Build, Flash and Run
Notice
The Corstone-1000 software stack uses the Yocto Project to build a tiny Linux distribution suitable for the Corstone-1000 platform (kernel and initramfs filesystem less than 5 MB on the flash). The Yocto Project relies on the BitBake tool as its build tool. Please see Yocto Project documentation for more information.
Prerequisites
This guide assumes that your host machine is running Ubuntu 20.04 LTS ( with sudo rights), with at least
32GB of free disk space and 16GB of RAM as minimum requirement.
The following prerequisites must be available on the host system:
Git 1.8.3.1 or greater.
Python 3.8.0 or greater.
GNU Tar 1.28 or greater.
GNU Compiler Collection 8.0 or greater.
GNU Make 4.0 or greater.
tmux.
Please follow the steps described in the Yocto mega manual:
Targets
The Corstone-1000 software stack can be run on:
Important
Arm Corstone-1000 for MPS3 requires an additional 32 MB QSPI flash PMOD module. For more information see the Application Note AN550 document.
Yocto Stable Branch
Corstone-1000 software stack is built on top of Yocto styhead release.
Software Components
Within the Yocto Project, each component included in the Corstone-1000 software stack is specified as
a BitBake recipe.
The recipes specific to the Corstone-1000 BSP are located at:
$WORKSPACE/meta-arm/meta-arm-bsp/.
Important
$WORKSPACE refers to the absolute path to your workspace where the meta-arm repository will be cloned.
$TARGET is either mps3 or fvp.
The Yocto machine config files for the Corstone-1000 FVP and MPS3 targets are:
$WORKSPACE/meta-arm/meta-arm-bsp/conf/machine/include/corstone1000.inc
$WORKSPACE/meta-arm/meta-arm-bsp/conf/machine/corstone1000-$TARGET.conf
Note
All the paths stated in this document are absolute paths.
Host Processor Components
Trusted Firmware-A
bbappend |
Recipe |
Trusted Services
bbappend |
bbappend |
bbappend |
bbappend |
bbappend |
bbappend |
bbappend |
Recipe |
Recipe |
Recipe |
Recipe |
Recipe |
Recipe |
Recipe |
OP-TEE
bbappend |
Recipe |
U-Boot
bbappend |
bbappend |
Recipe |
Linux
The distribution is based on the Poky distribution which is a Linux distribution stripped down to a minimal configuration.
The provided distribution is based on BusyBox and built using musl libc.
bbappend |
Recipe |
defconfig |
Secure Enclave Components
Trusted Firmware-M
bbappend |
Recipe |
External System Processor Components
RTX Real-Time operating system
An example application that uses the RTX Real-Time Operating System.
The application project can be found here.
Recipe |
Build
Warning
Building binaries natively on Windows and AArch64 Linux is not supported.
Use an AMD64 Linux based development machine to build the software stack and transfer the binaries to run the software stack on an FVP in Windows or AArch64 Linux if required.
Create a new folder that will be your workspace.
mkdir $WORKSPACE cd $WORKSPACE
Install kas version 4.4 with
sudorights.sudo pip3 install kas==4.4Ensure the kas installation directory is visible on the
$PATHenvironment variable.Clone the meta-arm Yocto layer in the workspace
$WORKSPACE.cd $WORKSPACE git clone https://git.yoctoproject.org/git/meta-arm -b CORSTONE1000-2024.11
Build a Corstone-1000 image:
kas build meta-arm/kas/corstone1000-$TARGET.yml:meta-arm/ci/debug.ymlImportant
Accept the EULA at https://developer.arm.com/downloads/-/arm-ecosystem-fvps/eula to build a Corstone-1000 image for FVP as follows:
export ARM_FVP_EULA_ACCEPT="True"Warning
Access to the External System Processor is disabled by default. To build the Corstone-1000 image with External System Processor enabled, run:
kas build meta-arm/kas/corstone1000-$TARGET.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-extsys.yml
A clean build takes a significant amount of time given that all of the development machine utilities are also built along with the target images. Those development machine utilities include executables (Python, CMake, etc.) and the required toolchains.
Once the build succeeds, all output binaries will be placed in $WORKSPACE/build/tmp/deploy/images/corstone1000-$TARGET/
Everything apart from the Secure Enclave ROM firmware and External System firmware, is bundled into a single binary, the
corstone1000-flash-firmware-image-corstone1000-$TARGET.wic file.
- The output binaries run in the Corstone-1000 platform are the following:
The Secure Enclave ROM firmware:
$WORKSPACE/build/tmp/deploy/images/corstone1000-$TARGET/bl1.binThe External System Processor firmware:
$WORKSPACE/build/tmp/deploy/images/corstone1000-$TARGET/es_flashfw.binThe internal firmware flash image:
$WORKSPACE/build/tmp/deploy/images/corstone1000-$TARGET/corstone1000-flash-firmware-image-corstone1000-$TARGET.wic
Flash
Note
The steps below only apply to the MPS3. The FVP being a software application running on your development machine does not require any firmware flashing. Refer to this section for running the software stack on FVP.
Download the FPGA bit file image
AN550: Arm® Corstone™-1000 for MPS3 Version 2.0on the Arm Developer website. Click on theDownload AN550 bundlebutton and login to download the file.The directory structure of the FPGA bundle is as shown below:
Boardfiles ├── config.txt ├── MB │ ├── BRD_LOG.TXT │ ├── HBI0309B │ │ ├── AN550 │ │ │ ├── AN550_v2.bit │ │ │ ├── an550_v2.txt │ │ │ └── images.txt │ │ ├── board.txt │ │ └── mbb_v210.ebf │ └── HBI0309C │ ├── AN550 │ │ ├── AN550_v2.bit │ │ ├── an550_v2.txt │ │ └── images.txt │ ├── board.txt │ └── mbb_v210.ebf └── SOFTWARE ├── an550_st.axf ├── bl1.bin ├── cs1000.bin └── ES0.bin
Depending upon the MPS3 board version, you should update the
images.txtfile (found in the correspondingHBI0309xfolder e.g.Boardfiles/MB/HBI0309$BOARD_VERSION/AN550/images.txt) so it points to the images under theSOFTWAREdirectory. Where$BOARD_VERSIONis a variable containing the board printed on the MPS3 board.The
images.txtfile compatible with the latest version of the software stack can be seen below;;************************************************ ; Preload port mapping * ;************************************************ ; PORT 0 & ADDRESS: 0x00_0000_0000 QSPI Flash (XNVM) (32MB) ; PORT 0 & ADDRESS: 0x00_8000_0000 OCVM (DDR4 2GB) ; PORT 1 Secure Enclave (M0+) ROM (64KB) ; PORT 2 External System 0 (M3) Code RAM (256KB) ; PORT 3 Secure Enclave OTP memory (8KB) ; PORT 4 CVM (4MB) ;************************************************ [IMAGES] TOTALIMAGES: 3 ;Number of Images (Max: 32) IMAGE0PORT: 1 IMAGE0ADDRESS: 0x00_0000_0000 IMAGE0UPDATE: RAM IMAGE0FILE: \SOFTWARE\bl1.bin IMAGE1PORT: 0 IMAGE1ADDRESS: 0x00_0000_0000 IMAGE1UPDATE: AUTOQSPI IMAGE1FILE: \SOFTWARE\cs1000.bin IMAGE2PORT: 2 IMAGE2ADDRESS: 0x00_0000_0000 IMAGE2UPDATE: RAM IMAGE2FILE: \SOFTWARE\es0.bin
Copy
bl1.binfrom$WORKSPACE/build/tmp/deploy/images/corstone1000-mps3to theSOFTWAREdirectory of the FPGA bundle.Copy
es_flashfw.binfrom$WORKSPACE/build/tmp/deploy/images/corstone1000-mps3to theSOFTWAREdirectory of the FPGA bundle and rename the binary toes0.bin.Copy
corstone1000-flash-firmware-image-corstone1000-mps3.wicfrom$WORKSPACE/build/tmp/deploy/images/corstone1000-mps3to theSOFTWAREdirectory of the FPGA bundle and rename the wic image tocs1000.bin.
Note
Renaming of the images is required because the MCC firmware has a limit of 8 characters for file name and 3 characters for file extension.
After making all modifications above, copy the FPGA bit file bundle to the board’s SDCard and reboot the MPS3.
Run
Once the target is turned ON, the Secure Enclave will start to boot, wherein the relevant memory contents of the *.wic
file are copied to their respective memory locations. Firewall policies are enforced
on memories and peripherals before bringing the Host Processor out of reset.
The Host Processor will boot TrustedFirmware-A, OP-TEE, U-Boot and then Linux before presenting a login prompt.
MPS3
Open 4 serial port comms terminals on the host machine. Those might be
ttyUSB0,ttyUSB1,ttyUSB2, andttyUSB3on Linux machines.
ttyUSB0for MCC, OP-TEE and Secure Partition
ttyUSB1for Secure Enclave (Cortex-M0+)
ttyUSB2for Host Processor (Cortex-A35)
ttyUSB3for External System Processor (Cortex-M3)The serial ports might be different on Windows machines.
Run the following commands in separate terminal instances on Linux:
sudo picocom -b 115200 /dev/ttyUSB0sudo picocom -b 115200 /dev/ttyUSB1sudo picocom -b 115200 /dev/ttyUSB2sudo picocom -b 115200 /dev/ttyUSB3Important
Plug a connected Ethernet cable to the MPS3 or it will wait for a network connection for a considerable amount of time, printing the following on the Host Processor terminal (
ttyUSB2):Generic PHY 40100000.ethernet-ffffffff:01: attached PHY driver (mii_bus:phy_addr=40100000.ethernet-ffffffff:01, irq=POLL) smsc911x 40100000.ethernet eth0: SMSC911x/921x identified at 0xffffffc008e50000, IRQ: 17 Waiting up to 100 more seconds for network.
Once the system boot is completed, you should see console logs on the serial port terminals. Once the Host Processor is booted completely, user can login to the shell using
rootlogin.Important
The secure flash might be completely filled if the system does not boot and only the Secure Enclave logs (
ttyUSB1) are visible.Clean the secure flash if that is the case following the steps here.
FVP
A Fixed Virtual Platform (FVP) model of the Corstone-1000 platform must be available to run the Corstone-1000 FVP software image.
A Yocto recipe is provided to download the latest supported FVP version.
The recipe is located at $WORKSPACE/meta-arm/meta-arm/recipes-devtools/fvp/fvp-corstone1000.bb.
The latest FVP version is 11.23.25 and is automatically downloaded and installed when using the
runfvp command as detailed below.
Note
kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml \
-c "../meta-arm/scripts/runfvp -- --version"
The FVP can also be manually downloaded from the Arm Ecosystem FVPs page by navigating to “Corstone IoT FVPs” section to download the Corstone-1000 platform FVP installer. Follow the instructions of the installer to setup the FVP.
Run the FVP
kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml \ -c "../meta-arm/scripts/runfvp --terminals=tmux"
When the script is executed, three terminal instances will be launched:
one for the Secure Enclave processing element
two for the Host processor processing element.
corstone1000-fvp login:Login using the
rootusername.
Security Issue Reporting
To report any security issues identified with Corstone-1000, please send an email to psirt@arm.com.
Tests
Important
All the tests below assume you have already built the software stack at least once following the instructions here.
Clean Secure Flash
Important
The MPS3 secure flash needs to be cleared before running tests. This is to erase the flash cleanly and prepare a clean board environment for testing.
Clone the systemready-patch repository to your $WORKSPACE.
cd $WORKSPACE git clone https://git.gitlab.arm.com/arm-reference-solutions/systemready-patch.git -b CORSTONE1000-2024.11
Copy the secure flash cleaning Git patch file to your copy of meta-arm.
cp -f systemready-patch/embedded-a/corstone1000/erase_flash/0001-embedded-a-corstone1000-clean-secure-flash.patch meta-armApply the Git patch to meta-arm.
cd meta-arm git apply 0001-embedded-a-corstone1000-clean-secure-flash.patch
Rebuild the software stack.
cd $WORKSPACE kas shell meta-arm/kas/corstone1000-mps3.yml:meta-arm/ci/debug.yml bitbake -c cleansstate trusted-firmware-m corstone1000-flash-firmware-image bitbake -c build corstone1000-flash-firmware-image
Replace the
bl1.binfile on the SD card with$WORKSPACE/build/tmp/deploy/images/corstone1000-mps3/bl1.bin.Reboot the board to completely erase the secure flash.
The following message log from TrustedFirmware-M should be displayed on the Secure Enclave terminal (
ttyUSB1):!!!SECURE FLASH HAS BEEN CLEANED!!! NOW YOU CAN FLASH THE ACTUAL CORSTONE1000 IMAGE PLEASE REMOVE THE LATEST ERASE SECURE FLASH PATCH AND BUILD THE IMAGE AGAIN
Whilst still in the
kasshell, revert the changes the patch introduced by running the following commands:cd $WORKSPACE/meta-arm git reset --hard cd .. bitbake -c cleansstate trusted-firmware-m corstone1000-flash-firmware-image exit
Follow the instructions to build a clean software stack and flash the MPS3 with it.
You can proceed with the test instructions in the following section after having done all the above.
SystemReady-IR
Important
Running the SystemReady-IR tests described below requires USB drives. In our testing, not all USB drive models worked well with the MPS3.
Here are the USB drive models that were stable in our test environment:
HP v165w 8 GB USB Flash Drive
SanDisk Ultra 32GB Dual USB Flash Drive USB M3.0
SanDisk Ultra 16GB Dual USB Flash Drive USB M3.0
Follow the instructions below before running the Architecture Compliance Suite (ACS) tests.
Build an EFI System Partition
A storage with EFI System Partition (ESP) must exist in the system for the UEFI-SCT related tests to pass.
Build an ESP partition for your target
kas build meta-arm/kas/corstone1000-$TARGET.yml:meta-arm/ci/debug.yml --target corstone1000-esp-imageLocate the
corstone1000-esp-image-corstone1000-$TARGET.wicbuild artefact in$WORKSPACE/build/tmp/deploy/images/corstone1000-$TARGET/
Use the EFI System Partition
MPS3
Connect a USB drive to your development machine.
Run the following command on your development machine to discover which device is your USB drive:
lsblkThe remaining steps assume the USB drive is
/dev/sdb.Warning
Do not mistake your development machine hard drive with the USB drive.
Copy the ESP to the USB drive by running the following command:
sudo dd \ if=$WORKSPACE/build/tmp/deploy/images/corstone1000-mps3/corstone1000-esp-image-corstone1000-mps3.wic \ of=/dev/sdb \ iflag=direct oflag=direct status=progress bs=512; sync;
Plug the USB drive to the MPS3.
FVP
The ESP disk image will automatically be used by the Corstone-1000 FVP as the 2nd MMC card image. It will be used when the SystemReady-IR tests is performed on the FVP in the later section.
Run SystemReady-IR ACS Tests
ACS is used to ensure architectural compliance across different implementations of the architecture. Arm Enterprise ACS includes a set of examples of the invariant behaviors that are provided by a set of specifications for enterprise systems (i.e. SBSA, SBBR, etc.). Implementers can verify if these behaviors have been interpreted correctly.
The following test suites and bootable applications are under the BOOT partition of the ACS image:
SCT
FWTS
BSA UEFI
BSA linux
GRUB
UEFI manual capsule application
See the directory structure of the ACS image BOOT partition below:
├── EFI
│ └── BOOT
│ ├── app
│ ├── bbr
│ ├── bootaa64.efi
│ ├── bsa
│ ├── debug
│ ├── Shell.efi
│ └── startup.nsh
├── grub
├── grub.cfg
├── Image
├── ramdisk-busybox.img
└── acs_results
The BOOT partition is also used to store test results in the acs_results folder.
Important
Ensure that the acs_results folder is empty before starting the test.
This sections below describe how to build and run ACS tests on Corstone-1000.
On your host development machine, clone the Arm SystemReady ACS repository.
cd $WORKSPACE git clone https://github.com/ARM-software/arm-systemready.git
This repository contains the infrastructure to build the ACS and the bootable prebuilt images to be used for the certifications of SystemReady-IR.
Find the pre-built ACS live image in
$WORKSPACE/arm-systemready/IR/prebuilt_images/v23.09_2.1.0/ir-acs-live-image-generic-arm64.wic.xz.Note
This prebuilt ACS image includes v5.13 kernel, which does not provide USB driver support for Corstone-1000. The ACS image with a newer kernel version and full USB support for Corstone-1000 will be available in the repository with the next SystemReady release.
Decompress the pre-built ACS live image.
cd $WORKSPACE/arm-systemready/IR/prebuilt_images/v23.09_2.1.0 unxz ir-acs-live-image-generic-arm64.wic.xz
MPS3
Connect a USB drive (other than the one used for the ESP) to the host development machine.
Run the following command to discover which device is your USB drive:
/dev/sdc.Warning
Copy the ACS image to the USB drive by running the following commands:
cd $WORKSPACE/arm-systemready/IR/prebuilt_images/v23.09_2.1.0 sudo dd if=ir-acs-live-image-generic-arm64.wic of=/dev/sdc iflag=direct oflag=direct bs=1M status=progress; sync
Plug the USB drive to the MPS3. At this point you should have both the USB drive with the ESP and the USB drive with the ACS image plugged to the MPS3.
Reboot the MPS3.
The MPS3 will reset multiple times during the test, and it might take approximately 24 to 36 hours to finish the test.
Important
Unplug the ESP USB drive from the MPS3 if it is preventing GRUB from finding the bootable partition. Leave only the ACS image USB drive plugged in to run the ACS tests.
The ESP USB drive can be plugged in again after selecting the Linux Boot option in the GRUB menu at the end of the ACS tests.
Warning
A timeout issue has been observed while booting Linux during the ACS tests, causing the system to boot into emergency mode. Booting Linux is necessary to run certain tests, such as dt-validation. The following workaround is required to enable Linux to boot properly and perform all Linux-based tests:
Press Enter at the Linux prompt.
Open the file /etc/systemd/system.conf and set DefaultDeviceTimeoutSec=infinity.
Reboot the platform using the reboot command.
Select the Linux Boot option from the GRUB menu.
Allow Linux to boot and run the remaining ACS tests until completion.
FVP
Run the commands below to run the ACS test on FVP using the built firmware image and the pre-built ACS image identified above:
cd $WORKSPACE
tmux
./meta-arm/scripts/runfvp \
--terminals=tmux \
./build/tmp/deploy/images/corstone1000-fvp/corstone1000-flash-firmware-image-corstone1000-fvp.fvpconf \
-- -C board.msd_mmc.p_mmc_file=$WORKSPACE/arm-systemready/IR/prebuilt_images/v23.09_2.1.0/ir-acs-live-image-generic-arm64.wic
Note
The FVP will reset multiple times during the test. The ACS tests might take up to 1 day to complete when run on FVP.
The message ACS run is completed will be displayed on the FVP host terminal when the test runs to completion. You will be prompted to press the Enter key to access the Linux prompt.
Test Sequence and Results
U-Boot should be able to boot the GRUB bootloader from the first partition.
If GRUB is not interrupted, the tests are executed automatically in the following order:
SCT
UEFI BSA
FWTS
The results can be fetched from the acs_results folder in the BOOT partition of the USB drive (for MPS3) or SD Card (for FVP).
Note
Access the acs_results folder in FVP by running the following commands:
sudo mkdir /mnt/test
sudo mount -o rw,offset=1048576 \
$WORKSPACE/arm-systemready/IR/prebuilt_images/v23.09_2.1.0/ir-acs-live-image-generic-arm64.wic \
/mnt/test
Capsule Update
The following section describes the steps to update the firmware using Capsule Update as the Corstone-1000 supports UEFI.
The firmware update process is tested with an invalid capsule (negative capsule update test) and with a valid capsule (positive capsule update test) to validate the robustness and error-handling capabilities of the firmware update mechanism.
During the positive capsule update test, the Corstone-1000 is given a valid capsule, which it successfully applies, boots up and then reaches the Linux command prompt.
During the negative capsule update test, the Corstone-1000 is given an outdated capsule with a lower version number, which is expected to be rejected due to its outdated status, thereby retaining the previous firmware.
Two different capsules (one for each test) are therefore needed to perform the tests.
Generate Capsules
U-Boot’s mkeficapsule tool is used to generate capsules. It is built automatically for the host machine during the firmware image building process.
The tool can be found in the $WORKSPACE/build/tmp/sysroots-components/x86_64/u-boot-tools-native/usr/bin/mkeficapsule directory.
mkeficapsule uses a no-partition image which is created when performing a clean firmware build.
The no-partition image can be found in the $WORKSPACE/build/tmp/deploy/images/corstone1000-$TARGET/corstone1000-$TARGET_image.nopt directory.
The capsule’s default metadata passed can be found in the $WORKSPACE/meta-arm/meta-arm-bsp/recipes-bsp/images/corstone1000-flash-firmware-image.bb
and $WORKSPACE/meta-arm/kas/corstone1000-image-configuration.yml files.
Valid Capsule
An automatically generated capsule can be found in $WORKSPACE/build/tmp/deploy/images/corstone1000-$TARGET/corstone1000-$TARGET-v6.uefi.capsule after running a firmware build.
The default metadata values are assumed to be correct to generate a valid capsule.
This capsule will be used for the positive capsule update test.
Invalid Capsule
Generate another capsule with fw-version metadata set to a lower version than the valid capsule.
The example below assumes the valid capsule has a default firmware version of 6, and therefore creates an invalid capsule with firmware version 5.
Run the following commands to generate an invalid capsule with a fw-version of 5:
cd $WORKSPACE
./build/tmp/sysroots-components/x86_64/u-boot-tools-native/usr/bin/mkeficapsule \
--monotonic-count 1 \
--private-key build/tmp/deploy/images/corstone1000-$TARGET/corstone1000_capsule_key.key \
--certificate build/tmp/deploy/images/corstone1000-$TARGET/corstone1000_capsule_cert.crt \
--index 1 \
--guid $TARGET_GUID \
--fw-version 5 build/tmp/deploy/images/corstone1000-$TARGET/corstone1000-$TARGET_image.nopt \
corstone1000-$TARGET-v5.uefi.capsule
Important
$TARGET_GUID is different depending on whether the capsule is built for the fvp or mps3 $TARGET.
fvp$TARGET_GUIDis989f3a4e-46e0-4cd0-9877-a25c70c01329mps3$TARGET_GUIDisdf1865d1-90fb-4d59-9c38-c9f2c1bba8cc
The invalid capsule will be located in the $WORKSPACE directory.
Transfer Capsules to Target
The capsule delivery process described below is the direct method (usage of capsules from the ACS image) as opposed to the on-disk method (delivery of capsules using a file on a mass storage device).
MPS3
Prepare a USB drive as explained in this section.
Copy the capsule file to the root directory of the
BOOTpartition in the USB drive.
sudo cp $CAPSULES_PATH/corstone1000-mps3-v6.uefi.capsule $ACS_IMAGE_USB_DRIVE_PATH/BOOT/ sudo cp $CAPSULES_PATH/corstone1000-mps3-v5.uefi.capsule $ACS_IMAGE_USB_DRIVE_PATH/BOOT/ sync
Important
Since we are using the direct Capsule Update method, the capsule files should not be placed in
the EFI/UpdateCapsule directory, as this might inadvertently trigger the on-disk update method.
FVP
Download and extract the ACS image as described for the MPS3. The ACS image extraction location will be referred below as
$ACS_IMAGE_PATH.Note
Creating a USB drive with the ACS image is not required as the image will be mounted with the steps below.
Find the first partition’s offset of the
ir-acs-live-image-generic-arm64.wicimage using thefdisktool. The partition table can be listed using:fdisk -lu $ACS_IMAGE_PATH/ir-acs-live-image-generic-arm64.wic Device Start End Sectors Size Type $ACS_IMAGE_PATH/ir-acs-live-image-generic-arm64.wic1 2048 309247 307200 150M Microsoft basic data $ACS_IMAGE_PATH/ir-acs-live-image-generic-arm64.wic2 309248 1343339 1034092 505M Linux filesystem
Given that the first partition starts at sector 2048 and each sector is 512 bytes in size, the first partition is at offset 1048576 (2048 x 512).
Mount the
ir-acs-live-image-generic-arm64.wicimage using the previously calculated offset:sudo mkdir /mnt/ir-acs-live-image-generic-arm64 sudo mount -o rw,offset=<first_partition_offset> $ACS_IMAGE_PATH/ir-acs-live-image-generic-arm64.wic /mnt/ir-acs-live-image-generic-arm64
Copy the capsules:
sudo cp $CAPSULES_PATH/corstone1000-fvp-v6.uefi.capsule /mnt/ir-acs-live-image-generic-arm64/ sudo cp $CAPSULES_PATH/corstone1000-fvp-v5.uefi.capsule /mnt/ir-acs-live-image-generic-arm64/ sync
Unmount the IR image:
sudo umount /mnt/ir-acs-live-image-generic-arm64
Run Capsule Update Tests
The valid capsule (corstone1000-$TARGET-v6.uefi.capsule) will be used first to run the positive capsule update test.
This will be followed by using the invalid capsule (corstone1000-$TARGET-v5.uefi.capsule) to run the negative capsule update test.
Important
This sequence order must be respected as the invalid capsule has a firmware version lower than the firmware version in the valid capsule. The negative capsule update test effectively tests that firmware rollback is not permitted.
Positive Capsule Update Test
Run Corstone-1000 with the ACS image containing the two capsule files:
MPS3:
Plug the prepared USB drive which has the IR prebuilt image and two capsules to the MPS3.
Power cycle the MPS3.
FVP:
Run the FVP with the IR prebuilt image which now also contains the two capsules:
kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml \ -c "../meta-arm/scripts/runfvp --terminals=tmux \ -- -C board.msd_mmc.p_mmc_file=$ACS_IMAGE_PATH/ir-acs-live-image-generic-arm64.wic"
Warning
$ACS_IMAGE_PATHmust be an absolute path. Ensure there are no spaces before or after of=of the-C board.msd_mmc.p_mmc_fileoption.
Wait until U-Boot loads EFI from the ACS image and interrupt the EFI shell by pressing the
Escapekey when the following prompt is displayed on the Host Processor terminal (ttyUSB2).Press ESC in 4 seconds to skip startup.nsh or any other key to continue.Access the content of the first file system (
File System 0) where we copied the capsule files by running the following command:FS0:Run the
CapsuleAppapplication with the valid capsule file:MPS3:
EFI/BOOT/app/CapsuleApp.efi EFI/BOOT/corstone1000-mps3-v6.uefi.capsuleFVP:
EFI/BOOT/app/CapsuleApp.efi corstone1000-fvp-v6.uefi.capsule
The capsule update will be started.
Note
The capsule update takes about 8 minutes to complete on MPS3 and between 15-30 minutes on FVP.
The Corstone-1000 will reset after successfully applying the capsule.
The software stack copies the capsule content to the external flash, which is shared between the Secure Enclave and the Host Processor before rebooting the system.
After the first reboot, TrustedFirmware-M should apply the valid capsule and display the following log on the Secure Enclave terminal (
ttyUSB1) before rebooting the system a second time:... SysTick_Handler: counted = 10, expiring on = 360 SysTick_Handler: counted = 20, expiring on = 360 SysTick_Handler: counted = 30, expiring on = 360 ... metadata_write: success: active = 1, previous = 0 flash_full_capsule: exit corstone1000_fwu_flash_image: exit: ret = 0 ...
The above log snippet indicates that the new capsule image is successfully applied, and the board is booting with the external flash’s Bank-1.
After a second reboot, the following log should be displayed on on the Secure Enclave terminal (
ttyUSB1):... fmp_set_image_info:133 Enter FMP image update: image id = 0 FMP image update: status = 0version=6 last_attempt_version=6. fmp_set_image_info:157 Exit. corstone1000_fwu_host_ack: exit: ret = 0 ...
Interrupt the U-Boot shell.
Hit any key to stop autoboot:Run the following commands in order to run the Corstone-1000 Linux kernel.
Note
Otherwise, the execution ends up in the ACS live image.
$ unzip $kernel_addr 0x90000000 $ loadm 0x90000000 $kernel_addr_r $filesize $ bootefi $kernel_addr_r $fdtcontroladdr
After the system fully boots, read the EFI System Resource Table (ESRT) to verify that the firmware version matches the version of the capsule applied.
# cd /sys/firmware/efi/esrt/entries/entry0 # cat * 0x0 # capsule_flags 989f3a4e-46e0-4cd0-9877-a25c70c01329 # fw_class 0 # fw_type 6 # fw_version 0 # last_attempt_status 6 # last_attempt_version 0 # lowest_supported_fw_verSee the UEFI documentation for more information on the significance of the table fields.
Warning
Do not terminate FVP between the positive and negative capsule update tests.
Negative Capsule Update Test
Important
The positive capsule update test must be run before running the negative capsule update test.
After running the positive capsule update test, reboot the system by typing the following command on the Host Processor terminal (
ttyUSB2):rebootWait until U-Boot loads EFI from the ACS image and interrupt the EFI shell by pressing the
CapsuleAppapplication with the invalid capsule file:MPS3:
EFI/BOOT/app/CapsuleApp.efi EFI/BOOT/corstone1000-mps3-v5.uefi.capsuleFVP:
EFI/BOOT/app/CapsuleApp.efi corstone1000-fvp-v5.uefi.capsule
TrustedFirmware-M should reject the capsule due to having a lower firmware version and display the following log on the Secure Enclave terminal (
ttyUSB1):... uefi_capsule_retrieve_images: image 0 at 0xa0000070, size=15654928 uefi_capsule_retrieve_images: exit flash_full_capsule: enter: image = 0x0xa0000070, size = 7764541, version = 5 ERROR: flash_full_capsule: version error private_metadata_write: enter: boot_index = 1 private_metadata_write: success fmp_set_image_info:133 Enter FMP image update: image id = 0 FMP image update: status = 1version=6 last_attempt_version=5. fmp_set_image_info:157 Exit. corstone1000_fwu_flash_image: exit: ret = -1 fmp_get_image_info:232 Enter pack_image_info:207 ImageInfo size = 105, ImageName size = 34, ImageVersionName size = 36 fmp_get_image_info:236 Exit ...
The Secure Enclave tries to load the new image a predetermined number of times if the capsule passes initial verification but fails verifications performed during boot time.
... metadata_write: success: active = 0, previous = 1 fwu_select_previous: in regular state by choosing previous active bank ...
The Secure Enclave eventually reverts back to the previously running image.
Reboot manually:
Shell> resetInterrupt the U-Boot shell.
Note
After the system fully boots, read the ESRT to verify the firmware version does not match what is on the invalid capsule.
# cd /sys/firmware/efi/esrt/entries/entry0 # cat * 0x0 # capsule_flags 989f3a4e-46e0-4cd0-9877-a25c70c01329 # fw_class 0 # fw_type 6 # fw_version 1 # last_attempt_status 5 # last_attempt_version 0 # lowest_supported_fw_ver
Linux Distributions
This sections describes the steps to install major Linux distributions to the Corstone-1000 Host Processor.
The Linux distributions to be installed are:
Follow the instructions below to install the Linux distributions to the Corstone-1000 software stack.
Prepare Installation Media
The media containing the bootable files required to start the installation process needs to be prepared.
Follow the instructions below to create the installation media.
Using your development machine, download one of following Linux distribution images:
Note
For openSUSE Tumbleweed, search for an ISO file with the format:
openSUSE-Tumbleweed-DVD-aarch64-Snapshot$DATE-Media.iso.openSUSE-Tumbleweed-DVD-aarch64-Snapshot20240516-Media.isowas used during development.The location of the ISO file on the development machine will be referred to as
$DISTRO_INSTALLER_ISO_PATH.Create the installation media which will contain the necessary files to install the operation system.
MPS3:
Plug a blank USB drive formatted with FAT32, ensuring it has a minimum capacity of 4GB, to the development machine.
/dev/sdb.Warning
Write one of the distribution installer ISO file to the USB drive.
sudo dd if=$DISTRO_INSTALLER_ISO_PATH of=/dev/sdb iflag=direct oflag=direct status=progress bs=1M; sync;
FVP:
The distribution installer ISO file does not need to be burnt to a USB drive. It will be used as is when starting the FVP install the distribution.
Prepare System Drive
A system (or boot) drive, to store all the operating system files and used to boot the distribution, is required as Corstone-1000 on-board non-volatile storage size is insufficient for installing the distributions.
- MPS3:
Find another blank USB drive formatted with FAT32 with a minimum capacity of 4GB.
Do not yet connect this blank USB drive to the MPS3. It will be used as the primary drive to boot the distribution.
- FVP:
Create an 10 GB GUID Partition Table (GPT) formatted MultiMediaCard (MMC) image.
dd if=/dev/zero of=$WORKSPACE/fvp_distro_system_drive.img \ bs=1 count=0 seek=10G; sync; \ parted -s fvp_distro_system_drive.img mklabel gptThis MMC image will be used as the primary drive to boot the distribution.
Installation
MPS3
Connect the installation media, which contains the installer for the desired distribution, to the MPS3.
Open a serial port terminal interface to
/dev/ttyUSB0in one terminal window on your development machine.sudo picocom -b 115200 /dev/ttyUSB0Open a serial port terminal interface to
/dev/ttyUSB2in another terminal window on your development machine.sudo picocom -b 115200 /dev/ttyUSB2When the installation screen is displayed on
ttyUSB2, plug in the (still empty) system drive to the MPS3.Start the distribution installation process.
Note
Reboot the MPS3 with both USB drives (installation media and empty system drive) connected to it if the distribution installer does not start.
Note
Due to the performance limitation, the distribution installation process can take up to 24 hours to complete.
FVP
Start the FVP with the system drive as the primary drive and the distro ISO file as the secondary drive.
kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml \ -c "../meta-arm/scripts/runfvp --terminals=tmux -- \ -C board.msd_mmc.p_mmc_file=$WORKSPACE/fvp_distro_system_drive.img \ -C board.msd_mmc_2.p_mmc_file=$DISTRO_INSTALLER_ISO_PATH"
The Linux distribution will be installed on
fvp_distro_system_drive.img.
Debian Installation Extra Steps
Debian installation may need some extra steps, that are indicated below:
Answer
Yesto the questionForce grub installation to the EFI removable media path?.If the GRUB installation fails, these are the steps to follow on the subsequent popups:
Select
Continue, thenContinueagain on the next popup.Scroll down and select
Execute a shell.Select
Continue.Enter the following command:
in-target grub-install --no-nvram --force-extra-removableEnter the following command:
in-target update-grubEnter the following command:
exitSelect
Continue without boot loader, then selectContinueon the next popup.At this stage, the installation should proceed as normal.
Answer
Noto the questionUpdate NVRAM variables to automatically boot into Debian?.
Boot Distribution
MPS3
Once the installation is complete, unplug the installation media.
Perform a cold boot of the MPS3.
FVP
The target should automatically boot into the installed operating system image.
Stop the FVP and run the command below to simulate a cold boot:
kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml \ -c "../meta-arm/scripts/runfvp --terminals=tmux -- \ -C board.msd_mmc.p_mmc_file=$WORKSPACE/fvp_distro_system_drive.img"
Warning
To manually enter recovery mode, once the FVP begins booting, you can quickly change the boot option in GRUB, to boot into recovery mode. This option will disappear quickly, so it is best to preempt it.
Select
Advanced Options for <OS>and then<OS> (recovery mode).
The target will then enter recovery mode, from which the user can access a shell
after entering the password for the root user.
Timeout Optimizations
Important
Operating system timeouts are inconsistent across systems. Skip this section if the system boots to Debian or OpenSUSE without any issue.
Make the system modification below whilst in recovery mode to increase timeouts and boot to the installed distribution.
Remove the timeout limit for device operations.
- Debian
vi /etc/systemd/system.conf DefaultDeviceTimeoutSec=infinity
- openSUSE
vi /usr/lib/systemd/system.conf DefaultDeviceTimeoutSec=infinity
Warning
As modifying
system.confin/usr/lib/systemd/is not working as it is getting overwritten, copysystem.conffrom/usr/lib/systemd/to/etc/systemd/system.conf.d/after the above edit.
Set the maximum time that the system will wait for a user to successfully log in before timing out to 180 seconds.
- Debian
vi /etc/login.defs LOGIN_TIMEOUT 180
- openSUSE
vi /usr/etc/login.defs LOGIN_TIMEOUT 180
Ensure the changes are applied by run the command below.
systemctl daemon-reloadPerform a cold boot of the target.
Log into the Distribution
Login with the root username and its corresponding password (set during installation)
at the distribution login prompt after booting. See an illustration for Debian below:
debian login:
UEFI Secure Boot
The UEFI Secure Boot test is designed to verify the integrity and authenticity of the system’s boot process. This test ensures that only trusted, signed images are executed, thereby preventing unauthorized or malicious code from running. A successful test confirms that the signed image executes correctly, while any unsigned image is blocked from running.
Generate Keys, Signed Image and Unsigned Image
Build an EFI System Partition as described here.
Clone the systemready-patch repository to your workspace.
cd $WORKSPACE git clone https://git.gitlab.arm.com/arm-reference-solutions/systemready-patch.git \ -b CORSTONE1000-2024.11
Set the current working directory to build directory’s subdirectory containing the software stack build images.
cd $WORKSPACE/build/tmp/deploy/images/corstone1000-$TARGET/Run the image signing script (without changing the current working directory).
./$WORKSPACE/systemready-patch/embedded-a/corstone1000/secureboot/create_keys_and_sign.sh \ -d $TARGET \ -v $CERTIFICATE_VALIDITY_DURATION_IN_DAYS
Important
The efitools package is required to execute the script.
Note
Consult the image signing script help message (
-h) for more information about other optional arguments.The script is interactive and contains commands that require
sudolevel permissions.
The keys, signed kernel image, and unsigned kernel image will be copied to the exisiting ESP image.
The modified ESP image can be found at $WORKSPACE/build/tmp/deploy/images/corstone1000-$TARGET/corstone1000-esp-image-corstone1000-$TARGET.wic.
Run Unsigned Image Boot Test
FVP
Follow the instructions here to use the ESP.
Run the software stack as described here.
On the Host Processor terminal host side, stop the execution of U-Boot when prompted to do so with the message
Press any key to stop.Warning
There is a timeout of 3 seconds to stop the execution at the U-Boot prompt.
The U-Boot console prompt looks as follows:
corstone1000#Important
The rest of the instructions below will be executed on the U-Boot terminal.
On the U-Boot console, set the current MMC device.
corstone1000# mmc dev 1Enroll the four UEFI secure boot authenticated variables.
corstone1000# \ load mmc 1:1 $loadaddr corstone1000_secureboot_keys/PK.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize PK; \ load mmc 1:1 $loadaddr corstone1000_secureboot_keys/KEK.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize KEK; \ load mmc 1:1 $loadaddr corstone1000_secureboot_keys/db.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize db; \ load mmc 1:1 $loadaddr corstone1000_secureboot_keys/dbx.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize dbx
Attempt to Load the unsigned kernel image.
corstone1000# \ load mmc 1:1 $loadaddr corstone1000_secureboot_fvp_images/Image_fvp; \ loadm $loadaddr $kernel_addr_r $filesize; \ bootefi $kernel_addr_r $fdtcontroladdr Booting /MemoryMapped(0x0,0x88200000,0x236aa00) Image not authenticated Loading image failed
The unsigned Linux kernel image should not be loaded.
MPS3
On the U-Boot console, reset USB.
corstone1000# usb reset resetting USB... Bus usb@40200000: isp1763 bus width: 16, oc: not available USB ISP 1763 HW rev. 32 started scanning bus usb@40200000 for devices... port 1 high speed 3 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found
Note
Occasionally, the USB reset may fail to detect the USB device. It is advisable to rerun the USB reset command.
Select the first USB device, which should be the USB drive containing the ESP.
corstone1000# usb dev 0Enroll the four UEFI secure boot authenticated variables.
corstone1000# \ load usb 0 $loadaddr corstone1000_secureboot_keys/PK.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize PK; \ load usb 0 $loadaddr corstone1000_secureboot_keys/KEK.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize KEK; \ load usb 0 $loadaddr corstone1000_secureboot_keys/db.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize db; \ load usb 0 $loadaddr corstone1000_secureboot_keys/dbx.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize dbx
corstone1000# \ load usb 0 $loadaddr corstone1000_secureboot_mps3_images/Image_mps3 loadm $loadaddr $kernel_addr_r $filesize bootefi $kernel_addr_r $fdtcontroladdr Booting /MemoryMapped(0x0,0x88200000,0x236aa00) Image not authenticated Loading image failed
Run Signed Image Boot Test
FVP
Important
You must first perform the Unsigned Image Boot Test.
Load the signed kernel image.
corstone1000# \
load mmc 1:1 $loadaddr corstone1000_secureboot_fvp_images/Image_fvp.signed; \
The signed Linux kernel image should be booted successfully.
MPS3
Important
corstone1000# \
load usb 0 $loadaddr corstone1000_secureboot_mps3_images/Image_mps3.signed; \
Disable Secure Boot
Running the UEFI Secure Boot Test steps stores UEFI authenticated variables in the secure flash. As a result, U-Boot reads these variables and verifies the Linux kernel image before executing it at each reboot.
In a typical boot scenario, the Linux kernel image is not signed, which will prevent the system from booting due to failed image authentication. To resolve this, the Platform Key (one of the UEFI authenticated variables for secure boot) needs to be deleted.
Press any key to stop.On the U-Boot console, delete the Platform Key (PK).
FVP
corstone1000# \ mmc dev 1; \ load mmc 1:1 $loadaddr corstone1000_secureboot_keys/PK_delete.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize PK; \ boot
MPS3
corstone1000# \ usb reset; \ usb dev 0; \ load usb 0 $loadaddr corstone1000_secureboot_keys/PK_delete.auth && setenv -e -nv -bs -rt -at -i $loadaddr:$filesize PK; \ boot
PSA API
The following tests the implementation of the Application Programming Interface (API) of the Platform Security Architecture (PSA) certification scheme. It uses Arm Firmware Framework for Arm A-profile (FF-A) to communicate between the normal world and the secure world to run the Arm Platform Security Architecture Test Suite.
The tests use the arm_tstee driver to access Trusted Services Secure Partitions from user space. The driver is included in the Linux Kernel, starting from v6.10.
Important
Ensure there are no USB drives connected to the board when running the test on the MPS3.
The steps below are applicable to both MPS3 and FVP).
Start the Corstone-1000 and wait until it boots to Linux on the Host Processor terminal (
ttyUSB2).Run the PSA API tests by running the commands below in the order shown:
psa-iat-api-test psa-crypto-api-test psa-its-api-test psa-ps-api-test
Important
Access to the External System Processor is disabled by default. Ensure you are running a software stack image with access to the External System Processor enabled following the steps here.
The Linux operating system running on the Host Processor starts the remoteproc framework to manage the External System Processor.
Stop the External System Processor with the following command:
echo stop > /sys/class/remoteproc/remoteproc0/stateStart the External System Processor with the following command:
echo start > /sys/class/remoteproc/remoteproc0/state
Symmetric Multiprocessing
Warning
Symmetric multiprocessing (SMP) mode is only supported on FVP but is disabled by default.
Build the software stack with SMP mode enabled:
kas build meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-fvp-multicore.ymlRun the Corstone-1000 FVP:
kas shell meta-arm/kas/corstone1000-fvp.yml:meta-arm/ci/debug.yml:meta-arm/kas/corstone1000-fvp-multicore.yml \ -c "../meta-arm/scripts/runfvp"
Verify that the FVP is running the Host Processor with more than one CPU core:
nproc 4 # number of processing units
Secure Debug
Warning
Secure Debug is only supported on MPS3.
The MPS3 supports Authenticated Debug Access Control (ADAC), using the CoreSight SDC-600 IP.
For more information about this, see the following resources:
The Secure Debug Manager API is implemented in the secure-debug-manager repository. This repository also contains the necessary files for the Arm Development Studio support. The build and integration instructions can be found in its README.
The secure-debug-manager repository also contains the private key and chain certificate to be used during the tests. The private key’s public pair is provisioned into the One-Time Programmable memory in TrustedFirmware-M. These are dummy keys that should not be used in production.
To test the Secure Debug feature, you’ll need a debug probe from the DSTREAM family and Arm Development Studio versions 2022.2, 2022.c, or 2023.a.
Clone the secure-debug-manager repository to your workspace.
cd $WORKSPACE git clone https://github.com/ARM-software/secure-debug-manager.git
Navigate into the repository directory and checkout the specific commit in the listing below.
cd $WORKSPACE/secure-debug-manager git checkout b30d6496ca749123e86b39b161b9f70ef76106d6
Follow the steps in the secure-debug-manager’s README for the development machine setup.
Rebuild the software stack with Secure Debug.
kas build meta-arm/kas/corstone1000-mps3.yml:meta-arm/ci/debug.yml:meta-arm/ci/secure-debug.ymlFlash the firmware image as shown here.
Run the software as shown here.
Wait until the Secure Enclave terminal (
ttyUSB1) prints the following prompts:IComPortInit : 382 : warn : init : IComPortInit: Blocked reading of LPH2RA is active. IComPortInit : 383 : warn : init : IComPortInit: Blocked reading LPH2RA
Connect the debug probe to the MPS3 using the 20-pin 1.27mm connector with the
CS_20W_1.27MM silkscreenlabel.Create a debug configuration in Arm Development Studio as described in the secure-debug-manager’s README.
Connect the debuger to the target using the debug configuration.
Provide the paths to the private key and trust chain certificate when asked by Arm Development Studio Console.
... Please provide private key file path: Enter file path > $WORKSPACE\secure-debug-manager\example\data\keys\EcdsaP256Key-3.pem Please provide trust chain file path: Enter file path > $WORKSPACE\secure-debug-manager\example\data\chains\chain.EcdsaP256-3 ...
When successful authenticated, Arm Development Studio will connect to the running MS3 and the debug features can be used. The following prompt should appear in the Secure Enclave terminal (
ttyUSB1):... boot_platform_init: Corstone-1000 Secure Debug is a success. ...
Reports
Various test reports for the Corstone-1000 software (CORSTONE1000-2024.11) release version are available for reference here.
Copyright (c) 2022-2024, Arm Limited. All rights reserved.
