fully booted again, `read the ESRT `__ to confirm that the firmware version reflects the updated capsule. .. warning:: Do not terminate FVP between the positive partial capsule update rollback protection capsule update tests. Rollback Protection Capsule Update Test ======================================= .. important:: The `positive partial capsule update test `__ must be run before running the rollback protection capsule update test. #. After running the positive capsule update test, reboot the system by typing the following command on the Host Processor terminal (``ttyUSB2`` for MPS3): .. code-block:: console reboot #. Wait until U-Boot loads EFI from the ACS image and interrupt the EFI shell by pressing the ``Escape`` key when the following prompt is displayed on the Host Processor terminal (``ttyUSB2`` for MPS3). .. code-block:: console Press ESC in 4 seconds to skip startup.nsh or any other key to continue. #. The content of the first file system (``File System 0``), where the capsule files were copied, can be accessed by running the following command: .. code-block:: console FS0: #. Run the ``CapsuleApp`` application with the invalid capsule file: - MPS3: .. code-block:: console EFI/BOOT/app/CapsuleApp.efi EFI/BOOT/corstone1000-mps3-v5.uefi.capsule - FVP: .. code-block:: console EFI/BOOT/app/CapsuleApp.efi corstone1000-fvp-v5.uefi.capsule #. TrustedFirmware-M should reject the capsule due to having a lower firmware version and display the following log on the Secure Enclave terminal (``ttyUSB1`` for MPS3): .. code-block:: console ... uefi_capsule_retrieve_images: image 0 at 0xa0000070, size=15654928 uefi_capsule_retrieve_images: exit flash_full_capsule: enter: image = 0x0xa0000070, size = 7764541, version = 5 ERROR: flash_full_capsule: version error private_metadata_write: enter: boot_index = 1 private_metadata_write: success fmp_set_image_info:133 Enter FMP image update: image id = 0 FMP image update: status = 1version=6 last_attempt_version=5. fmp_set_image_info:157 Exit. corstone1000_fwu_flash_image: exit: ret = -1 fmp_get_image_info:232 Enter pack_image_info:207 ImageInfo size = 105, ImageName size = 34, ImageVersionName size = 36 fmp_get_image_info:236 Exit ... The Secure Enclave tries to load the new image a predetermined number of times if the capsule passes initial verification but fails verifications performed during boot time. .. code-block:: console ... metadata_write: success: active = 0, previous = 1 fwu_select_previous: in regular state by choosing previous active bank ... The Secure Enclave eventually reverts back to the previously running image. #. Reboot manually: .. code-block:: console Shell> reset #. Interrupt the U-Boot shell. .. code-block:: console Hit any key to stop autoboot: #. Run the following commands in order to run the Corstone-1000 Linux kernel. .. note:: Otherwise, the execution ends up in the ACS live image. .. code-block:: console $ unzip $kernel_addr 0x90000000 $ loadm 0x90000000 $kernel_addr_r $filesize $ bootefi $kernel_addr_r $fdtcontroladdr #. The first boot after a capsule update is considered the trial stage, during which the FWU image is rejected. However, to view the updated contents of the ESRT, an additional reboot is required. .. code-block:: console # reboot #. Interrupt the U-Boot shell when prompted. .. code-block:: console Hit any key to stop autoboot: #. Run the following commands to boot the Corstone-1000 Linux kernel. .. note:: If these commands are not executed, the system will default to booting into the ACS live image. .. code-block:: console $ unzip $kernel_addr 0x90000000 $ loadm 0x90000000 $kernel_addr_r $filesize $ bootefi $kernel_addr_r $fdtcontroladdr #. Once the system has fully booted again, `read the ESRT `__ to confirm that the firmware version reflects the updated capsule. .. _verifying-firmware-versions-via-esrt: ************************************* Verifying Firmware Versions via ESRT ************************************* After the system has fully booted, verify that the firmware versions of all applied capsule payloads match those currently installed on the system. This can be done by inspecting the ESRT, which is exposed by the Linux kernel. Reading ESRT Entries ==================== To read each ESRT entry, use the following commands: .. code-block:: bash cat /sys/firmware/efi/esrt/entries/entry0/* cat /sys/firmware/efi/esrt/entries/entry1/* cat /sys/firmware/efi/esrt/entries/entry2/* cat /sys/firmware/efi/esrt/entries/entry3/* These entries typically correspond to: - ``entry0``: BL2 - ``entry1``: TFM_S - ``entry2``: FIP - ``entry3``: INITRAMFS .. note:: Entry indices may vary depending on how your firmware capsules are structured. Adjust as needed. Structure of Each ESRT Entry ============================ Each directory under ``/sys/firmware/efi/esrt/entries/entryX/`` contains files representing the following fields: +---------------------------------+--------------------------------------------------------------+ | Field Name | Description | +=================================+==============================================================+ | ``capsule_flags`` | Attributes of the update capsule (e.g., persist, reset) | +---------------------------------+--------------------------------------------------------------+ | ``fw_class`` | GUID identifying the firmware component | +---------------------------------+--------------------------------------------------------------+ | ``fw_type`` | Firmware type (e.g., system, device, peripheral) | +---------------------------------+--------------------------------------------------------------+ | ``fw_version`` | Currently installed firmware version | +---------------------------------+--------------------------------------------------------------+ | ``last_attempt_status`` | Status of the last update attempt (e.g., success, failure) | +---------------------------------+--------------------------------------------------------------+ | ``last_attempt_version`` | Version that was last attempted to install | +---------------------------------+--------------------------------------------------------------+ | ``lowest_supported_fw_version`` | Minimum firmware version that is still supported | +---------------------------------+--------------------------------------------------------------+ Verifying an ESRT Entry ======================= To check the version and status of BL2 (``entry0``), run: .. code-block:: bash cat /sys/firmware/efi/esrt/entries/entry0/fw_version cat /sys/firmware/efi/esrt/entries/entry0/last_attempt_version cat /sys/firmware/efi/esrt/entries/entry0/last_attempt_status Positive Full Capsule Update Test ESRT ====================================== The following table shows the details of the first four ESRT entries for the positive capsule update test: +-------------------+-----------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ | ``capsule_flags`` | ``fw_class`` | ``fw_type`` | ``fw_version`` | ``last_attempt_status`` | ``last_attempt_version`` | ``lowest_supported_fw_ver`` | +===================+=======================+=============+================+=========================+==========================+=============================+ | 0 | ``${BL2_GUID}`` | 0 | 6 | 0 | 6 | 0 | +-------------------+-----------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ | 0 | ``${TFM_S_GUID}`` | 0 | 6 | 0 | 6 | 0 | +-------------------+-----------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ | 0 | ``${FIP_GUID}`` | 0 | 6 | 0 | 6 | 0 | +-------------------+-----------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ | 0 | ``${INITRAMFS_GUID}`` | 0 | 6 | 0 | 6 | 0 | +-------------------+-----------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ Positive Partial Capsule Update Test ESRT ========================================= The following table shows the details of the first four ESRT entries for the positive capsule update test: +-------------------+-----------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ | ``capsule_flags`` | ``fw_class`` | ``fw_type`` | ``fw_version`` | ``last_attempt_status`` | ``last_attempt_version`` | ``lowest_supported_fw_ver`` | +===================+=======================+=============+================+=========================+==========================+=============================+ | 0 | ``${BL2_GUID}`` | 0 | 7 | 0 | 7 | 0 | +-------------------+-----------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ | 0 | ``${TFM_S_GUID}`` | 0 | 6 | 0 | 6 | 0 | +-------------------+-----------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ | 0 | ``${FIP_GUID}`` | 0 | 6 | 0 | 6 | 0 | +-------------------+-----------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ | 0 | ``${INITRAMFS_GUID}`` | 0 | 6 | 0 | 6 | 0 | +-------------------+-----------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ Rollback Protection Capsule Update Test ESRT ============================================ The following table shows the details of the first four ESRT entries for the rollback protection capsule update test: +-------------------+------------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ | ``capsule_flags`` | ``fw_class`` | ``fw_type`` | ``fw_version`` | ``last_attempt_status`` | ``last_attempt_version`` | ``lowest_supported_fw_ver`` | +===================+========================+=============+================+=========================+==========================+=============================+ | 0 | ``${BL2_GUID}`` | 0 | 7 | 1 | 5 | 0 | +-------------------+------------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ | 0 | ``${TFM_S_GUID}`` | 0 | 6 | 0 | 6 | 0 | +-------------------+------------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ | 0 | ``${FIP_GUID}`` | 0 | 6 | 0 | 6 | 0 | +-------------------+------------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ | 0 | ``${INITRAMFS_GUID}`` | 0 | 6 | 0 | 6 | 0 | +-------------------+------------------------+-------------+----------------+-------------------------+--------------------------+-----------------------------+ See the `UEFI documentation `__ for more information on the significance of the table fields. Linux Distributions ------------------- This sections describes the steps to install major Linux distributions to the Corstone-1000 Host Processor. The Linux distributions to be installed are: - `Debian `__ - `openSUSE `__ Follow the instructions below to install the Linux distributions to the Corstone-1000 software stack. ************************** Prepare Installation Media ************************** The media containing the bootable files required to start the installation process needs to be prepared. Follow the instructions below to create the installation media. #. Using your development machine, download one of following Linux distribution images: - `Debian installer image `__ - `openSUSE Leap installer image `__ .. note:: The location of the ISO file on the development machine will be referred to as ``${DISTRO_INSTALLER_ISO_PATH}``. #. Create the installation media which will contain the necessary files to install the operation system. - **MPS3**: #. Plug a blank USB drive formatted with FAT32, ensuring it has a minimum capacity of 4GB, to the development machine. #. Run the following command to discover which device is your USB drive: .. code-block:: console lsblk The remaining steps assume the USB drive is ``/dev/sdb``. .. warning:: Do not mistake your development machine hard drive with the USB drive. #. Write one of the distribution installer ISO file to the USB drive. .. code-block:: console sudo dd if=${DISTRO_INSTALLER_ISO_PATH} of=/dev/sdb iflag=direct oflag=direct status=progress bs=1M; sync; - **FVP**: The distribution installer ISO file does not need to be burnt to a USB drive. It will be used as is when starting the FVP install the distribution. ******************** Prepare System Drive ******************** A system (or boot) drive, to store all the operating system files and used to boot the distribution, is required as Corstone-1000 on-board non-volatile storage size is insufficient for installing the distributions. - MPS3: #. Find another blank USB drive formatted with FAT32 with a minimum capacity of 4GB. #. Do not yet connect this blank USB drive to the MPS3. It will be used as the primary drive to boot the distribution. - FVP: #. Create an 10 GB GUID Partition Table (GPT) formatted MultiMediaCard (MMC) image. .. code-block:: console dd if=/dev/zero of=${WORKSPACE}/fvp_distro_system_drive.img \ bs=1 count=0 seek=10G; sync; \ parted -s fvp_distro_system_drive.img mklabel gpt #. This MMC image will be used as the primary drive to boot the distribution. ************ Installation ************ MPS3 ==== #. Connect the installation media, which contains the installer for the desired distribution, to the MPS3. #. Open a serial port terminal interface to ``/dev/ttyUSB0`` in one terminal window on your development machine. .. code-block:: console sudo picocom -b 115200 /dev/ttyUSB0 #. Open a serial port terminal interface to ``/dev/ttyUSB2`` in another terminal window on your development machine. .. code-block:: console sudo picocom -b 115200 /dev/ttyUSB2 #. When the installation screen is displayed on ``ttyUSB2``, plug in the (still empty) system drive to the MPS3. #. Start the distribution installation process. .. note:: Reboot the MPS3 with both USB drives (installation media and empty system drive) connected to it if the distribution installer does not start. .. note:: Due to the performance limitation, the distribution installation process can take up to 24 hours to complete. FVP === #. Run the ``tmux``: .. code-block:: console cd ${WORKSPACE} && tmux #. Start the FVP within ``tmux`` with the system drive as the primary drive and the distro ISO file as the secondary drive: .. code-block:: console kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml \ -c "../meta-arm/scripts/runfvp --terminals=tmux -- \ -C board.msd_mmc.p_mmc_file=${WORKSPACE}/fvp_distro_system_drive.img \ -C board.msd_mmc_2.p_mmc_file=${DISTRO_INSTALLER_ISO_PATH}" The Linux distribution will be installed on ``fvp_distro_system_drive.img``. Debian Installation Extra Steps =============================== Debian installation may need some extra steps, that are indicated below: #. Answer ``Yes`` to the question ``Force grub installation to the EFI removable media path?``. If the GRUB installation fails, these are the steps to follow on the subsequent popups: #. Select ``Continue``, then ``Continue`` again on the next popup. #. Scroll down and select ``Execute a shell``. #. Select ``Continue``. #. Enter the following command: .. code-block:: console in-target grub-install --no-nvram --force-extra-removable #. Enter the following command: .. code-block:: console in-target update-grub #. Enter the following command: .. code-block:: console exit #. Select ``Continue without boot loader``, then select ``Continue`` on the next popup. #. At this stage, the installation should proceed as normal. #. Answer ``No`` to the question ``Update NVRAM variables to automatically boot into Debian?``. ***************** Boot Distribution ***************** - MPS3 #. Once the installation is complete, unplug the installation media. #. Perform a cold boot of the MPS3. - FVP The target should automatically boot into the installed operating system image. Stop the FVP with ``CTRL+C`` and run ``tmux``: .. code-block:: console cd ${WORKSPACE} && tmux Run the command below to simulate a cold boot: .. code-block:: console kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml \ -c "../meta-arm/scripts/runfvp --terminals=tmux -- \ -C board.msd_mmc.p_mmc_file=${WORKSPACE}/fvp_distro_system_drive.img" .. warning:: To manually enter recovery mode, once the FVP begins booting, you can quickly change the boot option in GRUB, to boot into recovery mode. This option will disappear quickly, so it is best to preempt it. Select ``Advanced Options for `` and then `` (recovery mode)``. The target will then enter recovery mode, from which the user can access a shell after entering the password for the ``root`` user. Timeout Optimizations ===================== .. important:: Operating system timeouts are inconsistent across systems. Skip this section if the system boots to Debian or openSUSE without any issue. Make the system modification below whilst in recovery mode to increase timeouts and boot to the installed distribution. #. Remove the timeout limit for device operations. - Debian .. code-block:: console vi /etc/systemd/system.conf DefaultDeviceTimeoutSec=infinity - openSUSE .. code-block:: console vi /usr/lib/systemd/system.conf DefaultDeviceTimeoutSec=infinity .. warning:: As modifying ``system.conf`` in ``/usr/lib/systemd/`` is not working as it is getting overwritten, copy ``system.conf`` from ``/usr/lib/systemd/`` to ``/etc/systemd/system.conf.d/`` after the above edit. #. Set the maximum time that the system will wait for a user to successfully log in before timing out to 180 seconds. - Debian .. code-block:: console vi /etc/login.defs LOGIN_TIMEOUT 180 - openSUSE .. code-block:: console vi /usr/etc/login.defs LOGIN_TIMEOUT 180 #. Ensure the changes are applied by run the command below. .. code-block:: console systemctl daemon-reload #. Perform a cold boot of the target. Log into the Distribution ========================= Login with the ``root`` username and its corresponding password (set during installation) at the distribution login prompt after booting. See an illustration for Debian below: .. code-block:: console debian login: UEFI Secure Boot ---------------- The UEFI Secure Boot test is designed to verify the integrity and authenticity of the system’s boot process. This test ensures that only trusted, signed images are executed, thereby preventing unauthorized or malicious code from running. A successful test confirms that the signed image executes correctly, while any unsigned image is blocked from running. ********************************************** Generate Keys, Signed Image and Unsigned Image ********************************************** #. Build an EFI System Partition as described `here `__. #. Clone the `systemready-patch` repository to your workspace. .. code-block:: console cd ${WORKSPACE} git clone https://gitlab.arm.com/arm-reference-solutions/systemready-patch \ -b CORSTONE1000-2025.12 #. Set the current working directory to build directory's subdirectory containing the software stack build images. .. code-block:: console cd ${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/ #. Run the image signing script (without changing the current working directory). .. code-block:: console ./${WORKSPACE}/systemready-patch/embedded-a/corstone1000/secureboot/create_keys_and_sign.sh \ -d ${TARGET} \ -v ${CERTIFICATE_VALIDITY_DURATION_IN_DAYS} .. important:: The `efitools `__ package is required to execute the script. ``${CERTIFICATE_VALIDITY_DURATION_IN_DAYS}`` is an integer that specifies the certificate's validity period in days. .. note:: Consult the image signing script help message (``-h``) for more information about other optional arguments. The script is interactive and contains commands that require ``sudo`` level permissions. The keys, signed kernel image, and unsigned kernel image will be copied to the exisiting ESP image. The modified ESP image can be found at ``${WORKSPACE}/build/tmp/deploy/images/corstone1000-${TARGET}/corstone1000-esp-image-corstone1000-${TARGET}.wic``. **************************** Run Unsigned Image Boot Test **************************** .. _unsigned-image-boot-test-mps3: MPS3 ==== #. Follow the instructions `here `__ to use the ESP. #. Perform a cold boot of the MPS3. #. On the Host Processor terminal host side, stop the execution of U-Boot when prompted to do so with the message ``Press any key to stop``. .. warning:: There is a timeout of 3 seconds to stop the execution at the U-Boot prompt. The U-Boot console prompt looks as follows: .. code-block:: console corstone1000# .. important:: The rest of the instructions below will be executed on the U-Boot terminal. #. On the U-Boot console, reset USB. .. code-block:: console corstone1000# usb reset resetting USB... Bus usb@40200000: isp1763 bus width: 16, oc: not available USB ISP 1763 HW rev. 32 started scanning bus usb@40200000 for devices... port 1 high speed 3 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found .. note:: Occasionally, the USB reset may fail to detect the USB device. It is advisable to rerun the USB reset command. #. Select the first USB device, which should be the USB drive containing the ESP. .. code-block:: console corstone1000# usb dev 0 #. Enroll the four UEFI secure boot authenticated variables. .. code-block:: console corstone1000# \ load usb 0 $loadaddr corstone1000_secureboot_keys/PK.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize PK; \ load usb 0 $loadaddr corstone1000_secureboot_keys/KEK.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize KEK; \ load usb 0 $loadaddr corstone1000_secureboot_keys/db.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize db; \ load usb 0 $loadaddr corstone1000_secureboot_keys/dbx.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize dbx #. Attempt to Load the unsigned kernel image. .. code-block:: console corstone1000# \ load usb 0 $loadaddr corstone1000_secureboot_mps3_images/Image_mps3 loadm $loadaddr $kernel_addr_r $filesize bootefi $kernel_addr_r $fdtcontroladdr Booting /MemoryMapped(0x0,0x88200000,0x236aa00) Image not authenticated Loading image failed The unsigned Linux kernel image should not be loaded. .. _unsigned-image-boot-test-fvp: FVP === #. Follow the instructions `here `__ to use the ESP. #. Run the software stack as described `here `__. #. On the Host Processor terminal host side, stop the execution of U-Boot when prompted to do so with the message ``Press any key to stop``. .. warning:: There is a timeout of 3 seconds to stop the execution at the U-Boot prompt. The U-Boot console prompt looks as follows: .. code-block:: console corstone1000# .. important:: The rest of the instructions below will be executed on the U-Boot terminal. #. On the U-Boot console, set the current MMC device. .. code-block:: console corstone1000# mmc dev 1 #. Enroll the four UEFI secure boot authenticated variables. .. code-block:: console corstone1000# \ load mmc 1:1 $loadaddr corstone1000_secureboot_keys/PK.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize PK; \ load mmc 1:1 $loadaddr corstone1000_secureboot_keys/KEK.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize KEK; \ load mmc 1:1 $loadaddr corstone1000_secureboot_keys/db.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize db; \ load mmc 1:1 $loadaddr corstone1000_secureboot_keys/dbx.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize dbx #. Attempt to Load the unsigned kernel image. .. code-block:: console corstone1000# \ load mmc 1:1 $loadaddr corstone1000_secureboot_fvp_images/Image_fvp; \ loadm $loadaddr $kernel_addr_r $filesize; \ bootefi $kernel_addr_r $fdtcontroladdr Booting /MemoryMapped(0x0,0x88200000,0x236aa00) Image not authenticated Loading image failed The unsigned Linux kernel image should not be loaded. ************************** Run Signed Image Boot Test ************************** MPS3 ==== .. important:: You must first perform the `Unsigned Image Boot Test `__. Load the signed kernel image. .. code-block:: console corstone1000# \ load usb 0 $loadaddr corstone1000_secureboot_mps3_images/Image_mps3.signed; \ loadm $loadaddr $kernel_addr_r $filesize; \ bootefi $kernel_addr_r $fdtcontroladdr The signed Linux kernel image should be booted successfully. FVP === .. important:: You must first perform the `Unsigned Image Boot Test `__. Load the signed kernel image. .. code-block:: console corstone1000# \ load mmc 1:1 $loadaddr corstone1000_secureboot_fvp_images/Image_fvp.signed; \ loadm $loadaddr $kernel_addr_r $filesize; \ bootefi $kernel_addr_r $fdtcontroladdr The signed Linux kernel image should be booted successfully. ******************* Disable Secure Boot ******************* Running the UEFI Secure Boot Test steps stores UEFI authenticated variables in the secure flash. As a result, U-Boot reads these variables and verifies the Linux kernel image before executing it at each reboot. In a typical boot scenario, the Linux kernel image is not signed, which will prevent the system from booting due to failed image authentication. To resolve this, the Platform Key (one of the UEFI authenticated variables for secure boot) needs to be deleted. #. Perform a cold boot of the MPS3. #. On the Host Processor terminal host side, stop the execution of U-Boot when prompted to do so with the message ``Press any key to stop``. #. On the U-Boot console, delete the Platform Key (PK). - MPS3 .. code-block:: console corstone1000# \ usb reset; \ usb dev 0; \ load usb 0 $loadaddr corstone1000_secureboot_keys/PK_delete.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize PK; \ boot - FVP .. code-block:: console corstone1000# \ mmc dev 1; \ load mmc 1:1 $loadaddr corstone1000_secureboot_keys/PK_delete.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize PK; \ boot PSA API ------- The following tests the implementation of the Application Programming Interface (API) of the Platform Security Architecture (PSA) certification scheme. It uses Arm Firmware Framework for Arm A-profile (FF-A) to communicate between the normal world and the secure world to run the `Arm Platform Security Architecture Test Suite `__. The tests use the `arm_tstee` driver to access Trusted Services Secure Partitions from user space. The driver is included in the Linux Kernel, starting from v6.10. .. important:: Ensure there are no USB drives connected to the board when running the test on the MPS3. The steps below are applicable to both MPS3 and FVP. #. Start the Corstone-1000 and wait until it boots to Linux on the Host Processor terminal (``ttyUSB2``). #. Run the PSA API tests by running the commands below in the order shown: .. code-block:: console psa-iat-api-test psa-crypto-api-test psa-its-api-test psa-ps-api-test External System Processor ------------------------- .. important:: Access to the External System Processor is disabled by default. Ensure you are running a software stack image with access to the External System Processor enabled following the steps `here `__. The Linux operating system running on the Host Processor starts the ``remoteproc`` framework to manage the External System Processor. #. Stop the External System Processor with the following command: .. code-block:: console echo stop > /sys/class/remoteproc/remoteproc0/state #. Start the External System Processor with the following command: .. code-block:: console echo start > /sys/class/remoteproc/remoteproc0/state Symmetric Multiprocessing ------------------------- .. warning:: Symmetric multiprocessing (SMP) mode is only supported on Corstone-1000 with Cortex-A35 FVP but is disabled by default. #. Build the software stack with SMP mode enabled: .. code-block:: console kas build meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-fvp-multicore.yml #. Run the Corstone-1000 FVP: .. code-block:: console kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-fvp-multicore.yml \ -c "../meta-arm/scripts/runfvp" #. Verify that the FVP is running the Host Processor with more than one CPU core: .. code-block:: console nproc 4 # number of processing units Ethos-U85 NPU ------------- .. warning:: The Ethos-U85 NPU is only supported on Corstone-1000 with Cortex-A320 FVP. #. Clone the `systemready-patch` repository to your ``${WORKSPACE}``. .. code-block:: console cd ${WORKSPACE} git clone https://git.gitlab.arm.com/arm-reference-solutions/systemready-patch.git \ -b CORSTONE1000-2025.12 #. Copy the additional kas configuration file to: .. code-block:: console cp ${WORKSPACE}/systemready-patch/embedded-a/corstone1000/ethos-u85_test/ethos-u85_test.yml \ ${WORKSPACE}/meta-arm/kas/ #. Re-Build the Corstone-1000 with Cortex-A320 FVP software stack as follows: .. code-block:: console kas build meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-a320.yml:\ meta-arm/kas/ethos-u85_test.yml #. Run the Corstone-1000 with Cortex-320 FVP: .. code-block:: console kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-a320.yml:\ systemready-patch/embedded-a/corstone1000/ethos-u85_test/ethos-u85_test.yml \ -c "../meta-arm/scripts/runfvp" #. To verify you are running the Corstone-1000 with Cortex-A320, build and run the FVP and inspect the CPU model reported in ``/proc/cpuinfo`` as shown below. Inside the FVP shell, confirm the core type: .. code-block:: console grep -E 'CPU part|model name' /proc/cpuinfo # Expect: CPU part : 0xd8f (which corresponds to Cortex-A320) #. Run the `delegate_runner` test application inside the FVP shell as follows: .. code-block:: console delegate_runner -l /usr/lib/libethosu_op_delegate.so \ -n /usr/share/ethosu/mobilenet_v2_1.0_224_INT8_vela.tflite \ -i /usr/share/ethosu/input_data0.bin \ -o /usr/share/ethosu/actual_output_data0.bin The test completes in approximately one minute. #. Run the following command to compare the generated output binary with the expected output binary: .. code-block:: console cmp -s /usr/share/ethosu/expected_output_data0.bin /usr/share/ethosu/actual_output_data0.bin The two binary files should be identical. Secure Debug ------------ .. warning:: Secure Debug is only supported on MPS3. The MPS3 supports Authenticated Debug Access Control (ADAC), using the CoreSight SDC-600 IP. For more information about this, see the following resources: - `CoreSight SDC-600 `__ - `Authenticated Debug Access Control Specification `__ - `Arm Corstone-1000 for MPS3 Application Note AN550, Chapter 7 `__ The Secure Debug Manager API is implemented in the `Secure Debug Manager (PSA-ADAC / SDC-600) `__ repository. This repository also contains the necessary files for the Arm Development Studio support. The build and integration instructions can be found in its `README `__. The `Secure Debug Manager (PSA-ADAC / SDC-600)` repository also contains the private key and chain certificate to be used during the tests. The private key's public pair is provisioned into the One-Time Programmable memory in TrustedFirmware-M. These are dummy keys that should not be used in production. To test the Secure Debug feature, you'll need a debug probe from the `Arm ULINKpro family `__ and `Arm Development Studio `__ versions 2022.2, 2022.c, or 2023.a. #. Clone the `Secure Debug Manager (PSA-ADAC / SDC-600)` repository to your workspace. .. code-block:: console cd ${WORKSPACE} git clone https://github.com/ARM-software/secure-debug-manager.git #. Navigate into the repository directory and checkout the specific commit in the listing below. .. code-block:: console cd ${WORKSPACE}/secure-debug-manager git checkout b30d6496ca749123e86b39b161b9f70ef76106d6 #. Follow the instructions in the `Secure Debug Manager (PSA-ADAC / SDC-600)'s README `__ for the development machine setup. #. Rebuild the software stack with Secure Debug. .. code-block:: console kas build meta-arm/kas/corstone1000-mps3.yml:meta-arm/ci/debug.yml:meta-arm/ci/secure-debug.yml #. Flash the firmware image as shown `here `__. #. Run the software as shown `here `__. #. Wait until the Secure Enclave terminal (``ttyUSB1``) prints the following prompts: .. code-block:: console IComPortInit : 382 : warn : init : IComPortInit: Blocked reading of LPH2RA is active. IComPortInit : 383 : warn : init : IComPortInit: Blocked reading LPH2RA #. Connect the debug probe to the MPS3 using the 20-pin 1.27mm connector with the ``CS_20W_1.27MM silkscreen`` label. #. Create a debug configuration in Arm Development Studio as described in the `Secure Debug Manager (PSA-ADAC / SDC-600)'s README `__. #. Connect the debuger to the target using the debug configuration. #. Provide the paths to the private key and trust chain certificate when asked by Arm Development Studio Console. .. code-block:: console ... Please provide private key file path: Enter file path > ${WORKSPACE}\secure-debug-manager\example\data\keys\EcdsaP256Key-3.pem Please provide trust chain file path: Enter file path > ${WORKSPACE}\secure-debug-manager\example\data\chains\chain.EcdsaP256-3 ... #. When successful authenticated, Arm Development Studio will connect to the running MPS3 and the debug features can be used. The following prompt should appear in the Secure Enclave terminal (``ttyUSB1``): .. code-block:: console ... boot_platform_init: Corstone-1000 Secure Debug is a success. ... -------------- *Copyright (c) 2022-2025, Arm Limited. All rights reserved.* .. _arm-developer-fvp: https://developer.arm.com/tools-and-software/open-source-software/arm-platforms-software/arm-ecosystem-fvps .. _secure-debug-manager-repo-readme: https://github.com/ARM-software/secure-debug-manager/tree/master?tab=readme-ov-file#secure-debug-manager-psa-adac--sdc-600 .. _secure-debug-manager-armds-integration: https://github.com/ARM-software/secure-debug-manager?tab=readme-ov-file#arm-development-studio-integration .. _meta-arm-repository-release-branch: https://web.git.yoctoproject.org/meta-arm?h=walnascar .. _arm-ulink-pro-website: https://www.arm.com/products/development-tools/debug-probes/ulink-pro .. _arm-ds-website: https://www.arm.com/products/development-tools/embedded-and-software/arm-development-studio .. _edk2-repository: https://github.com/tianocore/edk2
