Change Log
This document contains a summary of the new features, changes and fixes in each release of Corstone-1000 software stack.
Version 2024.06
Changes
Re-enabling support for the External System using linux remoteproc (only supporting switching on and off the External System)
UEFI Secure Boot and Authenticated Variable support
RSE Comms replaces OpenAMP
The EFI System partition image is now created by the meta-arm build system. This image is mounted on the second MMC card by default in the FVP.
The capsule generation script is now part of the meta-arm build system. Corstone1000-flash-firmware-image recipe generates a capsule binary using the U-Boot capsule generation tool that includes all the firmware binaries and recovery kernel image.
SW components upgrades
Bug fixes
Corstone-1000 components versions
arm-tstee |
2.0.0 |
linux-yocto |
6.6.23 |
u-boot |
2023.07.02 |
external-system |
0.1.0 |
optee-client |
4.1.0 |
optee-os |
4.1.0 |
trusted-firmware-a |
2.10.4 |
trusted-firmware-m |
2.0.0 |
libts |
602be60719 |
ts-newlib |
4.1.0 |
ts-psa-{crypto, iat, its. ps}-api-test |
602be60719 |
ts-sp-{se-proxy, smm-gateway} |
602be60719 |
Yocto distribution components versions
meta-arm |
scarthgap |
poky |
scarthgap |
meta-openembedded |
scarthgap |
meta-secure-core |
scarthgap |
busybox |
1.36.1 |
musl |
1.2.4 |
gcc-arm-none-eabi |
13.2.Rel1 |
gcc-cross-aarch64 |
13.2.0 |
openssl |
3.2.1 |
Version 2023.11
Changes
Making Corstone-1000 SystemReady IR 2.0 certifiable
Allow booting Debian & OpenSUSE on FVP
Add support for two MMC cards for the FVP
Add signed capsule update support
Enable on-disk capsule update
Add the feature of purging specific DT nodes in U-Boot before Linux
Add Ethernet over VirtIO support in U-Boot
Add support for unaligned MMC card images
Reducing the out-of-tree patches by upstreaming them to the corresponding open-source projects
Bug fixes
arm-ffa-tee |
1.1.2-r0 |
linux-yocto |
6.5.7 |
u-boot |
2023.07 |
external-system |
0.1.0+gitAUTOINC+8c9dca74b1-r0 |
optee-client |
3.22.0 |
optee-os |
3.22.0 |
2.9.0 |
1.8.1 |
libts |
08b3d39471 |
ts-newlib |
4.1.0 |
38cb53a4d9 |
08b3d39471 |
meta-arm |
nanbield |
poky |
nanbield |
meta-openembedded |
nanbield |
meta-secure-core |
nanbield |
busybox |
1.36.1 |
musl |
1.2.4 |
gcc-arm-none-eabi |
11.2-2022.02 |
gcc-cross-aarch64 |
13.2.0 |
openssl |
3.1.3 |
Version 2023.06
Changes
GPT support (in TF-M, TF-A, U-boot)
Use TF-M BL1 code as the ROM code instead of MCUboot (the next stage bootloader BL2 remains to be MCUboot)
Secure Enclave uses CC312 OTP as the provisioning backend in FVP and FPGA
NVMXIP block storage support in U-Boot
Upgrading the SW stack recipes
Upgrades for the U-Boot FF-A driver and MM communication
arm-ffa-tee |
1.1.2-r0 |
arm-ffa-user |
5.0.1-r0 |
corstone1000-external-sys-tests |
1.0+gitAUTOINC+2945cd92f7-r0 |
external-system |
linux-yocto |
6.1.25+gitAUTOINC+36901b5b29_581dc1aa2f-r0 |
u-boot |
2023.01-r0 |
optee-client |
3.18.0-r0 |
optee-os |
3.20.0-r0 |
2.8.0-r0 |
1.7.0-r0 |
ts-newlib |
4.1.0-r0 |
38cb53a4d9 |
08b3d39471 |
meta-arm |
mickledore |
poky |
mickledore |
meta-openembedded |
mickledore |
busybox |
1.36.0-r0 |
musl |
1.2.3+gitAUTOINC+7d756e1c04-r0 |
gcc-arm-none-eabi-native |
11.2-2022.02 |
gcc-cross-aarch64 |
12.2.rel1-r0 |
openssl |
3.1.0-r0 |
Version 2022.11.23
Changes
Booting the External System (Cortex-M3) with RTX RTOS
Adding MHU communication between the HOST (Cortex-A35) and the External System
Adding a Linux application to test the External System
Adding ESRT (EFI System Resource Table) support
arm-ffa-tee |
1.1.1 |
arm-ffa-user |
5.0.0 |
1.0 |
external-system |
0.1.0 |
linux-yocto |
5.19 |
u-boot |
2022.07 |
optee-client |
3.18.0 |
optee-os |
3.18.0 |
2.7.0 |
1.6.0 |
ts-newlib |
4.1.0 |
451aa087a4 |
3d4956770f |
meta-arm |
langdale |
poky |
langdale |
meta-openembedded |
langdale |
busybox |
1.35.0 |
musl |
1.2.3+git37e18b7bf3 |
11.2-2022.02 |
gcc-cross-aarch64 |
12.2 |
openssl |
3.0.5 |
Version 2022.04.04
Changes
Linux distro openSUSE, raw image installation and boot in the FVP.
SCT test support in FVP.
Manual capsule update support in FVP.
Version 2022.02.25
Changes
Building and running psa-arch-tests on Corstone-1000 FVP
Enabled smm-gateway partition in Trusted Service on Corstone-1000 FVP
Enabled MHU driver in Trusted Service on Corstone-1000 FVP
Enabled OpenAMP support in SE proxy SP on Corstone-1000 FVP
Version 2022.02.21
Changes
psa-arch-tests: recipe is dropped and merged into the secure-partitons recipe.
psa-arch-tests: The tests are align with latest tfm version for psa-crypto-api suite.
Version 2022.01.18
Changes
psa-arch-tests: change master to main for psa-arch-tests
U-Boot: fix null pointer exception for get_image_info
TF-M: fix capsule instability issue for Corstone-1000
Version 2022.01.07
Changes
Corstone-1000: fix SystemReady-IR ACS test (SCT, FWTS) failures.
U-Boot: send bootcomplete event to secure enclave.
U-Boot: support populating Corstone-1000 image_info to ESRT table.
U-Boot: add ethernet device and enable configs to support bootfromnetwork SCT.
Version 2021.12.15
Changes
Enabling Corstone-1000 FPGA support on: - Linux 5.10 - OP-TEE 3.14 - Trusted Firmware-A 2.5 - Trusted Firmware-M 1.5
Adding openamp support in SE proxy SP
OP-TEE: adding smm-gateway partition
U-Boot: introducing Arm FF-A and MM support
Version 2021.10.29
Changes
Enabling Corstone-1000 FVP support on: - Linux 5.10 - OP-TEE 3.14 - Trusted Firmware-A 2.5 - Trusted Firmware-M 1.4
Linux kernel: enabling EFI, adding FF-A debugfs driver, integrating ARM_FFA_TRANSPORT.
U-Boot: Extending EFI support
python3-imgtool: adding recipe for Trusted-firmware-m
python3-imgtool: adding the Yocto recipe used in signing host images (based on MCUBOOT format)
Copyright (c) 2022-2024, Arm Limited. All rights reserved.
